path: root/configs/j721e_evm_a72_defconfig
2020-08-10configs: Resync with savedefconfigTom Rini
2020-08-08Convert CONFIG_SYS_MMC_ENV_DEV et al to KconfigTom Rini
This converts the following to Kconfig: CONFIG_SYS_MMC_ENV_DEV CONFIG_SYS_MMC_ENV_PART Note that with this conversion we now have consistent behavior with respect to ensuring that we have always selected the correct MMC device and hardware partition. Signed-off-by: Tom Rini <trini@konsulko.com>
2020-07-28Makefile: Allow CONFIG_SPL_FIT_GENERATOR to be emptySimon Glass
At present we use the empty string to indicate that there is no FIT generator, but this doesn't allow an individual board to undefine it. Create a separate bool instead. Update the config of the boards which currently have an empty string. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-07-28configs: migrate CONFIG_SPL_LOAD_FIT_ADDRESS to defconfigsPeng Fan
Done with: ./tools/moveconfig.py -S SPL_LOAD_FIT_ADDRESS ./tools/moveconfig.py -S SPL_LOAD_FIT_ADDRESS -H Signed-off-by: Peng Fan <peng.fan@nxp.com> [trini: A few more migrations] Signed-off-by: Tom Rini <trini@konsulko.com>
2020-07-28Convert CONFIG_ENV_OVERWRITE to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_ENV_OVERWRITE Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Rerun migration, remove some comments] Signed-off-by: Tom Rini <trini@konsulko.com>
2020-07-28configs: Resync with savedefconfigTom Rini
2020-07-25configs: j721e_evm: Enable CONFIG_SOC_DEVICE and CONFIG_SOC_DEVICE_TI_K3Dave Gerlach
Enable CONFIG_SOC_DEVICE and CONFIG_SOC_DEVICE_TI_K3 so the TI K3 SoC driver can be used for SoC detection. Signed-off-by: Dave Gerlach <d-gerlach@ti.com>
2020-07-24Revert "Merge tag 'dm-pull-20jul20' of git://git.denx.de/u-boot-dm"Tom Rini
This reverts commit 5d3a21df6694ebd66d5c34c9d62a26edc7456fc7, reversing changes made to 56d37f1c564107e27d873181d838571b7d7860e7. Unfortunately this is causing CI failures: https://travis-ci.org/github/trini/u-boot/jobs/711313649 Signed-off-by: Tom Rini <trini@konsulko.com>
2020-07-20configs: j721e_evm: Enable CONFIG_SOC_DEVICE and CONFIG_SOC_DEVICE_TI_K3Dave Gerlach
2020-07-06Merge branch 'next'Tom Rini
Merge all outstanding changes from the current next branch in now that we have released.
2020-07-06configs: Resync with savedefconfigTom Rini
2020-06-29spi: Convert CONFIG_DM_SPI* to CONFIG_$(SPL_TPL_)DM_SPI*Lukasz Majewski
This change allows more fine tuning of driver model based SPI support in SPL and TPL. It is now possible to explicitly enable/disable the DM_SPI support in SPL and TPL via Kconfig option. Before this change it was necessary to use: /* SPI Flash Configs */ #if defined(CONFIG_SPL_BUILD) #undef CONFIG_DM_SPI #undef CONFIG_DM_SPI_FLASH #undef CONFIG_SPI_FLASH_MTD #endif in the ./include/configs/<board>.h, which is error prone and shall be avoided when we strive to switch to Kconfig. The goal of this patch: Provide distinction for DM_SPI support in both U-Boot proper and SPL (TPL). Valid use case is when U-Boot proper wants to use DM_SPI, but SPL must still support non DM driver. Another use case is the conversion of non DM/DTS SPI driver to support DM/DTS. When such driver needs to work in both SPL and U-Boot proper, the distinction is needed in Kconfig (also if SPL version of the driver supports OF_PLATDATA). In the end of the day one would have to support following use cases (in single driver file - e.g. mxs_spi.c): - U-Boot proper driver supporting DT/DTS - U-Boot proper driver without DT/DTS support (deprecated) - SPL driver without DT/DTS support - SPL (and TPL) driver with DT/DTS (when the SoC has enough resources to run full blown DT/DTS) - SPL driver with DT/DTS and SPL_OF_PLATDATA (when one have constrained environment with no fitImage and OF_LIBFDT support). Some boards do require SPI support (with DM) in SPL (TPL) and some only have DM_SPI{_FLASH} defined to allow compiling SPL. This patch converts #ifdef CONFIG_DM_SPI* to #if CONFIG_IS_ENABLED(DM_SPI) and provides corresponding defines in Kconfig. Signed-off-by: Lukasz Majewski <lukma@denx.de> Tested-by: Adam Ford <aford173@gmail.com> #da850-evm Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> [trini: Fixup a few platforms] Signed-off-by: Tom Rini <trini@konsulko.com>
2020-06-26spi: Enable missing CONFIG_SPL_DM_SPI supportTom Rini
