CONFIG_KSNET_NETCP_V1_0
CONFIG_KSNET_NETCP_V1_5
CONFIG_SPL_NS16550_MIN_FUNCTIONS
CONFIG_SYS_NS16550_MEM32
CONFIG_SYS_NS16550_PORT_MAPPED
CONFIG_SYS_NS16550_REG_SIZE
CONFIG_SYS_NS16550_SERIAL
To do this we also introduce CONFIG_SPL_SYS_NS16550_SERIAL so that
platforms can enable the legacy driver here for SPL.
CONFIG_SYS_NAND_NO_SUBPAGE_WRITE
CONFIG_SYS_NAND_HW_ECC
CONFIG_SYS_NAND_4BIT_HW_ECC_OOBFIRST
The current name is inconsistent with SPL which uses CONFIG_SPL_TEXT_BASE
and this makes it imposible to use CONFIG_VAL().
Rename it to resolve this problem.
Resync all defconfig files using moveconfig.py
The ISW_ENTRY_ADDR symbol was used for OMAP devices in place of
SPL_TEXT_BASE. Keystone2 HS devices were not using it right either.
Remove ISW_ENTRY_ADDR and use SPL_TEXT_BASE directly.
Signed-off-by: Andrew Davis <afd@ti.com>
CONFIG_SPL_TARGET
CONFIG_SYS_SPL_MALLOC_SIZE
CONFIG_SYS_SPL_MALLOC_START
We introduce a default value here as well, and CONFIG_SYS_SPL_MALLOC to
control if we have a malloc pool or not.
CONFIG_SPL_BSS_START_ADDR
CONFIG_SPL_STACK
- Make all users of CUSTOM_SYS_INIT_SP_ADDR reference SYS_INIT_SP_ADDR
- Introduce HAS_CUSTOM_SYS_INIT_SP_ADDR to allow for setting the stack
pointer directly, otherwise we use the common calculation.
- On some platforms that were using the standard calculation but did not
set CONFIG_SYS_INIT_RAM_SIZE / CONFIG_SYS_INIT_RAM_ADDR, set them.
- On a small number of platforms that were not subtracting
GENERATED_GBL_DATA_SIZE do so now via the standard calculation.
- CONFIG_SYS_INIT_SP_OFFSET is now widely unused, so remove it from most
board config header files.
CONFIG_SPL_BSS_MAX_SIZE
CONFIG_SPL_MAX_FOOTPRINT
Note that the da850evm platforms were violating the "only use one" rule
here, and so now hard-code their BSS limit.
CONFIG_SPL_PAD_TO
CONFIG_SPL_MAX_SIZE
CONFIG_TPL_PAD_TO
CONFIG_TPL_MAX_SIZE
Note that we need to make TPL_MAX_SIZE be hex, and so move and convert the
existing places.
CONFIG_SYS_MAXARGS
The most commonly used value today is 0x2000 and not 0x400. Rework the
Kconfig logic to use this more frequently used value as the default.
Cc: Andrew F. Davis <afd@ti.com>
Cc: Alex Nemirovsky <alex.nemirovsky@cortina-access.com>
Cc: Alexey Brodkin <abrodkin@synopsys.com>
Cc: Alison Wang <alison.wang@nxp.com>
Cc: Anastasiia Lukianenko <anastasiia_lukianenko@epam.com>
Cc: Andes <uboot@andestech.com>
Cc: Andre Przywara <andre.przywara@arm.com>
Cc: Bharat Gooty <bharat.gooty@broadcom.com>
Cc: David Lechner <david@lechnology.com>
Cc: Dzmitry Sankouski <dsankouski@gmail.com>
Cc: Enric Balletbo i Serra <eballetbo@gmail.com>
Cc: Eugeniy Paltsev <paltsev@synopsys.com>
Cc: Fabio Estevam <festevam@gmail.com>
Cc: Gerald Kerma <dreagle@doukki.net>
Cc: Gregory CLEMENT <gregory.clement@bootlin.com>
Cc: Holger Brunck <holger.brunck@hitachienergy.com>
Cc: Jaehoon Chung <jh80.chung@samsung.com>
Cc: Jassi Brar <jaswinder.singh@linaro.org>
Cc: Kristian Amlie <kristian.amlie@northern.tech>
Cc: Krzysztof Kozlowski <krzk@kernel.org>
Cc: Liviu Dudau <liviu.dudau@foss.arm.com>
Cc: Luka Perkov <luka.perkov@sartura.hr>
Cc: Lukasz Majewski <lukma@denx.de>
Cc: Masami Hiramatsu <masami.hiramatsu@linaro.org>
Cc: Matthias Brugger <mbrugger@suse.com>
Cc: Max Filippov <jcmvbkbc@gmail.com>
Cc: Michael Walle <michael@walle.cc>
Cc: Michal Simek <michal.simek@xilinx.com>
