path: root/configs/k2hk_hs_evm_defconfig
2019-04-12ti: keystone2: Move CONFIG_ISW_ENTRY_ADDR to a common placeTom Rini
The ISW_ENTRY_ADDR Kconfig option under mach-omap2 isn't a SoC specific notion but rather "where is our previous stage loaded in memory?" option. Make use of this on ARCH_KEYSTONE rather than SPL_TEXT_BASE for our HS builds that are not using SPL anyhow. Cc: Vitaly Andrianov <vitalya@ti.com> Cc: Andrew F. Davis <afd@ti.com> Cc: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com?
2019-01-07configs: Resync with savedefconfigTom Rini
2018-12-14usb: host: replace xhci-keystone driver by the generic dwc3 driverJean-Jacques Hiblot
The keystone platforms can use the generic DC3 driver. Removing the keystone-spcecific xchi driver and add the configuration options to enable the generic DWC3 driver on all K2 platforms. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-11-05configs: net: convert DRIVER_TI_KEYSTONE_NET kconfigGrygorii Strashko
Convert DRIVER_TI_KEYSTONE_NET to Kconfig. Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com>
2018-08-17Convert CONFIG_SYS_I2C_DAVINCI to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_SYS_I2C_DAVINCI Signed-off-by: Adam Ford <aford173@gmail.com>
2018-07-21Convert CONFIG_NAND_DAVINCI to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_NAND_DAVINCI Signed-off-by: Adam Ford <aford173@gmail.com>
2018-04-06configs: k2hk_hs_evm: Resync defconfig with non-HS defconfigAndrew F. Davis
Signed-off-by: Andrew F. Davis <afd@ti.com> Reviewed-by: Lokesh vutla <lokeshvutla@ti.com>
2018-02-23defconfig: k2x_hs_evm: Re-enable TI_SECURE_DEVICE in HS K2x partsAndrew F. Davis
These got removed in config re-syncs due to a Kconfig bug. Add these back here. Signed-off-by: Andrew F. Davis <afd@ti.com> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
2018-02-23configs: Re-sync with CONFIG_DISTRO_DEFAULTSTom Rini
A number of platforms include config_distro_defaults.h but do not enable CONFIG_DISTRO_DEFAULTS. As they plainly intended to, set that flag and re-sync config files. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-01-22Convert CONFIG_DAVINCI_SPI to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_DAVINCI_SPI Signed-off-by: Adam Ford <aford173@gmail.com>
2017-05-08configs: ks2: Enable TI_COMMON_CMD_OPTIONSLokesh Vutla
Enable TI_COMMON_CMD_OPTIONS on all keystone2 platforms. Also sync with savedefconfig. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2017-04-27Kconfig: Enable FIT support by default for TI platformsAndrew F. Davis
Almost all TI defconfigs enable this already, add this as a default and remove the explicit assignment. Signed-off-by: Andrew F. Davis <afd@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-04-27configs: keystone2: Standardise U-boot promptLokesh Vutla
Standardise U-Boot prompt on all keystone2 platforms instead of platform specific prompt. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-04-08defconfig: k2hk_hs_evm: Add k2hk_hs_evm_defconfigAndrew F. Davis
TI K2HK secure devices have to be built with TI_SECURE_DEVICE, FIT, and FIT_IMAGE_POST_PROCESS enabled. Add a dedicated defconfig for this. Signed-off-by: Andrew F. Davis <afd@ti.com>
