path: root/configs/integratorap_cm926ejs_defconfig
2021-12-01Convert CONFIG_USE_BOOTCOMMAND et al to KconfigTom Rini
This converts the following to Kconfig: CONFIG_USE_BOOTCOMMAND CONFIG_BOOTCOMMAND CONFIG_RAMBOOTCOMMAND CONFIG_NFSBOOTCOMMAND Signed-off-by: Tom Rini <trini@konsulko.com>
2021-11-01configs: Resync with savedefconfigTom Rini
2021-09-04configs: Resync with savedefconfigTom Rini
2021-08-31Convert CONFIG_SYS_MALLOC_LEN to KconfigTom Rini
This converts the following to Kconfig: CONFIG_SYS_MALLOC_LEN Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Sean Anderson <seanga2@gmail.com> Reviewed-by: Rick Chen <rick@andestech.com>
2021-08-31Convert CONFIG_SYS_LOAD_ADDR to KconfigTom Rini
Now that we have consistent usage, migrate this symbol to Kconfig. Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Rick Chen <rick@andestech.com>
2021-07-06ARM: integrator: Drop PCI supportLinus Walleij
We didn't convert the Integrator to use DM for PCI in time, and we don't use it either so let's just drop PCI support from the Integrator. Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2020-10-09configs: Resync with savedefconfigTom Rini
2020-08-10configs: Resync with savedefconfigTom Rini
2020-07-25net: dc2114x: Add Kconfig entriesMarek Vasut
Add Kconfig entries for the dc2114x driver and convert various boards. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Ramon Fried <rfried.dev@gmail.com>
2020-06-18net: eepro100: Add Kconfig entriesMarek Vasut
Add Kconfig entries for the eepro100 driver and convert various boards. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
2015-04-23ARM: integrator: split board select into AP/CP select and CM selectMasahiro Yamada
Select integrator boards by the combination of platform select (AP/CP) and core module select (CM720T, CM920T, ...). This allows us to remove CONFIG_SYS_EXTRA_OPTIONS and make Kconfig much cleaner. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Linus Walleij <linus.walleij@linaro.org>
2015-04-23ARM: integrator: move board select into mach-integrator/KconfigMasahiro Yamada
The board/SoC select menu in arch/arm/Kconfig is still cluttered. Add ARCH_INTEGRATOR into arch/arm/Kconfig and move the board select under arch/arm/mach-integrator. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Linus Walleij <linus.walleij@linaro.org>
