path: root/configs/jetson-tk1_defconfig
2019-02-22configs: Resync with savedefconfigTom Rini
2019-02-20Kconfig: tegra: Migrate USB_EHCI_TEGRAPeter Robinson
Migrate USB_EHCI_TEGRA from headers to Kconfig Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Cc: Tom Warren <twarren@nvidia.com> Cc: Stephen Warren <swarren@nvidia.com> Cc: Marek Vasut <marex@denx.de> Cc: Marcel Ziswiler <marcel.ziswiler@toradex.com> Cc: Peter.Chubb@data61.csiro.au Cc: Lucas Stach <dev@lynxeye.de> Cc: Stefan Agner <stefan.agner@toradex.com> Cc: Alban Bedel <alban.bedel@avionic-design.de> Cc: Allen Martin <amartin@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2019-02-20Kconfig: tegra: Migrate SYS_I2C_TEGRAPeter Robinson
Migrate SYS_I2C_TEGRA from headers to Kconfig Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Cc: Tom Warren <twarren@nvidia.com> Cc: Stephen Warren <swarren@nvidia.com> Cc: Heiko Schocher <hs@denx.de> Cc: Marcel Ziswiler <marcel.ziswiler@toradex.com> Cc: Peter.Chubb@data61.csiro.au Cc: Lucas Stach <dev@lynxeye.de> Cc: Stefan Agner <stefan.agner@toradex.com> Cc: Alban Bedel <alban.bedel@avionic-design.de> Cc: Allen Martin <amartin@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2019-01-07configs: Resync with savedefconfigTom Rini
2018-04-16part: Disable CONFIG_SPL_ISO_PARTITION by defaultAlexander Graf
We enabled CONFIG_ISO_PARTITION by default for distro boot, so that U-Boot could load distro images that usually get shipped as iso images. These images usually come with a board agnostic boot environment. However, there is very little point in having ISO support enabled (for anyone really) in SPL, as the whole idea of SPL is to load U-Boot proper which again is board specific. So the fact that we enable ISO support in U-Boot proper does not mean at all that we want ISO support in U-Boot SPL. Hence, let's remove the Kconfig dependency. Along the way, let's also clean up all those default configs that disabled SPL ISO support. Signed-off-by: Alexander Graf <agraf@suse.de>
2017-10-03usb: gadget: Make g_dnl USB settings commonMaxime Ripard
The g_dnl USB settings for the vendor ID, product ID and manufacturer are actually common settings that can and should be shared by all the gadgets. Make them common by renaming them, and convert all the users. Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Lukasz Majewski <lukma@denx.de> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-09-08usb: net: migrate USB Ethernet adapters to KconfigChris Packham
This migrates ASIX, ASIX88179, MCS7830, RTL8152 and SMSC95XX to Kconfig. Update defconfigs. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-08usb: net: migrate CONFIG_USB_HOST_ETHER to KconfigChris Packham
CONFIG_USB_HOST_ETHER is the framework that the drivers are dependent on USB_HOST_ETHER. Use this as a menu and move the existing LAN75XX and LAN78XX options under new menu. Finally update the defconfigs that need CONFIG_USB_HOST_ETHER. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-07-28dm: tegra: Move nyan-big, jetson-tk1/tx1, beaver to livetreeSimon Glass
Change these board to use a live device tree after relocation. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Tested-on: Beaver, Jetson-TK1 Tested-by: Stephen Warren <swarren@nvidia.com>
2017-07-28dm: power: Convert as3722 to driver modelSimon Glass
Convert this PMIC driver to driver model and fix up other users. The regulator and GPIO functions are now handled by separate drivers. Update nyan-big to work correct. Three boards will need to be updated by the maintainers: apalis-tk1, cei-tk1-som. Also the TODO in the code re as3722_sd_set_voltage() needs to be completed. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Lukasz Majewski <lukma@denx.de> Tested-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Tested-on: Jetson-TK1 Tested-by: Stephen Warren <swarren@nvidia.com>
2017-06-01tegra: Convert MMC to use driver model for operationsSimon Glass
Enable CONFIG_DM_MMC_OPS and CONFIG_BLK for all Tegra devices. This moves Tegra to use driver model fully for MMC. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-04-30power: Convert CONFIG_PMIC_AS3722 to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_PMIC_AS3722 Signed-off-by: Simon Glass <sjg@chromium.org>
