path: root/configs/k2hk_hs_evm_defconfig
2019-05-18CONFIG_SYS_[DI]CACHE_OFF: convert to KconfigTrevor Woerner
CONFIG_SYS_[DI]CACHE_OFF had been partially converted to Kconfig parameters; only for the ARC architecture. This patch turns these two parameters into Kconfig items everywhere else they are found. All of the include/configs/* and defconfig changes in this patch are for arm machines only. The Kconfig changes for arc, nds32, riscv, and xtensa have been included since these symbols are found in code under arch/{arc,nds32,riscv,xtensa}, however, no currently-defined include/configs/* or defconfigs for these architectures exist which include these symbols. These results have been confirmed with tools/moveconfig.py. Acked-by: Alexey Brodkin <abrodkin@snopsys.com> Signed-off-by: Trevor Woerner <trevor@toganlabs.com> [trini: Re-migrate for a few more boards] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-04-12ti: keystone2: Move CONFIG_ISW_ENTRY_ADDR to a common placeTom Rini
The ISW_ENTRY_ADDR Kconfig option under mach-omap2 isn't a SoC specific notion but rather "where is our previous stage loaded in memory?" option. Make use of this on ARCH_KEYSTONE rather than SPL_TEXT_BASE for our HS builds that are not using SPL anyhow. Cc: Vitaly Andrianov <vitalya@ti.com> Cc: Andrew F. Davis <afd@ti.com> Cc: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com?
2019-01-07configs: Resync with savedefconfigTom Rini
2018-12-14usb: host: replace xhci-keystone driver by the generic dwc3 driverJean-Jacques Hiblot
The keystone platforms can use the generic DC3 driver. Removing the keystone-spcecific xchi driver and add the configuration options to enable the generic DWC3 driver on all K2 platforms. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-11-05configs: net: convert DRIVER_TI_KEYSTONE_NET kconfigGrygorii Strashko
Convert DRIVER_TI_KEYSTONE_NET to Kconfig. Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com>
2018-08-17Convert CONFIG_SYS_I2C_DAVINCI to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_SYS_I2C_DAVINCI Signed-off-by: Adam Ford <aford173@gmail.com>
2018-07-21Convert CONFIG_NAND_DAVINCI to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_NAND_DAVINCI Signed-off-by: Adam Ford <aford173@gmail.com>
2018-04-06configs: k2hk_hs_evm: Resync defconfig with non-HS defconfigAndrew F. Davis
Signed-off-by: Andrew F. Davis <afd@ti.com> Reviewed-by: Lokesh vutla <lokeshvutla@ti.com>
2018-02-23defconfig: k2x_hs_evm: Re-enable TI_SECURE_DEVICE in HS K2x partsAndrew F. Davis
These got removed in config re-syncs due to a Kconfig bug. Add these back here. Signed-off-by: Andrew F. Davis <afd@ti.com> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
2018-02-23configs: Re-sync with CONFIG_DISTRO_DEFAULTSTom Rini
A number of platforms include config_distro_defaults.h but do not enable CONFIG_DISTRO_DEFAULTS. As they plainly intended to, set that flag and re-sync config files. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-01-22Convert CONFIG_DAVINCI_SPI to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_DAVINCI_SPI Signed-off-by: Adam Ford <aford173@gmail.com>
2017-05-08configs: ks2: Enable TI_COMMON_CMD_OPTIONSLokesh Vutla
Enable TI_COMMON_CMD_OPTIONS on all keystone2 platforms. Also sync with savedefconfig. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2017-04-27Kconfig: Enable FIT support by default for TI platformsAndrew F. Davis
Almost all TI defconfigs enable this already, add this as a default and remove the explicit assignment. Signed-off-by: Andrew F. Davis <afd@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-04-27configs: keystone2: Standardise U-boot promptLokesh Vutla
Standardise U-Boot prompt on all keystone2 platforms instead of platform specific prompt. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-04-08defconfig: k2hk_hs_evm: Add k2hk_hs_evm_defconfigAndrew F. Davis
TI K2HK secure devices have to be built with TI_SECURE_DEVICE, FIT, and FIT_IMAGE_POST_PROCESS enabled. Add a dedicated defconfig for this. Signed-off-by: Andrew F. Davis <afd@ti.com>
