path: root/configs/k2hk_evm_defconfig
2016-02-08defconfig: k2hk_evm_defconfig: enable net driver modelMugunthan V N
enable net driver model for k2hk evm as keystone_net supports driver model Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-10-22ARM: dts: k2hk: Enable OF_CONTROL and DMLokesh Vutla
Import k2hk specific DT files from Linux Kernel and enable OF_CONTROL, DM, DM_SERIAL. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2014-10-10configs:ks2_evm: update defconfigs to support SPLMurali Karicheri
The K2HK and K2E boards support SPL by default, so add CONFIG_SPL option. Also export CONFIG_ARM, CONFIG_ARCH_KEYSTONE and TARGET_K2*_EVM options to spl/.config as they are the same. So now it's convinient to build gph images using only two commands: make k2hk_evm_defconfig make u-boot-spi.gph Acked-By: Murali Karicheri <m-karicheri2@ti.com> Signed-off-by: Murali Karicheri <m-karicheri2@ti.com> Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
2014-08-30keystone: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the Keystone board select menu to keystone/Kconfig. Move also common settings (CONFIG_SYS_CPU="armv7" and CONFIG_SYS_SOC="keystone"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Tom Rini <trini@ti.com> Cc: Vitaly Andrianov <vitalya@ti.com>
