CONFIG_ENV_SPI_BUS
CONFIG_ENV_SPI_CS
CONFIG_ENV_SPI_MAX_HZ
CONFIG_ENV_SPI_MODE
As part of this, we use Kconfig to provide the defaults now that were
done in include/spi_flash.h. We also in some cases change from using
CONFIG_ENV_SPI_FOO to CONFIG_SF_DEFAULT_FOO as those were the values in
use anyhow as ENV was not enabled.
CONFIG_FSL_USDHC
Even if board can be successfuly built, CI goes in deadlock (see thread
on https://www.mail-archive.com/u-boot@lists.denx.de/msg419663.html).
This is caused by SYS_CONFIG set in header file and because defconfig
for the board is out of sync with Kconfig. As result, buildman goes on
to read from stdin until an OOM is reached.
CC: Frieder Schrempf <frieder.schrempf@kontron.de>
(N801x)
The Kontron SoM-Line i.MX8MM (N801x) by Kontron Electronics GmbH is a SoM
module with an i.MX8M-Mini SoC, 1/2/4 GB LPDDR4 RAM, SPI NOR, eMMC and PMIC.
The matching evaluation boards (Board-Line) have 2 Ethernets, USB 2.0, HDMI/LVDS,
SD card, CAN, RS485 and much more.
Signed-off-by: Frieder Schrempf <frieder.schrempf@kontron.de>
Reviewed-by: Stefano Babic <sbabic@denx.de>
Tested-by: Heiko Thiery <heiko.thiery@gmail.com>