Due to how the Makefile logic is we currently get DM_SPI support in SPL enabled by having DM_SPI enabled for full U-Boot but not having CONFIG_SPL_DM_SPI set. Add this missing option to boards that were inadvertently making use of it. Cc: Adam Ford <aford173@gmail.com> Cc: Akash Gajjar <akash@openedev.com> Cc: Anatolij Gustschin <agust@denx.de> Cc: Andy Yan <andy.yan@rock-chips.com> Cc: Anup Patel <anup.patel@wdc.com> Cc: Atish Patra <atish.patra@wdc.com> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Chee Hong Ang <chee.hong.ang@intel.com> Cc: Chin-Liang See <clsee@altera.com> Cc: Dalon Westergreen <dwesterg@gmail.com> Cc: Dinh Nguyen <dinguyen@kernel.org> Cc: Eugen Hristev <eugen.hristev@microchip.com> Cc: Hannes Schmelzer <hannes.schmelzer@br-automation.com> Cc: Heiko Schocher <hs@denx.de> Cc: Jagan Teki <jagan@amarulasolutions.com> Cc: Klaus Goger <klaus.goger@theobroma-systems.com> Cc: Levin Du <djw@t-chip.com.cn> Cc: Ley Foon Tan <ley.foon.tan@intel.com> Cc: Lokesh Vutla <lokeshvutla@ti.com> Cc: Luca Ceresoli <luca@lucaceresoli.net> Cc: Marek Vasut <marex@denx.de> Cc: Michal Simek <monstr@monstr.eu> Cc: Mike Looijmans <mike.looijmans@topic.nl> Cc: Nicolas Ferre <nicolas.ferre@microchip.com> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Palmer Dabbelt <palmer@dabbelt.com> Cc: Patrick Delaunay <patrick.delaunay@st.com> Cc: Paul Walmsley <paul.walmsley@sifive.com> Cc: Pavel Machek <pavel@denx.de> Cc: Peter Robinson <pbrobinson@gmail.com> Cc: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Cc: Simon Glass <sjg@chromium.org> Cc: Stefan Roese <sr@denx.de> Cc: Suniel Mahesh <sunil@amarulasolutions.com> Cc: Vitaly Andrianov <vitalya@ti.com> Cc: Wolfgang Grandegger <wg@aries-embedded.de> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Luca Ceresoli <luca@lucaceresoli.net>
2020-06-12net: phy: Add support for TI PHY initDan Murphy
ti_phy_init function was allocated to the DP83867 PHY. This function name is to generic for a specific PHY. The function can be moved to a TI specific file that can register all TI PHYs that are defined in the defconfig. The ti_phy_init file will contain all TI PHYs initialization so that only phy_ti_init can be called from the framework. In addition to the above the config flag for the DP83867 needs to be changed in the Kconfig and dependent defconfig files. The config flag that was used for the DP83867 was also generic in nature so a more specific config flag for the DP83867 was created. Acked-by: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Dan Murphy <dmurphy@ti.com>
2020-04-28configs: Resync with savedefconfigTom Rini
2020-03-17Merge tag 'ti-v2020.07-next' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-ti into next K3 J721E: * OSPI boot support * Support for loading remote cores in R5 SPL * PMIC ESM Support * Minor fixes for R5F and C7x remoteproc drivers K3 AM654: * Update AVS class 0 voltages. * Add I2C nodes DRA7xx/AM57xx: * Fixed Android boot on AM57xx AM33/AM43/Davinci: * switch to driver model for the net and mdio driver for baltos * Add DM/DTS support for omap video driver * Enable fastboot on am335x-evm
2020-03-09configs: j721e_evm: Add Support for eMMC bootFaiz Abbas
Enable configs to support eMMC boot. Signed-off-by: Faiz Abbas <faiz_abbas@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2020-03-03configs: j721e_evm_defconfig: Enable OSPI configsVignesh Raghavendra
Enable OSPI related defconfigs. Also enable SPL_DMA so that DMA is used during OSPI boot Signed-off-by: Vignesh Raghavendra <vigneshr@ti.com>
2020-02-28configs: Resync with savedefconfigTom Rini
2020-02-06configs: Resync with savedefconfigTom Rini
2020-02-04configs: j721e_evm_a72: Add GPIO supportFaiz Abbas
Enable CONFIG_DA8XX_GPIO to enable GPIO support. Signed-off-by: Faiz Abbas <faiz_abbas@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2020-02-04configs: j721e_evm_defconfig: Enable PCA953x IO expanderVignesh Raghavendra
Enable PCA953x IO expander to control MMC/SD power lines. Signed-off-by: Vignesh Raghavendra <vigneshr@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2020-02-04configs: j721e_evm_r5/a72_defconfig: Enable DFU related configsVignesh Raghavendra
Enable DFU, Fastboot and USB mass storage gadget related configs Signed-off-by: Vignesh Raghavendra <vigneshr@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2020-02-04configs: j721e_evm_r5/a72_defconfig: Enable USB Gadget related configsVignesh Raghavendra
Enable USB Gadget for R5 SPL, A72 SPL and A72 U-Boot to support DFU boot Signed-off-by: Vignesh Raghavendra <vigneshr@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2020-02-04configs: j721e_evm_a72: Fix redundant environment offsetFaiz Abbas
The current environment offset overlaps with the sysfw area and whenever environment is saved in the redundant slot, it overwrites sysfw.itb. Fix the offset to prevent this. Signed-off-by: Faiz Abbas <faiz_abbas@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2020-01-22configs: Resync with savedefconfigTom Rini
