path: root/configs/imxrt1050-evk_defconfig
2020-04-28configs: Resync with savedefconfigTom Rini
2020-04-18configs: imxrt1050-evk: temporary disable DCACHEGiulio Benetti
mxsfb needs a dcache function not implemented in cortex-M7, so for the moment let's keep dcache not enabled. Signed-off-by: Giulio Benetti <giulio.benetti@benettiengineering.com> Reviewed-by: Anatolij Gustschin <agust@denx.de>
2020-04-18configs: imxrt1050-evk: enable video support/consoleGiulio Benetti
Enable DM_VIDEO subsystem and its BACKLIGHT_GPIO. Then enable SYS_WHITE_ON_BLACK to have classic black background on display. Need also to enable CONFIG_SYS_CONSOLE_ENV_OVERWRITE to retrieve stdin/stdout/stderr from CONFIG_EXTRA_ENV_SETTINGS. Signed-off-by: Giulio Benetti <giulio.benetti@benettiengineering.com> Reviewed-by: Anatolij Gustschin <agust@denx.de>
2020-03-09configs: imxrt1050-evk: enable D/I cacheGiulio Benetti
Soc supports cache so let's enable it. Signed-off-by: Giulio Benetti <giulio.benetti@benettiengineering.com>
2020-01-14imx: imxrt1050-evk: Add support for the NXP i.MXRT1050-EVKGiulio Benetti
This commit adds board support for i.MXRT1050-EVK from NXP. This board is an evaluation kit provided by NXP for i.MXRT105x processor family. More information about this board can be found here: https://www.nxp.com/design/development-boards/i.mx-evaluation-and-development-boards/i.mx-rt1050-evaluation-kit:MIMXRT1050-EVK The initial supported/tested devices include: - Debug serial - SD Signed-off-by: Giulio Benetti <giulio.benetti@benettiengineering.com>