Cc: Nikita Kiryanov <nikita@compulab.co.il>
Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
Cc: Oleksandr Andrushchenko <oleksandr_andrushchenko@epam.com>
Cc: Otavio Salvador <otavio@ossystems.com.br>
Cc: Patrice Chotard <patrice.chotard@foss.st.com>
Cc: Paul Burton <paul.burton@mips.com>
Cc: Paul Kocialkowski <contact@paulk.fr>
Cc: Priyanka Jain <priyanka.jain@nxp.com>
Cc: Rajesh Bhagat <rajesh.bhagat@nxp.com>
Cc: Rayagonda Kokatanur <rayagonda.kokatanur@broadcom.com>
Cc: Sergey Temerkhanov <s.temerkhanov@gmail.com>
Cc: Stefan Bosch <stefan_b@posteo.net>
Cc: Stephan Gerhold <stephan@gerhold.net>
Cc: Tetsuyuki Kobayashi <koba@kmckk.co.jp>
Cc: Thomas Chou <thomas@wytron.com.tw>
Cc: Thomas Fitzsimmons <fitzsim@fitzsim.org>
Cc: Thomas Weber <weber@corscience.de>
Cc: Tony Dinh <mibodhi@gmail.com>
Cc: Trevor Woerner <twoerner@gmail.com>
Cc: Vitaly Andrianov <vitalya@ti.com>
Cc: Vladimir Zapolskiy <vz@mleia.com>
Cc: liuhao <liuhao@phytium.com.cn>
Cc: lixinde <lixinde@phytium.com.cn>
Cc: shuyiqi <shuyiqi@phytium.com.cn>
Cc: weichangzheng <weichangzheng@phytium.com.cn>
Reviewed-by: Thomas Chou <thomas@wytron.com.tw>
Reviewed-by: Masami Hiramatsu <masami.hiramatsu@linaro.org>
Reviewed-by: Tony Dinh <mibodhi@gmail.com>
Reviewed-by: Patrice Chotard <patrice.chotard@foss.st.com>
Reviewed-by: Kristian Amlie <kristian.amlie@northern.tech>
CONFIG_NET_RETRY_COUNT
Cc: Ramon Fried <rfried.dev@gmail.com>
CONFIG_TIMESTAMP
CONFIG_USE_BOOTCOMMAND
CONFIG_BOOTCOMMAND
CONFIG_RAMBOOTCOMMAND
CONFIG_NFSBOOTCOMMAND
CONFIG_TI_EDMA3
Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
Rename these options so that CONFIG_IS_ENABLED can be used with them.
CONFIG_SYS_MALLOC_LEN
Acked-by: Sean Anderson <seanga2@gmail.com>
Reviewed-by: Rick Chen <rick@andestech.com>
CONFIG_SKIP_LOWLEVEL_INIT
CONFIG_SKIP_LOWLEVEL_INIT_ONLY
In order to do this, we need to introduce SPL and TPL variants of these
options so that we can clearly disable these options only in SPL in some
cases, and both instances in other cases.
- Rename usages of CONFIG_SYS_DEF_EEPROM_ADDR to CONFIG_SYS_I2C_EEPROM_ADDR
based on current usage.
- Convert CONFIG_SYS_I2C_EEPROM_ADDR, CONFIG_SYS_I2C_EEPROM_ADDR_LEN,
CONFIG_SYS_I2C_EEPROM_BUS, CONFIG_CONFIG_SYS_EEPROM_SIZE
CONFIG_SYS_EEPROM_PAGE_WRITE_BITS and CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS
to Kconfig. We move these symbols around a bit and add appropriate
dependencies to them. In some cases, we now add a correct default value
as well.
Rename this option so that CONFIG_IS_ENABLED can be used with it.
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
As the deadline for migration to DM_USB, when using a USB host
controller has now gone two years past the deadline, enforce migration.
This is done by:
- Ensuring that all host controller options (other than the very legacy
old MUSB ones) now select USB_HOST. USB_HOST now enforces DM_USB and
OF_CONTROL.
- Remove other parts of Kconfig logic that had platforms pick DM_USB.
- To keep Kconfig happy, have some select statements test for USB_HOST
as well.
- Re-order some Kconfig entries and menus so that we can cleanly pick
host or gadget roles. For the various HCD options that have platform
glue options, group them together and update dependencies in some
cases.
- As SPL_DM_USB is not required, on platforms that had not yet enabled
it, disable it.