2016-12-03Enable DISTRO_DEFAULT on platforms that missed it beforeTom Rini
A number of platforms had been using the distro default feature before it was moved to Kconfig but did not enable the new Kconfig option when it was enabled. This caused a regression in terms of features and this introduces breakage when more things move to Kconfig. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_SYS_STDIO_DEREGISTER to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SYS_STDIO_DEREGISTER This option should never be enabled in SPL, so use CONFIG_IS_ENABLED(SYS_STDIO_DEREGISTER) when checking the option. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Re-sync] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-11dm: mmc: Enable DM_MMC_OPS by default with DM_MMCSimon Glass
These two options go together and it is best to do the conversion in one step. So enable DM_MMC_OPS by default if DM_MMC is enabled. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-11dm: blk: Enable CONFIG_BLK if DM_MMC is enabledSimon Glass
To speed up conversion to CONFIG_BLK, enable it by default when DM_MMC is enabled. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-09-27dfu: Migrate to KconfigTom Rini
Introduce a hidden USB_FUNCTION_DFU Kconfig option and select it for CMD_DFU (as we must have the DFU command enabled to do anything DFU). Make all of the entries in drivers/dfu/Kconfig depend on CMD_DFU and add options for all of the back end choices that DFU can make use of. Cc: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Lukasz Majewski <l.majewski@samsung.com>
2016-04-20usb: gadget Move: CONFIG_G_DNL_* to KconfigSam Protsenko
And also reformat defconfigs using "make savedefconfig" rule. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-20usb: gadget: Move CONFIG_USB_GADGET_DOWNLOAD to KconfigSam Protsenko
While at it, remove obsolete CONFIG_USBDOWNLOAD_GADGET option from some config headers. This is also probably fixes am335x_baltos board. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-20usb: gadget: Move CONFIG_USB_GADGET_DUALSPEED to KconfigSam Protsenko
Move CONFIG_USB_GADGET_DUALSPEED option to Kconfig and make all UDC controllers select USB_GADGET_DUALSPEED: - add next options to Kconfig selecting USB_GADGET_DUALSPEED: - USB_GADGET_ATMEL_USBA - USB_GADGET_DWC2_OTG - USB_DWC3 - CI_UDC - make USB_MUSB_GADGET select USB_GADGET_DUALSPEED While at it, make some related fixes: - remove DUALSPEED from configs that don't enable gadget support: - kwb.h - tseries.h - add missing USB_GADGET option to next configs: - novena_defconfig - pcm051_rev*_defconfig - xfi3_defconfig Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-03-25usb: gadget: Move CONFIG_USB_GADGET to KconfigSam Protsenko
The description was borrowed from kernel. "tristate" type was changed to "bool" (I believe we don't support modules for u-boot yet, right?). CONFIG_USB_GADGET requires CONFIG_USB to be defined too, so add it along as well. Definitions were added to defconfig files in a way that "make savedefconfig" generates exactly the same file as used defconfig. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> [trini: Add zynq_zc702 conversion] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-03-22net: Move CONFIG_RTL8169 to KconfigBin Meng
Introduce CONFIG_RTL8169 in Kconfig and move over boards' defconfig to use that. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Stephen Warren <swaren@nvidia.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-12-05tegra: Remove merge markers in some Kconfig filesSimon Glass
These were added by mistake in commit fde7e189. They cause a warning when configuring the boards. Remove them. Fixes: fde7e18938d8 ("dm: tegra: pci: Move CONFIG_PCI_TEGRA to Kconfig") Signed-off-by: Simon Glass <sjg@chromium.org> Reported-by: Stephen Warren <swarren@nvidia.com> Tested-by: Stephen Warren <swarren@nvidia.com> Reported-by: Kevin Hilman <khilman@linaro.org> Acked-by: Thomas Chou <thomas@wytron.com.tw>
2015-12-01dm: tegra: pci: Move CONFIG_PCI_TEGRA to KconfigSimon Glass
Move this option to Kconfig and fix up all users. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Stephen Warren <swarren@nvidia.com>
