There are many boards share the board file and device header file with
rk3399 evb, add target type MACRO so that it is fixed instead of default
to the first target in "RK3399 board select".
Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
RK3288, RK3399 are now support cpu-info, so enable
DISPLAY_CPUINFO by default.
Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
Use the same SPL_STACK_R_ADDR in Kconfig instead of each board config;
default to 0x4000000(64MB) instead of 0x80000(512KB) for this address
can support all the SoCs including those may have only 64MB memory, and
also reserve enough space for atf, kernel(in falcon mode) loading.
After the ATF entry move to 0x40000, the stack from 0x80000 may be override
when loading ATF bl31.
We use to reserve IRAM to avoid the SPL text overlap with ATF M0 code,
and when we introduce the TPL, the SPL space is in DRAM, we reserve
space to avoid SPL text overlap with ATF bl31.
Now we decide to move ATF entry point to 0x40000 instead of 0x1000,
so that the SPL can have 0x4000 as code size and no need to reserve
space or relocate before loading ATF.
The mainline ATF has update since:
0aad563c rockchip: Update BL31_BASE to 0x40000
Specification
- Rockchip RK3399
- LPDDR4
- TF sd scard slot
- eMMC
- M.2 B-Key for 4G LTE
- AP6256 for WiFi + BT
- Gigabit ethernet
- HDMI out
- 40 pin header
- USB 2.0 x 2
- USB 3.0 x 1
- USB 3.0 Type-C x 1
- TYPE-C Power supply
Commit details of rk3399-leez-p710.dts sync from linus tree for Linux 5.4-rc1:
"arm64: dts: rockchip: Add dts for Leez RK3399 P710 SBC"
(sha1: fc702ed49a8668a17343811ee28214d845bfc5e6)
Signed-off-by: Andy Yan <andyshrk@gmail.com>
