path: root/configs/iot_devkit_defconfig
2020-04-28configs: Resync with savedefconfigTom Rini
2019-12-04configs: Resync with savedefconfigTom Rini
2019-11-01arc: emsdp/iotdk: Switch to DM_MMCAlexey Brodkin
Somehow EMSDP & IoT DK boards were skipped on ARC boads conversion to DM MMC. So doing it now. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2019-01-25ARC: Move ENV_SIZE and ENV_OFFSET to KconfigAlexey Brodkin
Join the party of some ARM boards and drop more items from include/configs/xxx.h. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-10-12iot_dk: Link for eFlashAlexey Brodkin
That's what we'll have in production. But note it won't work for loading via JTAG as eFlash is not directly writable, one needs to use prebootloader to flash uboot.bin from SD-card into eFlash. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2018-10-12iot_dk: Disable networking supportAlexey Brodkin
There's no Ethernet controller on the board so no point in having networking support. This also saves us 5.5 kB of precious memory. | # bloat-o-meter u-boot.net u-boot.no_net_regex | tail -1 | Total: Before=127892, After=122334, chg -4.35% Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2018-10-12iot_dk: Add localversion stringAlexey Brodkin
2018-10-05arc: Add support for IoT development kitAlexey Brodkin
The DesignWare ARC IoT Development Kit is a versatile platform that includes the necessary hardware and software to accelerate software development and debugging of sensor fusion, voice recognition and face detection designs. More information is avaialble here [1] and here [2]. The board is based on real silicon with ARC EM9D-based Data Fusion IP Subsystem. It sports a rich set of I/O including * DW USB OTG * DW MobileStorage (used for micro SD-card) * GPIO * multiple serial interface including DW APB UART * ADC, PWM and eFlash, SRAM and SPI Flash memory * Real-Time Clock (RTC) * Bluetooth module with worldwide regulatory compliance (FCC, IC, CE, ETSI, TELEC) * On-board 9-axis sensor (gyro, accelerometer and compass) Extensible with Arduino, Pmod, mikroBUS connectors and a 2x18 extension header. One of the most interesting features for developers is built-in Digilent USB JTAG probe so only micro-USB cable is needed! [1] https://www.synopsys.com/dw/ipdir.php?ds=arc_iot_development_kit [2] https://www.synopsys.com/dw/doc.php/ds/cc/iot_dev_kit.pdf Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
