path: root/configs/k2l_evm_defconfig
2018-02-23configs: Re-sync with CONFIG_DISTRO_DEFAULTSTom Rini
A number of platforms include config_distro_defaults.h but do not enable CONFIG_DISTRO_DEFAULTS. As they plainly intended to, set that flag and re-sync config files. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-01-22Convert CONFIG_DAVINCI_SPI to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_DAVINCI_SPI Signed-off-by: Adam Ford <aford173@gmail.com>
2017-10-16configs: Resync with savedefconfigTom Rini
2017-10-05dts: renamed FIT_EMBED to MULTI_DTB_FIT and moved it to the dts KconfigJean-Jacques Hiblot
CONFIG_FIT_EMBED might be confused with CONFIG_OF_EMBED, rename it MULTI_DTB_FIT as it is able to get a DTB from a FIT image containing multiple DTBs. Also move the option to the Kconfig dedicated to the DTS options and create a README for this feature. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-07-25configs: Resync with savedefconfigTom Rini
2017-07-10defconfig: keystone2: Enable U-boot runtime DTB detectionCooper Jr., Franklin
Enable various config options to allow U-boot at runtime to select the proper dtb to use from the list of dtb's within the FIT image. Signed-off-by: Franklin S Cooper Jr <fcooper@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-05-08configs: ks2: Enable TI_COMMON_CMD_OPTIONSLokesh Vutla
Enable TI_COMMON_CMD_OPTIONS on all keystone2 platforms. Also sync with savedefconfig. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2017-04-27configs: keystone2: Standardise U-boot promptLokesh Vutla
Standardise U-Boot prompt on all keystone2 platforms instead of platform specific prompt. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-04-08Kconfig: Adds SYS_TEXT_BASE config option for Keystone2Madan Srinivas
This patch makes SYS_TEXT_BASE a config option for Keystone2 so that it can be used to load u-boot at different addresses on secure and non-secure Keystone2 devices. Signed-off-by: Madan Srinivas <madans@ti.com> Signed-off-by: Andrew F. Davis <afd@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
2017-02-08ARM: dts: k2*: Rename the k2* files to keystone-k2* filesLokesh Vutla
As reported in [1], rename the k2* dts files to keystone-* files this will force consistency throughout. Script for the same (and hand modified for Makefile and config files): for i in arch/arm/dts/k2* do b=`basename $i`; git mv $i arch/arm/dts/keystone-$b; sed -i -e "s/$b/keystone-$b/g" arch/arm/dts/*[si] done This is similar to linux kernel commit 5edafc29829bc ("ARM: dts: k2*: Rename the k2* files to keystone-k2* files") [1] http://marc.info/?l=linux-arm-kernel&m=145637407804754&w=2 Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-09-26kconfig: introduce kconfig for UBIHeiko Schocher
move the UBI config options into Kconfig. Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Andrew F. Davis <afd@ti.com> Reviewed by: Evgeni Dobrev <evgeni at studio-punkt.com>
2016-09-16Convert CONFIG_SPL_POWER_SUPPORT to KconfigSimon Glass
2016-08-08configs: k2l_evm: add random eth address supportMugunthan V N
There is only one ethernet mac address in e-fuse, but there are multiple slaves in keystone net, so enable random mac address support. Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-07-09defconfig: k2l_evm_defconfig: enable SPI driver modelVignesh R
Enable SPI and SPI Flash driver model as K2L SPI controller driver supports driver model. Signed-off-by: Vignesh R <vigneshr@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Jagan Teki <jteki@openedev.com>
2016-06-04usb: move CONFIG_USB_XHCI_DWC3 to KconfigMasahiro Yamada
Create an entry for "config USB_XHCI_DWC3" in Kconfig and switch over to it for all boards. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-06-04usb: move CONFIG_USB_XHCI to Kconfig with renamingMasahiro Yamada
Move CONFIG_USB_XHCI to defconfig files for all boards, renaming it into CONFIG_USB_XHCI_HCD. As commented in the help of "config USB_XHCI" entry, this has been a TODO for a long time; now CONFIG_USB_XHCI_HCD and CONFIG_USB_XHCI have been unified in favor of the former. Note: Some boards define CONFIG_USB_XHCI in their headers without CONFIG_USB, which does not meet the "depends on" in Kconfig. I added CONFIG_USB=y for those boards when converting. Otherwise, they would fail to build. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-04-18configs: ks2: move CMD_NAND to defconfigsLokesh Vutla
NAND is not yet enabled on all Keystone2 platforms. So enabled CMD_NAND in the respective defconfigs only if available. Reported-by: Nishanth Menon <nm@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-04-18memory: Move TI_AEMIF config to KCONFIGLokesh Vutla
Not all Keystone2 devices has AEMIF NAND controller. So adding Kconfig entry for CONFIG_TI_AEMIF and enabling it in respective defconfigs on platforms with AEMIF controller. Reported-by: Nishanth Menon <nm@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-03-22defconfig: Reorder boards' defconfig filesBin Meng
Some boards' defconfig files are out of order. Clean this up. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-02-08defconfig: k2l_evm_defconfig: enable net driver modelMugunthan V N
enable net driver model for k2l evm as keystone_net supports driver model Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
