Enable CONFIG_SET_DFU_ALT_INFO for all J7 platforms, to set the
dfu_alt_info environment variable dynamically from a platform
specific override. For now, this is performed by fetching the
partition information from the device tree, dynamic dfu_alt_info
override is now supported only for `sf` devices.
Signed-off-by: Vaishnav Achath <vaishnav.a@ti.com>
Having saved environments usually causes inconsistencies while in
development workflow. The saved environments conflict with the
default ones that U-boot should be updating during development
but that doesn't happen and the saved environments need to be
reset during bootups to test the changes causing extra debugs.
Remove the saved environments as a default. Environments can always
be re-enabled locally if one does like them or needs them for
some production environment. Optionally, Uenv.txt can also be used on
some of the boot media.
Signed-off-by: Manorit Chawdhry <m-chawdhry@ti.com>
Enable OSPI PHY support in SPL and U-Boot, this is necessary
for achieving higher transaction speeds (>25 MHz DDR) with OSPI.
Default to common bootcmd that is set across all k3 devices.
Tested-by: Nikhil M Jain <n-jain1@ti.com>
Signed-off-by: Kamlesh Gurudasani <kamlesh@ti.com>
Keeping this line in defconfigs doesn't allow the Kconfig values to be
reflected, remove these to enabled use of setexpr used for fit image
booting.
This allows us to download large images like linux kernel and flash it
to boot media. Drop from defconfigs so that its common across platform.
Note the some *_r5_*defconfigs set this to even higher value but thats
useless as ARCH_K3 doesn't use u-boot.img for R5.
Signed-off-by: Vignesh Raghavendra <vigneshr@ti.com>
Enable the configs for J721S2 EVM OSPI NAND support.
Signed-off-by: Apurva Nandan <a-nandan@ti.com>
MTD subsystem has support for parsing partitions from device
tree, thus drop the MTDPARTS configs, also for cadence QSPI,
the REF_CLK is fetched from device tree thus remove that also
from the configs
commit c714045cc3c0c36bc836c909e74db3273a7dd390 upstream.
K3 devices have runtime type board detection. Make the default defconfig
include the secure configuration. Then remove the HS specific config.
Non-HS devices will continue to boot due to runtime device type detection.
If TI_SECURE_DEV_PKG is not set the build will emit warnings, for non-HS
devices these can be ignored.
Acked-by: Andrew Davis <afd@ti.com>
[praneeth@ti.com: cherry-pick and resolve merge conflict from upstream next]
Signed-off-by: Praneeth Bajjuri <praneeth@ti.com>
J721S2 EVM used to store env on eMMC, since EVM and SK uses same
defconfig and there is no eMMC on SK, we need to keep env in an
interface which available on both EVM and SK. So, save env in FAT
partition of MMC SD Card.
Enable defconfigs relevant for storing env on FAT partition of MMC.
Signed-off-by: Sinthu Raja <sinthu.raja@ti.com>
Enable configs for building multiple dtbs into a single fit image
and load the right dtb for next stage. Add k3-am68-sk-base-board
dtb along with evm dtb inside DTB FIT image. This helps to use same
defconfig for both EVM and SK
CONFIG_FLASH_SHOW_PROGRESS
Change configuration macro name to support all other devices in SEMPER S28
family.
Signed-off-by: Takahiro Kuwano <Takahiro.Kuwano@infineon.com>
Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
Remove the main_cpsw0_qsgmii_phyinit variable from the boot
command as there is no ethernet firmware in j721s2.
Fixes: 8886341aa670 ('configs: j721s2_evm_a72_defconfig: Add A72 specific defconfig')
Signed-off-by: Jayesh Choudhary <j-choudhary@ti.com>
CONFIG_SYS_SPL_MALLOC_SIZE
CONFIG_SYS_SPL_MALLOC_START
We introduce a default value here as well, and CONFIG_SYS_SPL_MALLOC to
control if we have a malloc pool or not.
CONFIG_SPL_BSS_START_ADDR
- Make all users of CUSTOM_SYS_INIT_SP_ADDR reference SYS_INIT_SP_ADDR
- Introduce HAS_CUSTOM_SYS_INIT_SP_ADDR to allow for setting the stack
pointer directly, otherwise we use the common calculation.
- On some platforms that were using the standard calculation but did not
set CONFIG_SYS_INIT_RAM_SIZE / CONFIG_SYS_INIT_RAM_ADDR, set them.
- On a small number of platforms that were not subtracting
GENERATED_GBL_DATA_SIZE do so now via the standard calculation.
- CONFIG_SYS_INIT_SP_OFFSET is now widely unused, so remove it from most
board config header files.
CONFIG_SPL_BSS_MAX_SIZE
CONFIG_SPL_MAX_FOOTPRINT
Note that the da850evm platforms were violating the "only use one" rule
here, and so now hard-code their BSS limit.
CONFIG_SPL_PAD_TO
CONFIG_SPL_MAX_SIZE
CONFIG_TPL_PAD_TO
CONFIG_TPL_MAX_SIZE
Note that we need to make TPL_MAX_SIZE be hex, and so move and convert the
existing places.
CONFIG_SPL_FS_LOAD_ARGS_NAME
CONFIG_SPL_FS_LOAD_KERNEL_NAME
CONFIG_SPL_FS_LOAD_PAYLOAD_NAME
CONFIG_SYS_MAXARGS
Resync all defconfig files using moveconfig.py
This is a little tricky since SoCFPGA has code to determine this as
runtime. Introduce a guard variable for platforms to select if they
have a static value to use. Then for ARCH_SOCFPGA, call
cm_get_qspi_controller_clk_hz() and otherwise continue the previous
behavior.
Cc: Jagan Teki <jagan@amarulasolutions.com>
As the CI test for stopping platforms from being merged that were
defining symbols that had Kconfig entries, a small number of symbols
needed to be migrated again. Do so, and catch two cases the README
should also have been updated but was not.
Rsync all defconfig files using moveconfig.py and update
scripts/pylint.base
Enable A72 specific configs for J721S2
Signed-off-by: David Huang <d-huang@ti.com>
Signed-off-by: Aswath Govindraju <a-govindraju@ti.com>
Signed-off-by: Hari Nagalla <hnagalla@ti.com>
