enable DTS support for keymile mpc83xx based boards.
get rid of compile warning:
===================== WARNING ======================
This board does not use CONFIG_DM_ETH (Driver Model
for Ethernet drivers). Please update the board to use
CONFIG_DM_ETH before the v2020.07 release. Failure to
update by the deadline may result in board removal.
See doc/driver-model/migration.rst for more info.
Therefore done:
- add DTS for all mpc83xx based boards from keymile
mainly they are not mainlined to linux.
- add u-boot specific dtsi
- add stdout-path
- add missing ucc4 par_io definitions, which were
in board code, but not in linux DTS
- remove not used ethernet nodes
Patch-cc: Mario Six <mario.six@gdsys.cc>
Patch-cc: Qiang Zhao <qiang.zhao@nxp.com>
Series-to: u-boot
Series-version: 3
Series-changes: 3
- rebase patchset to current mainline commit
c0192950df
- update defconfig files
Series-changes: 2
- add patch which fixes Codingstyle errors in drivers/qe
- add patch which converts the mpc83xx based boards from
keymile to DM_ETH
Cover-letter:
powerpc, mpc83xx: add DM_ETH support
This patch series adds DM ethernet support for mpc83xx based
keymile boards.
Travis build:
END
CONFIG_ENV_OVERWRITE
[trini: Rerun migration, remove some comments]
This is the first step to use DM support for the KM powerpc boards.
Signed-off-by: Holger Brunck <holger.brunck@ch.abb.com>
Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
CC: Mario Six <mario.six@gdsys.cc>
CC: Wolfgang Denk <wd@denx.de>
CC: Valentin Longchamp <valentin.longchamp@ch.abb.com>
CC: Priyanka Jain <priyanka.jain@nxp.com>
Remove this from the board header files and move it to Kconfig. Also use
the correct default address for kmtegr1.
Both symbols must be enabled when there is a raw NAND driver
selected. Also enable them when CONFIG_CMD_NAND is selected to avoid
breaking things when we'll further rework the MTD dependency
description.
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
[trini: Rebase and migrate a few more boards here]
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
Move this symbol to Kconfig. As part of this we can drop a UBI-specific
symbol that was a stop-gap for not having this particular symbol in
Kconfig.
Move the main symbol for Freescale Fman Ethernet controller option to
Kconfig. Also migrate the CONFIG_SYS_QE_FMAN_FW_IN_xxx macros and
rename the SPIFLASH one to follow the same format as all of the others.
To do this fully we need to migrate CONFIG_QC, do so.
Migrate the CONFIG_LCRR_* settings to Kconfig.
Signed-off-by: Mario Six <mario.six@gdsys.cc>
Migrate the arbiter configuration to Kconfig.
Mirate the HID configuration settings to Kconfig.
Migrate the BR/OR settings to Kconfig. These must be known at compile
time, so cannot be configured via DT.
Configuration of this crucial variable should still be somewhat
comfortable. Hence, make its fields configurable in Kconfig, and
assemble the final value from these.
The LBLAW_* values determine the window configuration of the memory
controller. Hence, they must be known at compile time, and cannot be
implemented in the DT mechanism.
The BATs (block address translation registers) determine the initial
memory window mappings. Hence, they must be known at compile time and
cannot be implemented in the DT mechanism.
Migrate the CONFIG_HIGH_BATS variable to Kconfig.
The HRCW (hardware reset configuration word) is a constant that must be
hard-coded into the boot loader image. So, it must be available at
compile time, and cannot be migrated to the DT mechanism, but has to be
kept in Kconfig.
MPC83xx uses CONFIG_83XX_CLKIN instead of CONFIG_SYS_CLK_FREQ to set the
system clock. To migrate the architecture, we can replace
CONFIG_83XX_CLKIN with CONFIG_SYS_CLK_FREQ.
To do this
* replace all occurrences of CONFIG_83XX_CLKIN with CONFIG_SYS_CLK_FREQ
* set CONFIG_SYS_CLK_FREQ to the old value of CONFIG_83XX_CLKIN in all
MPC83xx config files
The kmtegr1, kmvect1, and suvd3 boards all use the same config include
file with lots of #ifdefs in it.