2020-01-20configs: j721e_evm_a72_defconfig: Enable I2C and EEPROM supportVignesh Raghavendra
Enable I2C and EEPROM related configs for A72 SPL/U-Boot. Signed-off-by: Vignesh Raghavendra <vigneshr@ti.com> Signed-off-by: Andreas Dannenberg <dannenberg@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2020-01-20configs: j721e_evm: Add configs for environment in eMMCFaiz Abbas
Add config to save and read back environment from eMMC. Signed-off-by: Faiz Abbas <faiz_abbas@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2020-01-20configs: j721e_evm: Add configs for ADMA SupportFaiz Abbas
Add configs for ADMA Support. Signed-off-by: Faiz Abbas <faiz_abbas@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2020-01-20configs: j721e_evm_a72_defconfig: Enable USB related configsVignesh Raghavendra
Enable USB host and device related configs. Signed-off-by: Vignesh Raghavendra <vigneshr@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2019-12-09configs: j721e_evm_a72_defconfig: Enable DMA and EthernetVignesh Raghavendra
Enable configs related to DMA and Ethernet so as to support networking at U-Boot prompt Signed-off-by: Vignesh Raghavendra <vigneshr@ti.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Grygorii Strashko <grygorii.strashko@ti.com>
2019-12-03mtd: rename CONFIG_MTD_DEVICE -> CONFIG_MTDMiquel Raynal
Like in Linux, just use CONFIG_MTD to compile the MTD stack. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
2019-12-03mtd: rename CONFIG_MTD -> CONFIG_DM_MTDMiquel Raynal
CONFIG_MTD must be reserved for the MTD core. Like any other subsystem, prefix the symbol by DM when it comes to DM support. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com> [trini: Add Kconfig files] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-11-11configs: Resync with savedefconfigTom Rini
2019-11-07configs: Resync with savedefconfigTom Rini
2019-10-24Merge branch '2019-10-24-UFS-support'Tom Rini
- Add Universal Flash Storage (UFS) support
2019-10-24configs: j721e_evm_a72_defconfig: Add HBMC related configsVignesh Raghavendra
Enable HBMC and HyperFlash in A72 SPL and A72 U-Boot Signed-off-by: Vignesh Raghavendra <vigneshr@ti.com> Reviewed-by: Stefan Roese <sr@denx.de>
2019-10-23configs: j721e_evm_a72: Enable configs for UFSFaiz Abbas
Enable SCSI and UFS related configs. Signed-off-by: Faiz Abbas <faiz_abbas@ti.com>
2019-10-11configs: j721e_evm_a72: Enable DISPLAY_CPUINFOLokesh Vutla
Enable CONFIG_DISPLAY_CPUINFO so that cpuinfo is printed during boot. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2019-10-11configs: j721e_evm_a72: Disable PSCI_RESETLokesh Vutla
J721E uses TISCI protocol to reset the device and does not support PSCI reset. So disable PSCI reset. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2019-10-11configs: j721e_evm_a72: Enhance bootcmd to start remoteprocsSuman Anna
The A72 U-boot can support early booting of any of the R5F or C66x or C71x remote processors from U-boot prompt to achieve various system usecases before booting the Linux kernel. Update the default BOOTCOMMAND to provide an automatic and easier way to start various remote processors through added environment variables. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Signed-off-by: Suman Anna <s-anna@ti.com>
2019-10-11configs: j721e_evm_a72: Enable R5F and DSP remoteproc driverLokesh Vutla
Enable R5F and DSP remoteproc drivers for j721e running on a72. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2019-09-23configs: Resync with savedefconfigTom Rini
2019-08-25Convert CONFIG_SYS_SPI_U_BOOT_OFFS to KconfigHannes Schmelzer
This converts the following to Kconfig: CONFIG_SYS_SPI_U_BOOT_OFFS Signed-off-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com> [trini: Expose this for SPL_SPI_SUNXI for now] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-07-31configs: j721e_evm_a72: Disable K3_SYSTEM_CONTROLLERSuman Anna
The K3 System Controller driver is used for loading and starting the System Firmware, and is used only on R5 SPL. It need not be enabled and built for the A72 U-Boot and SPL, so disable it from the j721e_evm_a72 defconfig. While at this, also remove the unneeded CONFIG_SPL_REMOTEPROC and CONFIG_CMD_REMOTEPROC as no remoteprocs are now loaded from A72 SPL. Signed-off-by: Suman Anna <s-anna@ti.com>
2019-07-26configs: j721e_evm_a72: Add initial supportLokesh Vutla
Add initial defconfig support for J721e that runs on A72. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> [trini: Add MAINTAINERS entry] Signed-off-by: Tom Rini <trini@konsulko.com>
