CONFIG_SYS_MALLOC_LEN
Acked-by: Sean Anderson <seanga2@gmail.com>
Reviewed-by: Rick Chen <rick@andestech.com>
Now that we have consistent usage, migrate this symbol to Kconfig.
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
Somehow EMSDP & IoT DK boards were skipped on ARC boads conversion
to DM MMC. So doing it now.
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
Join the party of some ARM boards and drop more
items from include/configs/xxx.h.
Cc: Michal Simek <michal.simek@xilinx.com>
That's what we'll have in production.
But note it won't work for loading via JTAG as
eFlash is not directly writable, one needs to use
prebootloader to flash uboot.bin from SD-card into eFlash.
There's no Ethernet controller on the board so no point in having
networking support. This also saves us 5.5 kB of precious memory.
| # bloat-o-meter u-boot.net u-boot.no_net_regex | tail -1
| Total: Before=127892, After=122334, chg -4.35%
The DesignWare ARC IoT Development Kit is a versatile platform
that includes the necessary hardware and software to accelerate
software development and debugging of sensor fusion,
voice recognition and face detection designs.
More information is avaialble here [1] and here [2].
The board is based on real silicon with
ARC EM9D-based Data Fusion IP Subsystem.
It sports a rich set of I/O including
* DW USB OTG
* DW MobileStorage (used for micro SD-card)
* GPIO
* multiple serial interface including DW APB UART
* ADC, PWM and eFlash, SRAM and SPI Flash memory
* Real-Time Clock (RTC)
* Bluetooth module with worldwide regulatory compliance
(FCC, IC, CE, ETSI, TELEC)
* On-board 9-axis sensor (gyro, accelerometer and compass)
Extensible with Arduino, Pmod, mikroBUS connectors and a 2x18
extension header.
One of the most interesting features for developers is built-in
Digilent USB JTAG probe so only micro-USB cable is needed!
[1] https://www.synopsys.com/dw/ipdir.php?ds=arc_iot_development_kit
[2] https://www.synopsys.com/dw/doc.php/ds/cc/iot_dev_kit.pdf
