path: root/configs/kmtegr1_defconfig
2015-11-18powerpc/83xx: add support for kmtegr1 boardValentin Longchamp
This board uses the same CPU (8309) as VECT1. The memory however is different since it has NAND Flash, the NOR Flash partitioning is different and of course the FPGAs as well. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Signed-off-by: Christoph Dietrich <christoph.dietrich@keymile.com>
