- Make all users of CUSTOM_SYS_INIT_SP_ADDR reference SYS_INIT_SP_ADDR
- Introduce HAS_CUSTOM_SYS_INIT_SP_ADDR to allow for setting the stack
pointer directly, otherwise we use the common calculation.
- On some platforms that were using the standard calculation but did not
set CONFIG_SYS_INIT_RAM_SIZE / CONFIG_SYS_INIT_RAM_ADDR, set them.
- On a small number of platforms that were not subtracting
GENERATED_GBL_DATA_SIZE do so now via the standard calculation.
- CONFIG_SYS_INIT_SP_OFFSET is now widely unused, so remove it from most
board config header files.
CONFIG_SYS_MAXARGS
Apple SoCs have an integrated NVMe controller that isn't connected
over a PCIe bus. In preparation for adding support for this NVMe
controller, split out the PCI support into its own file. This file
is selected through a new CONFIG_NVME_PCI Kconfig option, so do
a wholesale replacement of CONFIG_NVME with CONFIG_NVME_PCI.
Signed-off-by: Mark Kettenis <kettenis@openbsd.org>
Tested on: Macbook Air M1
CONFIG_REMAKE_ELF
Signed-off-by: Alper Nebi Yasak <alpernebiyasak@gmail.com>
The Khadas vim3 and vim3l defconfigs introduced with:
* f89b90d2d9 ("configs: add khadas-vim3{l}_android for AOSP support")
* 425f06f86e ("configs: prepare khadas-vim3{l}_ab_android for AOSP support")
were based on an outdated defconfig prior to the ede1f4f297 ("configs:
amlogic: Disable CONFIG_NET_RANDOM_ETHADDR when unnecessary") cleanup.
Disable CONFIG_NET_RANDOM_ETHADDR for the android configs as well to
stay consistent.
Signed-off-by: Mattijs Korpershoek <mkorpershoek@baylibre.com>
Link: https://lore.kernel.org/r/20220112084023.2858375-1-mkorpershoek@baylibre.com
Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
meson64_android.h also relies on CMD_AB_SELECT so enable that as well.
Signed-off-by: Guillaume La Roque <glaroque@baylibre.com>
Link: https://lore.kernel.org/r/20211122152207.219023-5-mkorpershoek@baylibre.com
In AOSP, both VIM3 and VIM3L have 2 bootloader flavors,
depending on A/B enablement.
For example, for vim3l, the naming is:
- u-boot_kvim3l_noab.bin : legacy support
- u-boot_kvim3l_ab.bin : A/B support
Prepare a defconfig to support u-boot_kvim3_ab.bin and
u-boot_kvim3l_ab.bin.
This is identical to khadas-vim3{l}_ab_android but will be updated in
the next commit.
Also update partitioning tables for A/B support.
Link: https://lore.kernel.org/r/20211122152207.219023-4-mkorpershoek@baylibre.com