The Kconfig migation will become easier if we get rid of these #ifdefs
first.
Hence, create distinct config include files for these boards, and unwind
the #ifdef logic in these config files to only include the options
necessary for each board.
Now that CMD_UBI does not select CMD_MTDPARTS we need to make platforms
that had been enabling it turn it on by hand. This exposed that we had
not yet migrated CMD_MTDPARTS fully, so do so now.
Fixes: 86dfa556d927 ("cmd: ubi: Remove useless call to mtdparts_init()")
CONFIG_FLASH_CFI_DRIVER
CONFIG_SYS_FLASH_USE_BUFFER_WRITE
CONFIG_FLASH_CFI_MTD
CONFIG_SYS_FLASH_PROTECTION
CONFIG_SYS_FLASH_CFI
[trini: Re-migrate]
CONFIG_MISC_INIT_R
[trini: Update the defaults logic slightly]
Migrate boards which set bootlimit in the environment to Kconfig.
We exclude gurnard_defconfig which includes a bootlimit=, but doesn't set
CONFIG_BOOTCOUNT_LIMIT, so we'd fail to include a bootlimit setting
if we migrated it.
display5_defconfig and display5_factory_defconfig share a SYS_CONFIG_NAME,
but only display5_defconfig enables CONFIG_BOOTCOUNT_LIMIT, so we fail to
set bootlimit= in display5_factory_defconfig. This is okay because the
display5_factory_defconfig doesn't need to have it set, as it is only
meant to prepare the board in the factory.
Environment changes for all modified configs as seen from buildman:
boards.cfg is up to date. Nothing to do.
Summary of 3 commits for 32 boards (8 threads, 1 job per thread)
01: Merge git://git.denx.de/u-boot-x86
arm: + draco etamin rastaban pxm2 display5 thuban rut
02: Add BOOTCOUNT_BOOTLIMIT to set reboot limit
03: Migrate bootlimit to Kconfig
- display5_factory: bootlimit=3
Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
Reviewed-by: Lukasz Majewski <lukma@denx.de>
Migrate the CONFIG_LAST_STAGE_INIT option to Kconfig.
Migrate the CONFIG_BOARD_EARLY_INIT_R option to Kconfig.
Migrate the users of CONFIG_SYS_BOOTCOUNT_ADDR to Kconfig. We can
provide a default for BOOTCOUNT_AM33XX as that's a specific part of the
RTC in use. We can also provide a default for ARCH_LS1043A and
ARCH_LS1021A as they had been previously calculated and their symbols
are in Kconfig. In the case of other QE-enabled platforms, they are not
so we must update the relevant defconfig files. The previous default
only applied in some cases, even on a specific SoC family.
Reviewed-by: Alex Kiernan <alex.kiernan@gmail.com>
CONFIG_BOOTP_BOOTPATH
CONFIG_BOOTP_DNS
CONFIG_BOOTP_GATEWAY
CONFIG_BOOTP_HOSTNAME
CONFIG_BOOTP_PXE
CONFIG_BOOTP_SUBNETMASK
CONFIG_CMDLINE_EDITING
CONFIG_AUTO_COMPLETE
CONFIG_SYS_LONGHELP
CONFIG_SUPPORT_RAW_INITRD
CONFIG_ENV_VARS_UBOOT_CONFIG
[trini: Re-run the migration]
Signed-off-by: Lukasz Majewski <lukma@denx.de>
Tested-by: Alex Kiernan <alex.kiernan@gmail.com>
Reviewed-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
Acked-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
On the NIOS2 and Xtensa architectures, we do not have
CONFIG_SYS_TEXT_BASE set. This is a strict migration of the current
values into the defconfig and removing them from the headers.
I did not attempt to add more default values in and for now will leave
that to maintainers.
We move all instances of CONFIG_MTDIDS_DEFAULT and
CONFIG_MTDPARTS_DEFAULT from the header files to the defconfig files.
There's a few cases here where we need to expand upon what was in the
header file.
