path: root/configs/k2l_evm_defconfig
2015-10-22ARM: dts: k2l: Enable OF_CONTROL and DMLokesh Vutla
Import k2l specific DT files from Linux Kernel and enable OF_CONTROL, DM, DM_SERIAL. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2014-10-23keystone2: k2l-evm: add board supportHao Zhang
This patch adds Keystone II Lammar (K2L) EVM board support. Acked-by: Vitaly Andrianov <vitalya@ti.com> Signed-off-by: Hao Zhang <hzhang@ti.com> Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
