Now that those common Allwinner config symbols are defined automatically
for all boards in their Kconfig files, we can remove the now redundant
definitions from the boards' _defconfig files.
Some boards had a differing definiton for some of those symbols, it
looks like mostly to "merge races" when the symbol was introduced (new
board *_defconfig file missed the "add symbol to all files" patch).
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
Acked-by: Maxime Ripard <mripard@kernel.org>
Tested-by: Jagan Teki <jagan@amarulasolutions.com> # Amarula A64-Relic
Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
CONFIG_USE_PREBOOT
CONFIG_PREBOOT
Both are together in one commit, since otherwise the former causes kconfig
to define the latter, which gives duplicate symbol errors.
Includes a manual fixup for CONFIG_PREBOOT in ids8313_defconfig since the
backslash lands in the wrong place. Similarly with socfpga_vining_fpga.
The choice of the SPL_TEXT_BASE is not really a decision that should be
specified by each board's defconfig, as this setting is actually
dictated by the SoC's memory map and the BootROM behaviour.
To make this obvious and reduce the clutter in the defconfig files,
let's specify the SoC constraints in the Kconfig stanza.
This allows us to remove these lines from the defconfig files again.
Acked-by: Maxime Ripard <maxime.ripard@bootlin.com>
Moved CONFIG_SPL_TEXT_BASE to common/spl/Kconfig and migrate existing
values.
Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
[trini: Re-run migration]
Onc of key blocker for using USB Generic host controller
drivers in Allwinner are CLK and RESET drivers, now these
available for USB usage.
So switch sunxi USB use EHCI and OHCI Generic controllers.
Enabling USB is wisely a board choise, So Enable USB_OHCI_HCD
where it already have USB_EHCI_HCD
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
We have the following cases:
- CONFIG_NR_DRAM_BANKS was defined, migrate normally
- CONFIG_NR_DRAM_BANKS_MAX was defined and then used for
CONFIG_NR_DRAM_BANKS after a check, just migrate it over now.
- CONFIG_NR_DRAM_BANKS was very oddly defined on p2771-0000-* (to 1024 +
2), set this to 8.
We enabled CONFIG_ISO_PARTITION by default for distro boot, so that U-Boot
could load distro images that usually get shipped as iso images. These images
usually come with a board agnostic boot environment.
However, there is very little point in having ISO support enabled (for anyone
really) in SPL, as the whole idea of SPL is to load U-Boot proper which again
is board specific. So the fact that we enable ISO support in U-Boot proper does
not mean at all that we want ISO support in U-Boot SPL.
Hence, let's remove the Kconfig dependency. Along the way, let's also clean up
all those default configs that disabled SPL ISO support.
Commit 278b90ce786f ("configs: Migrate CONFIG_SYS_TEXT_BASE") made
CONFIG_SYS_TEXT_BASE a proper Kconfig variable, with the consequence
of moving the common definition shared by almost every sunxi board
into 123 individual defconfig files. But the U-Boot start address
for Allwinner boards is a platform decision which has been around for
ages, so defining it in each *board* config file seems a bit over the
top.
Define the standard values (160MB into DRAM for most SoCs, with two
SoC exceptions) if ARCH_SUNXI is selected, and delete the lines from
the individual defconfigs.
Reviewed-by: Jagan Teki <jagan@openedev.com>
On the NIOS2 and Xtensa architectures, we do not have
CONFIG_SYS_TEXT_BASE set. This is a strict migration of the current
values into the defconfig and removing them from the headers.
I did not attempt to add more default values in and for now will leave
that to maintainers.
cmd/Makefile has:
ifdef CONFIG_FPGA
obj-$(CONFIG_CMD_FPGA) += fpga.o
endif
which means that if CONFIG_FPGA is not set, CONFIG_CMD_FPGA silently
does nothing. Let's remove that Makefile conditional and instead express
this equivalent dependency in Kconfig, so a lot of redundant
# CONFIG_CMD_FPGA is not set
can be removed from board defconfigs that don't actually have an FPGA.
Having this as a 'default y' is rather annoying because it doesn't
actually compile unless other options are defined in the board header:
../cmd/bootm.c: In function 'do_imls_nor':
../cmd/bootm.c:330:7: error: 'CONFIG_SYS_MAX_FLASH_BANKS' undeclared (first use in this function); did you mean 'CONFIG_SYS_MAX_FLASH_SECT'?
i < CONFIG_SYS_MAX_FLASH_BANKS; ++i, ++info) {
Make it 'default n' so people who develop new boards that start from a
blank defconfig have one less compilation failure to debug.
This syncs all of the currently Kconfig'd symbols out of the headers and
into the defconfig files. This has two exceptions, first am335x_evm
needs to be converted to DM in SPL and then it can stop undef'ing
CONFIG_DM_USB. Leaving this as-is results in a build failure, and
without work, run time failure. The other case is am43xx_evm.h and in
turn am43xx_evm_usbhost_boot. The problem here is that we need DWC3 USB
host mode in SPL, but still desire to have gadget mode in U-Boot proper.
Signed-off-by: Patrick Delaunay <patrick.delaunay73@gmail.com>
Add a defconfig and dts file for tablets using the generic inet-q972 PCB.
Tablets with this PCB feature a mini-hdmi output, micro-usb usb-host,
micro-usb usb-otg, 3.5mm headphone jack, a micro sd slot,
(mini) power-barrel and an usb wifi module.
This has been tested on a 9.7" 1024x768 qware qw tb9718-qhd tablet.
The dts files are identical to the ones submitted to the upstream kernel.
Acked-by: Ian Campbell <ijc@hellion.org.uk>