Tested-by: Adam Ford <aford173@gmail.com> #omap3_logic
Having this as a 'default y' is rather annoying because it doesn't
actually compile unless other options are defined in the board header:
../cmd/bootm.c: In function 'do_imls_nor':
../cmd/bootm.c:330:7: error: 'CONFIG_SYS_MAX_FLASH_BANKS' undeclared (first use in this function); did you mean 'CONFIG_SYS_MAX_FLASH_SECT'?
i < CONFIG_SYS_MAX_FLASH_BANKS; ++i, ++info) {
Make it 'default n' so people who develop new boards that start from a
blank defconfig have one less compilation failure to debug.
CONFIG_BCH
Migrate all remaining instances of CMD_NAND, CMD_NAND_TRIMFFS
CMD_NAND_LOCK_UNLOCK and CMD_NAND_TORTURE from the headers into the
defconfig files.
The above CONFIG options are in Kconfig, and now have correct depends and
inter-dependencies. Migrate these to configs/ from include/configs/. In the
case of CMD_UBIFS also change it to be a default y if CMD_UBI.
CONFIG_CMD_JFFS2
CONFIG_CMD_IMMAP
Also move this command out of the cmd/ directory since it is
PowerPC-specific.
CONFIG_CMD_EEPROM
CONFIG_CMD_EEPROM_LAYOUT
CONFIG_EEPROM_LAYOUT_HELP_STRING
[trini: Rework Kconfig logic slightly, define EEPROM location on TI eval
platforms]
CONFIG_CMD_DIAG
[trini: imply CMD_DIAG on some keymile configs]
We repeated partial moves for CONFIG_SYS_NO_FLASH, but this is
not completed. Finish this work by the tool.
During this move, let's rename it to CONFIG_MTD_NOR_FLASH.
Actually, we have more instances of "#ifndef CONFIG_SYS_NO_FLASH"
than those of "#ifdef CONFIG_SYS_NO_FLASH". Flipping the logic will
make the code more readable. Besides, negative meaning symbols do
not fit in obj-$(CONFIG_...) style Makefiles.
This commit was created as follows:
[1] Edit "default n" to "default y" in the config entry in
common/Kconfig.
[2] Run "tools/moveconfig.py -y -r HEAD SYS_NO_FLASH"
[3] Rename the instances in defconfigs by the following:
find . -path './configs/*_defconfig' | xargs sed -i \
-e '/CONFIG_SYS_NO_FLASH=y/d' \
-e 's/# CONFIG_SYS_NO_FLASH is not set/CONFIG_MTD_NOR_FLASH=y/'
[4] Change the conditionals by the following:
find . -name '*.[ch]' | xargs sed -i \
-e 's/ifndef CONFIG_SYS_NO_FLASH/ifdef CONFIG_MTD_NOR_FLASH/' \
-e 's/ifdef CONFIG_SYS_NO_FLASH/ifndef CONFIG_MTD_NOR_FLASH/' \
-e 's/!defined(CONFIG_SYS_NO_FLASH)/defined(CONFIG_MTD_NOR_FLASH)/' \
-e 's/defined(CONFIG_SYS_NO_FLASH)/!defined(CONFIG_MTD_NOR_FLASH)/'
[5] Modify the following manually
- Rename the rest of instances
- Remove the description from README
- Create the new Kconfig entry in drivers/mtd/Kconfig
- Remove the old Kconfig entry from common/Kconfig
- Remove the garbage comments from include/configs/*.h
Commit 7a777f6d6f35 ("mmc: Add generic Kconfig option") created
a Kconfig entry for this option without any actual moves, then
commit 44c798799f66 ("sunxi: Use Kconfig CONFIG_MMC") moved
instances only for SUNXI.
We generally do not like such partial moves. This kind of work
is automated by tools/moveconfig.py, so it is pretty easy to
complete this move.
I am adding "default ARM || PPC || SANDBOX" (suggested by Tom).
This shortens the configs and will ease new board porting.
[1] Edit Kconfig (remove the "depends on", add the "default",
copy the prompt and help message from Linux)
[2] Run 'tools/moveconfig.py -y -s -r HEAD MMC'
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
Add 'PCI' as a menu option and migrate all existing users.
move the UBI config options into Kconfig.
Reviewed-by: Andrew F. Davis <afd@ti.com>
Reviewed by: Evgeni Dobrev <evgeni at studio-punkt.com>
