path: root/configs/kc1_defconfig
2016-11-18spl: Convert CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR to KconfigSemen Protsenko
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> [trini: Fix sniper and kc1 migration] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-09-20configs: Re-syncTom Rini
2016-04-20usb: gadget Move: CONFIG_G_DNL_* to KconfigSam Protsenko
And also reformat defconfigs using "make savedefconfig" rule. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-20usb: gadget: Move CONFIG_USB_GADGET_DOWNLOAD to KconfigSam Protsenko
While at it, remove obsolete CONFIG_USBDOWNLOAD_GADGET option from some config headers. This is also probably fixes am335x_baltos board. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-01kc1: Select libfdt to allow running devicetree-based kernelsPaul Kocialkowski
Selecting CONFIG_OF_LIBFDT allows running recent mainline kernels. Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
2016-03-25usb: gadget: Move CONFIG_USB_GADGET to KconfigSam Protsenko
The description was borrowed from kernel. "tristate" type was changed to "bool" (I believe we don't support modules for u-boot yet, right?). CONFIG_USB_GADGET requires CONFIG_USB to be defined too, so add it along as well. Definitions were added to defconfig files in a way that "make savedefconfig" generates exactly the same file as used defconfig. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> [trini: Add zynq_zc702 conversion] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-03-15kc1: MUSB USB controller and fastboot USB gadget supportPaul Kocialkowski
This adds support for the MUSB USB dual-role controller in peripheral mode, with configuration options for the fastboot USB gadget. At this point, flashing the internal eMMC is support. Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
2016-03-15Amazon Kindle Fire (first generation) codename kc1 supportPaul Kocialkowski
The Amazon Kindle Fire (first generation) codename kc1 is a tablet that was released by Amazon back in 2011. It is using an OMAP4430 SoC GP version, which allows running U-Boot and the U-Boot SPL from the ground up. Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
