path: root/configs/integratorcp_cm1136_defconfig
2015-04-23ARM: integrator: split board select into AP/CP select and CM selectMasahiro Yamada
Select integrator boards by the combination of platform select (AP/CP) and core module select (CM720T, CM920T, ...). This allows us to remove CONFIG_SYS_EXTRA_OPTIONS and make Kconfig much cleaner. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Linus Walleij <linus.walleij@linaro.org>
2015-04-23ARM: integrator: move board select into mach-integrator/KconfigMasahiro Yamada
The board/SoC select menu in arch/arm/Kconfig is still cluttered. Add ARCH_INTEGRATOR into arch/arm/Kconfig and move the board select under arch/arm/mach-integrator. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Linus Walleij <linus.walleij@linaro.org>
