MTD subsystem has support for parsing partitions from device
tree, thus drop the MTDPARTS configs, also for cadence QSPI,
the REF_CLK is fetched from device tree thus remove that also
from the configs
Signed-off-by: Vaishnav Achath <vaishnav.a@ti.com>
Run boot_procs in boot command to early boot all the remote processors.
Signed-off-by: Hari Nagalla <hnagalla@ti.com>
Add J784S4 High Security EVM defconfig.
These configs are same as for the non-secure part, except for:
CONFIG_TI_SECURE_DEVICE option set to 'y'
CONFIG_FIT_SIGNATURE option set to 'y'
CONFIG_BOOTCOMMAND option is changed to use fitImage
'# CONFIG_CMD_SETEXPR is not set' is removed to allow fit booting
Non-HS devices will continue to boot due to runtime device type detection.
If TI_SECURE_DEV_PKG is not set the build will emit warnings, for non-HS
devices these can be ignored.
Signed-off-by: Manorit Chawdhry <m-chawdhry@ti.com>
Add board support for J784S4 SoC.
