path: root/configs/libretech-cc_defconfig
2019-04-10ARM: meson: display Amlogic SoC InformationJulien Masson
The Amlogic SoCs have a registers containing the die revision and packaging type to determine the SoC family and package marketing name like S905X for the GXL SoC Family. This code is taken from the Linux meson-gx-socinfo driver and adapted to U-Boot printing. Signed-off-by: Julien Masson <jmasson@baylibre.com> Signed-off-by: Neil Armstrong <narmstrong@baylibre.com> [narmstrong: also updated new p200/p201 defconfigs]
2019-02-07configs: Resync with savedefconfigTom Rini
2019-01-31arm: libretech-cc: enable video by defaultMaxime Jourdan
libretech-cc being the main device tested with CONFIG_VIDEO_MESON, let's enable it by default. Also enable: - CONFIG_SYS_WHITE_ON_BLACK for prettiness - CONFIG_VIDEO_DT_SIMPLEFB for framebuffer sharing with kernel Signed-off-by: Maxime Jourdan <mjourdan@baylibre.com> Signed-off-by: Neil Armstrong <narmstrong@baylibre.com> Reviewed-by: Anatolij Gustschin <agust@denx.de>
2019-01-31arm: meson64: enable console mux and console env by defaultMaxime Jourdan
With the recent addition of the meson VPU driver, enable the following config entries by default for meson-64 targets: CONFIG_CONSOLE_MUX, CONFIG_SYS_CONSOLE_IS_IN_ENV. This allows outputting the console via video if CONFIG_VIDEO_MESON is selected. Signed-off-by: Maxime Jourdan <mjourdan@baylibre.com> Signed-off-by: Neil Armstrong <narmstrong@baylibre.com> Reviewed-by: Anatolij Gustschin <agust@denx.de>
2019-01-07configs: Resync with savedefconfigTom Rini
2018-11-26ARM: rework amlogic configurationJerome Brunet
Rework the board SYS_BOARD, SYS_VENDOR and SYS_CONFIG_NAME setup by moving the board Kconfig into the mach-meson Kconfig to make it easier to add new boards for a SoC architecture and add a custom config header or custom board handler for a platform. This drops the board CONFIGs and the duplicate boards configs headers in favor of a single meson64.h config header. Signed-off-by: Jerome Brunet <jbrunet@baylibre.com> Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2018-11-26board: amlogic: remove p212 derivativesJerome Brunet
The Khadas vim and the libretech aml-s905x-cc (aka Potato) derive from amlogic s905x reference design (P212). All the code in these board is a copy/paste from the p212, which is tedious to maintain. This change use p212 u-boot board for all these boards, while keeping a dedicated defconfig to customize the names and device tree. Signed-off-by: Jerome Brunet <jbrunet@baylibre.com> Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2018-07-09configs: Resync with savedefconfigTom Rini
2018-06-19configs: Update Meson GX configsNeil Armstrong
Enable USB on all Amlogic Meson GXL based board. Enable Regulator support on all boards. Enable ADC support on the LibreTech-CC board. Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2018-04-13net: phy: Don't limit phy addresses by defaultJoe Hershberger
Some boards expect to find more than one phy while other boards are old and need to be limited to a specific phy address. Only limit the phy address for boards that opt in. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Tested-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Neil Armstrong <narmstrong@baylibre.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2018-03-13Move CONFIG_PHY_ADDR to KconfigStefan Mavrodiev
CONFIG_PHY_ADDR is used for old-style configuration. This makes impossible changing the PHY address, if multiple boards share a same config header file (for example include/configs/sunxi-common.h). Moving this to Kconfig helps overcoming this issue. It's defined as entry inside PHYLIB section. After the implemention, moveconfig was run. The issues are: - edb9315a - CONFIG_PHYLIB is not enabled. Entry is deleted. - ds414 - CONFIG_PHYLIB is in incompatible format: { 0x1, 0x0 }. This entry is also deleted. - devkit3250 - The PHY_ADDR is in hex format (0x1F). Manually CONFIG_PHY_ADDR=31 is added in the defconfig. After the changes the suspicious defconfigs passes building. Signed-off-by: Stefan Mavrodiev <stefan@olimex.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> [jagan: rebased on master] Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-12-18configs: Resync with savedefconfigTom Rini
2017-12-04ARM: arch-meson: build memory banks using reported memory from registersNeil Armstrong
As discussed at [1], the Amlogic Meson GX SoCs can embed a BL31 firmware and a secondary BL32 firmware. Since mid-2017, the reserved memory address of the BL31 firmware was moved and grown for security reasons. But mainline U-Boot and Linux has the old address and size fixed. These SoCs have a register interface to get the two firmware reserved memory start and sizes. This patch adds a dynamic reservation of the memory zones in the device tree bootmem reserved memory zone used by the kernel in early boot. To be complete, the memory zones are also added to the EFI reserved zones. Depends on patchset "Add support for Amlogic GXL Based SBCs" at [2]. [1] http://lists.infradead.org/pipermail/linux-amlogic/2017-October/004860.html [2] http://lists.infradead.org/pipermail/linux-amlogic/2017-November/005410.html Changes since v1: - switched the #if to if(IS_ENABLED()) to compile all code paths - renamed function to meson_board_add_reserved_memory() - added a mem.h header with comment - updated all boards ft_board_setup() Changes since RFC v2: - reduced preprocessor load - kept Odroid-C2 static memory mapping as exception Changes since RFC v1: - switch to fdt rsv mem table and efi reserve memory - replaced in_le32 by readl() Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Neil Armstrong <narmstrong@baylibre.com> [trini: Fix warning on khadas-vim over missing <asm/arch/mem.h> Signed-off-by: Tom Rini <trini@konsulko.com>
2017-12-04arm: Add LibreTech CC support based on Meson GXL familyNeil Armstrong
This adds platform code for the Libre Computer CC "Le Potato" board based on a Meson GXL (S905X) SoC with the Meson GXL configuration. This initial submission supports UART, MMC/SDCard and Ethernet with the Internal RMII PHY. The meson-gxl-s905x-libretech-cc.dts is synchronised from the linux 4.13 stable tree as of 4.13.8. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