Cc: Icenowy Zheng <icenowy@aosc.io>
Cc: Samuel Holland <samuel@sholland.org>
Cc: FUKAUMI Naoki <naobsd@gmail.com>
Cc: Jagan Teki <jagan@amarulasolutions.com>
CONFIG_BOOTP_SEND_HOSTNAME
CONFIG_SPL_NAND_BASE
CONFIG_SPL_NAND_IDENT
CONFIG_SPL_NAND_DRIVERS
CONFIG_SPL_NAND_ECC
CONFIG_SPL_NAND_SIMPLE
CONFIG_ENV_OVERWRITE
[trini: Rerun migration, remove some comments]
This change allows more fine tuning of driver model based SPI support in
SPL and TPL. It is now possible to explicitly enable/disable the DM_SPI
support in SPL and TPL via Kconfig option.
Before this change it was necessary to use:
/* SPI Flash Configs */
#if defined(CONFIG_SPL_BUILD)
#undef CONFIG_DM_SPI
#undef CONFIG_DM_SPI_FLASH
#undef CONFIG_SPI_FLASH_MTD
#endif
in the ./include/configs/<board>.h, which is error prone and shall be
avoided when we strive to switch to Kconfig.
The goal of this patch:
Provide distinction for DM_SPI support in both U-Boot proper and SPL (TPL).
Valid use case is when U-Boot proper wants to use DM_SPI, but SPL must
still support non DM driver.
Another use case is the conversion of non DM/DTS SPI driver to support
DM/DTS. When such driver needs to work in both SPL and U-Boot proper, the
distinction is needed in Kconfig (also if SPL version of the driver
supports OF_PLATDATA).
In the end of the day one would have to support following use cases (in
single driver file - e.g. mxs_spi.c):
- U-Boot proper driver supporting DT/DTS
- U-Boot proper driver without DT/DTS support (deprecated)
- SPL driver without DT/DTS support
- SPL (and TPL) driver with DT/DTS (when the SoC has enough resources to
run full blown DT/DTS)
- SPL driver with DT/DTS and SPL_OF_PLATDATA (when one have constrained
environment with no fitImage and OF_LIBFDT support).
Some boards do require SPI support (with DM) in SPL (TPL) and some only
have DM_SPI{_FLASH} defined to allow compiling SPL.
This patch converts #ifdef CONFIG_DM_SPI* to #if CONFIG_IS_ENABLED(DM_SPI)
and provides corresponding defines in Kconfig.
Signed-off-by: Lukasz Majewski <lukma@denx.de>
Tested-by: Adam Ford <aford173@gmail.com> #da850-evm
Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com>
[trini: Fixup a few platforms]
Due to how the Makefile logic is we currently get DM_SPI support in SPL
enabled by having DM_SPI enabled for full U-Boot but not having
CONFIG_SPL_DM_SPI set. Add this missing option to boards that were
inadvertently making use of it.
Cc: Adam Ford <aford173@gmail.com>
Cc: Akash Gajjar <akash@openedev.com>
Cc: Andy Yan <andy.yan@rock-chips.com>
Cc: Anup Patel <anup.patel@wdc.com>
Cc: Atish Patra <atish.patra@wdc.com>
Cc: Bin Meng <bmeng.cn@gmail.com>
Cc: Chee Hong Ang <chee.hong.ang@intel.com>
Cc: Chin-Liang See <clsee@altera.com>
Cc: Dalon Westergreen <dwesterg@gmail.com>
Cc: Dinh Nguyen <dinguyen@kernel.org>
Cc: Eugen Hristev <eugen.hristev@microchip.com>
Cc: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
Cc: Klaus Goger <klaus.goger@theobroma-systems.com>
Cc: Levin Du <djw@t-chip.com.cn>
Cc: Ley Foon Tan <ley.foon.tan@intel.com>
Cc: Lokesh Vutla <lokeshvutla@ti.com>
Cc: Luca Ceresoli <luca@lucaceresoli.net>
Cc: Mike Looijmans <mike.looijmans@topic.nl>
Cc: Nicolas Ferre <nicolas.ferre@microchip.com>
Cc: Palmer Dabbelt <palmer@dabbelt.com>
Cc: Paul Walmsley <paul.walmsley@sifive.com>
Cc: Pavel Machek <pavel@denx.de>
Cc: Peter Robinson <pbrobinson@gmail.com>
Cc: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Cc: Stefan Roese <sr@denx.de>
Cc: Suniel Mahesh <sunil@amarulasolutions.com>
Cc: Wolfgang Grandegger <wg@aries-embedded.de>
Reviewed-by: Luca Ceresoli <luca@lucaceresoli.net>
CONFIG_BOOTP_DNS2
CONFIG_BOOTP_PXE_CLIENTARCH
This would make SPL build to DM_SPL, SPL_OF_CONTROL.
Build fine with but not tested.
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
