path: root/configs/k2l_evm_defconfig
2019-01-07configs: Resync with savedefconfigTom Rini
2018-12-14usb: host: replace xhci-keystone driver by the generic dwc3 driverJean-Jacques Hiblot
The keystone platforms can use the generic DC3 driver. Removing the keystone-spcecific xchi driver and add the configuration options to enable the generic DWC3 driver on all K2 platforms. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-11-05configs: net: convert DRIVER_TI_KEYSTONE_NET kconfigGrygorii Strashko
Convert DRIVER_TI_KEYSTONE_NET to Kconfig. Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com>
2018-08-17Convert CONFIG_SYS_I2C_DAVINCI to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_SYS_I2C_DAVINCI Signed-off-by: Adam Ford <aford173@gmail.com>
2018-07-21Convert CONFIG_NAND_DAVINCI to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_NAND_DAVINCI Signed-off-by: Adam Ford <aford173@gmail.com>
2018-04-11spl: spi: Move CONFIG_SPL_SPI_LOAD to KconfigMarek Vasut
Add Kconfig entry for CONFIG_SPL_SPI_LOAD symbol and move all configurations using it to Kconfig. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Tom Rini <trini@konsulko.com>
2018-02-23configs: Re-sync with CONFIG_DISTRO_DEFAULTSTom Rini
A number of platforms include config_distro_defaults.h but do not enable CONFIG_DISTRO_DEFAULTS. As they plainly intended to, set that flag and re-sync config files. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-01-22Convert CONFIG_DAVINCI_SPI to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_DAVINCI_SPI Signed-off-by: Adam Ford <aford173@gmail.com>
2017-10-16configs: Resync with savedefconfigTom Rini
2017-10-05dts: renamed FIT_EMBED to MULTI_DTB_FIT and moved it to the dts KconfigJean-Jacques Hiblot
CONFIG_FIT_EMBED might be confused with CONFIG_OF_EMBED, rename it MULTI_DTB_FIT as it is able to get a DTB from a FIT image containing multiple DTBs. Also move the option to the Kconfig dedicated to the DTS options and create a README for this feature. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-07-25configs: Resync with savedefconfigTom Rini
2017-07-10defconfig: keystone2: Enable U-boot runtime DTB detectionCooper Jr., Franklin
Enable various config options to allow U-boot at runtime to select the proper dtb to use from the list of dtb's within the FIT image. Signed-off-by: Franklin S Cooper Jr <fcooper@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-05-08configs: ks2: Enable TI_COMMON_CMD_OPTIONSLokesh Vutla
Enable TI_COMMON_CMD_OPTIONS on all keystone2 platforms. Also sync with savedefconfig. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2017-04-27configs: keystone2: Standardise U-boot promptLokesh Vutla
Standardise U-Boot prompt on all keystone2 platforms instead of platform specific prompt. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-04-08Kconfig: Adds SYS_TEXT_BASE config option for Keystone2Madan Srinivas
This patch makes SYS_TEXT_BASE a config option for Keystone2 so that it can be used to load u-boot at different addresses on secure and non-secure Keystone2 devices. Signed-off-by: Madan Srinivas <madans@ti.com> Signed-off-by: Andrew F. Davis <afd@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
2017-02-08ARM: dts: k2*: Rename the k2* files to keystone-k2* filesLokesh Vutla
As reported in [1], rename the k2* dts files to keystone-* files this will force consistency throughout. Script for the same (and hand modified for Makefile and config files): for i in arch/arm/dts/k2* do b=`basename $i`; git mv $i arch/arm/dts/keystone-$b; sed -i -e "s/$b/keystone-$b/g" arch/arm/dts/*[si] done This is similar to linux kernel commit 5edafc29829bc ("ARM: dts: k2*: Rename the k2* files to keystone-k2* files") [1] http://marc.info/?l=linux-arm-kernel&m=145637407804754&w=2 Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-09-26kconfig: introduce kconfig for UBIHeiko Schocher
move the UBI config options into Kconfig. Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Andrew F. Davis <afd@ti.com> Reviewed by: Evgeni Dobrev <evgeni at studio-punkt.com>
2016-09-16Convert CONFIG_SPL_POWER_SUPPORT to KconfigSimon Glass
