These two options go together and it is best to do the conversion in one
step. So enable DM_MMC_OPS by default if DM_MMC is enabled.
To speed up conversion to CONFIG_BLK, enable it by default when DM_MMC is
enabled.
move the UBI config options into Kconfig.
Reviewed-by: Andrew F. Davis <afd@ti.com>
Reviewed by: Evgeni Dobrev <evgeni at studio-punkt.com>
Move this option to Kconfig and tidy up existing uses.
Move the SPL settings into common/spl where most of the SPL code is kept.
move VERSION_VARIABLE from board config file into a
Kconfig option.
In some cases we were missing CONFIG_USB=y so enable that when needed.
Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
K2G can benefit from driver model support in the
MMC/SD driver it uses: omap_hsmmc
Enable driver model MMC support for K2G.
Signed-off-by: Sekhar Nori <nsekhar@ti.com>
Acked-by: Mugunthan V N <mugunthanvnm@ti.com>
Enable Cadence QSPI controller support to use QSPI on K2G SoC. Also
enable Spansion flash support to access s25fl512s flash present on K2G
QSPI bus.
Signed-off-by: Vignesh R <vigneshr@ti.com>
Reviewed-by: Jagan Teki <jteki@openedev.com>
Enable SPI and SPI Flash driver model as K2G SPI controller driver
supports driver model.
Create an entry for "config USB_XHCI_DWC3" in Kconfig and
switch over to it for all boards.
Move CONFIG_USB_XHCI to defconfig files for all boards, renaming it
into CONFIG_USB_XHCI_HCD.
As commented in the help of "config USB_XHCI" entry, this has been
a TODO for a long time; now CONFIG_USB_XHCI_HCD and CONFIG_USB_XHCI
have been unified in favor of the former.
Note:
Some boards define CONFIG_USB_XHCI in their headers without
CONFIG_USB, which does not meet the "depends on" in Kconfig.
I added CONFIG_USB=y for those boards when converting.
Otherwise, they would fail to build.
Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
Some boards' defconfig files are out of order. Clean this up.
Enable support for PMMC the TI power processor on K2G. This processor
manages all power management related activities on the SoC and and
allows the Operating Systems on compute processors such as ARM, DSP to
offload the power logic away into the power processor.
Signed-off-by: Nishanth Menon <nm@ti.com>
There are already two FIT options in Kconfig but the CONFIG options are
still in the header files. We need to do a proper move to fix this.
Move these options to Kconfig and tidy up board configuration:
CONFIG_FIT
CONFIG_OF_BOARD_SETUP
CONFIG_OF_SYSTEM_SETUP
CONFIG_FIT_SIGNATURE
CONFIG_FIT_BEST_MATCH
CONFIG_FIT_VERBOSE
CONFIG_OF_STDOUT_VIA_ALIAS
CONFIG_RSA
Unfortunately the first one is a little complicated. We need to make sure
this option is not enabled in SPL by this change. Also this option is
enabled automatically in the host builds by defining CONFIG_FIT in the
image.h file. To solve this, add a new IMAGE_USE_FIT #define which can
be used in files that are built on the host but must also build for U-Boot
and SPL.
Note: Masahiro's moveconfig.py script is amazing.
[trini: Add microblaze change, various configs/ re-applies]
enable net driver model for k2g evm as keystone_net supports
driver model
Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com>
There are already Kconfig options for SPI flash drivers, but we
have not moved them from config.h to defconfig files. This commit
does this in a batch.
Add CMD_GPIO to Kconfig and run tools/moveconfig.py .
Add config file for k2g
Signed-off-by: Vitaly Andrianov <vitalya@ti.com>
