With CONFIG_DM_USB_GADGET=y, we no longer need any board_usb_*() logic
because:
* the dwc2 driver is DM compatible, and handles its own clock enabling
* the dwc3-meson-g12a glue drivers handles "force mode switching"
Remove all mach-meson/g12a usb code and enable CONFIG_DM_USB_GADGET.
Note: Only configs having both CONFIG_USB_DWC3_MESON_G12A=y *and*
USB_GADGET_DWC2_OTG=y have been updated.
Signed-off-by: Mattijs Korpershoek <mkorpershoek@baylibre.com>
Link: https://lore.kernel.org/r/20221024-meson-dm-usb-v1-2-2ab077a503b9@baylibre.com
Signed-off-by: Neil Armstrong <neil.armstrong@linaro.org>
The current name is inconsistent with SPL which uses CONFIG_SPL_TEXT_BASE
and this makes it imposible to use CONFIG_VAL().
Rename it to resolve this problem.
Now that all the old code is gone, rename this option. Driver model
migration is now complete.
- Make all users of CUSTOM_SYS_INIT_SP_ADDR reference SYS_INIT_SP_ADDR
- Introduce HAS_CUSTOM_SYS_INIT_SP_ADDR to allow for setting the stack
pointer directly, otherwise we use the common calculation.
- On some platforms that were using the standard calculation but did not
set CONFIG_SYS_INIT_RAM_SIZE / CONFIG_SYS_INIT_RAM_ADDR, set them.
- On a small number of platforms that were not subtracting
GENERATED_GBL_DATA_SIZE do so now via the standard calculation.
- CONFIG_SYS_INIT_SP_OFFSET is now widely unused, so remove it from most
board config header files.
CONFIG_SYS_MAXARGS
Apple SoCs have an integrated NVMe controller that isn't connected
over a PCIe bus. In preparation for adding support for this NVMe
controller, split out the PCI support into its own file. This file
is selected through a new CONFIG_NVME_PCI Kconfig option, so do
a wholesale replacement of CONFIG_NVME with CONFIG_NVME_PCI.
Signed-off-by: Mark Kettenis <kettenis@openbsd.org>
Tested on: Macbook Air M1
CONFIG_REMAKE_ELF
Signed-off-by: Alper Nebi Yasak <alpernebiyasak@gmail.com>
On Meson GXL, GXM, AXG, G12A, G12B & SM1 SoCs, we can generate an unique
MAC address if none valid found in the eFuses storage.
Only the GXBB based boards doesn't have a fallback way to generate an
unique MAC address, so we rely on CONFIG_NET_RANDOM_ETHADDR to have
a valid one.
An exception is the Radxa Zero board who doesn't have Ethernet on board
so depends on an (or multiple) eventual USB adapters, so leaving the
CONFIG_NET_RANDOM_ETHADDR configs seems safer.
Suggested-by: Tom Rini <trini@konsulko.com>
Reviewed-by: Vyacheslav Bocharov <adeep@lexina.in>
Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
Link: https://lore.kernel.org/r/20211122110710.1038893-1-narmstrong@baylibre.com
Now that we have consistent usage, migrate this symbol to Kconfig.
Reviewed-by: Rick Chen <rick@andestech.com>
https://source.denx.de/u-boot/custodians/u-boot-amlogic
- Add SMBIOS info for Khadas VIM boards
- Fix meson-axg-mipi PHY build
- Fix VIM3 board phy-names property setup
- Return correct value for non emmc boot sources on VIM3
- add kernel compression vars
Enable configs to support SMBIOS for all Khadas VIM boards
Reviewed-by: Neil Armstrong <narmstrong@baylibre.com>
Signed-off-by: Artem Lapkin <art@khadas.com>
Now we have PCIe, let's also enable NVMe to access an eventual NVMe SSDs
connected on the M.2 slot.
Use the proper Synopsys DWMAC Meson8b glue to handle the ethernet link type.
Use DM_MDIO and the new G12A MDIO MUX driver for G12A, G12B & SM1 boards.
Add options required to check the 'Function' button state.
Analog to Digital Converter device (Meson SARADC) will be used for
probing 'Function' button state.
[narmstrong: also updated khadas-vim3l_defconfig]
Done with:
./tools/moveconfig.py BMP_16BPP BMP_24BPP BMP_32BPP
Done with:
./tools/moveconfig.py VIDEO_BMP_RLE8
The VIM3 on-board MCU can mux the PCIe/USB3.0 shared differential
lines using a FUSB340TMX USB 3.1 SuperSpeed Data Switch between
an USB3.0 Type A connector and a M.2 Key M slot.
The PHY driving these differential lines is shared between
the USB3.0 controller and the PCIe Controller, thus only
a single controller can use it.
This adds this dynamic switching right before booting Linux
and the configuration steps in the boards documentation.
Reviewed-by: Kevin Hilman <khilman@baylibre.com>
Tested-by: Kevin Hilman <khilman@baylibre.com>
[narmstrong: fixed warning by replacing min() by min_t()]
Use the newly added VIM3 board support instead of the generic W400.
CONFIG_SPLASH_SCREEN
CONFIG_SPLASH_SCREEN_ALIGN
CONFIG_SPLASHIMAGE_GUARD
CONFIG_SPLASH_SOURCE
Enable options to permit HDMI output on Khadas VIM3 & VIM3L boards.
Enable the necessary configs to make usage of the SPI NOR Flash.
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
Those platform use the DWC2 controller for the gadget support and the
DWC3 for host-only operations.
Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
Derived from odroid-n2_defconfig and README.odroid-n2.
Signed-off-by: Andreas Färber <afaerber@suse.de>
