path: root/configs/kylin-rk3036_defconfig
2016-07-25cosmetic: rockchip: rk3036: pinctrl: fix config symbol namingHeiko Stübner
Rockchip socs are always named rkxxxx in all places, as also shown by the naming of the rk3036 pinctrl file itself. Therefore also name the config symbol according to this scheme. Signed-off-by: Heiko Stuebner <heiko@sntech.de> Acked-by: Simon Glass <sjg@chromium.org>
2016-05-26Rename reset to sysresetStephen Warren
The current reset API implements a method to reset the entire system. In the near future, I'd like to introduce code that implements the device tree reset bindings; i.e. the equivalent of the Linux kernel's reset API. This controls resets to individual HW blocks or external chips with reset signals. It doesn't make sense to merge the two APIs into one since they have different semantic purposes. Resolve the naming conflict by renaming the existing reset API to sysreset instead, so the new reset API can be called just reset. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-03-14Correct defconfig orderingSimon Glass
Various boards have the wrong Kconfig ordering now. To avoid a misleading diff in the next patch, reorder the configuration correctly. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-12-13rockchip: Add basic support for kylin boardhuang lin
kylin board use rk3036 SOC, 512M sdram, 8G emmc. This add some basic files required to allow the board to output serial message and can run command(mmc info etc). Signed-off-by: Lin Huang <hl@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
