path: root/configs/k2hk_hs_evm_defconfig
2017-05-08configs: ks2: Enable TI_COMMON_CMD_OPTIONSLokesh Vutla
Enable TI_COMMON_CMD_OPTIONS on all keystone2 platforms. Also sync with savedefconfig. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2017-04-27Kconfig: Enable FIT support by default for TI platformsAndrew F. Davis
Almost all TI defconfigs enable this already, add this as a default and remove the explicit assignment. Signed-off-by: Andrew F. Davis <afd@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-04-27configs: keystone2: Standardise U-boot promptLokesh Vutla
Standardise U-Boot prompt on all keystone2 platforms instead of platform specific prompt. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-04-08defconfig: k2hk_hs_evm: Add k2hk_hs_evm_defconfigAndrew F. Davis
TI K2HK secure devices have to be built with TI_SECURE_DEVICE, FIT, and FIT_IMAGE_POST_PROCESS enabled. Add a dedicated defconfig for this. Signed-off-by: Andrew F. Davis <afd@ti.com>
