J721S2 supports both secure and non-secure devices, including HS-FS and
GP devices. Update the default defconfig to include configuration for
both GP and HS-FS. Because of runtime device type detection, both GP and
HS-FS devices will continue to boot.
Additionally, if TI_SECURE_DEV_PKG is not set the build emits warnings,
the same shall be ignored for GP devices.
Signed-off-by: Sinthu Raja <sinthu.raja@ti.com>
Acked-by: Manorit Chawdhry <m-chawdhry@ti.com>
J721S2 EVM used to store env on eMMC, since EVM and SK uses same
defconfig and there is no eMMC on SK, we need to keep env in an
interface which available on both EVM and SK. So, save env in FAT
partition of MMC SD Card.
Enable defconfigs relevant for storing env on FAT partion of MMC.
Enable configs for building multiple dtbs into a single fit image
and load the right dtb for next stage. This will help to use same
defconfig for both EVM and SK.
Enable R5 SPL specific configs for J721S2.
Signed-off-by: David Huang <d-huang@ti.com>
Signed-off-by: Aswath Govindraju <a-govindraju@ti.com>
Signed-off-by: Vignesh Raghavendra <vigneshr@ti.com>
Signed-off-by: Hari Nagalla <hnagalla@ti.com>
