- Make all users of CUSTOM_SYS_INIT_SP_ADDR reference SYS_INIT_SP_ADDR
- Introduce HAS_CUSTOM_SYS_INIT_SP_ADDR to allow for setting the stack
pointer directly, otherwise we use the common calculation.
- On some platforms that were using the standard calculation but did not
set CONFIG_SYS_INIT_RAM_SIZE / CONFIG_SYS_INIT_RAM_ADDR, set them.
- On a small number of platforms that were not subtracting
GENERATED_GBL_DATA_SIZE do so now via the standard calculation.
- CONFIG_SYS_INIT_SP_OFFSET is now widely unused, so remove it from most
board config header files.
CONFIG_SPL_BSS_MAX_SIZE
CONFIG_SPL_MAX_FOOTPRINT
Note that the da850evm platforms were violating the "only use one" rule
here, and so now hard-code their BSS limit.
CONFIG_SYS_CBSIZE
CONFIG_SYS_PBSIZE
1M of heap is more than internal ram making booting without SDRAM not
possible now it is 256k
Signed-off-by: Jesse Taube <Mr.Bossman075@gmail.com>
This option is selected implicitly when [SPL_]CLK_IMXRT10{20|50} is selected.
Signed-off-by: Heiko Thiery <heiko.thiery@gmail.com>
Reviewed-by: Giulio Benetti <giulio.benetti@benettiengineering.com>
Rename these options so that CONFIG_IS_ENABLED can be used with them.
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
[trini: Fixup some incorrect renames]
CONFIG_SYS_MALLOC_LEN
Acked-by: Sean Anderson <seanga2@gmail.com>
Reviewed-by: Rick Chen <rick@andestech.com>
Now that we have consistent usage, migrate this symbol to Kconfig.
Drop the _SUPPORT suffix so we can use CONFIG_IS_ENABLED() with this
option.
Reviewed-by: Alexandru Gagniuc <mr.nuke.me@gmail.com>
Signed-off-by: Alexandru Gagniuc <mr.nuke.me@gmail.com>
Let's enable imx-gpt-timer in imx1020-evk defconfig.
Signed-off-by: Giulio Benetti <giulio.benetti@benettiengineering.com>
CONFIG_{SPL,TPL}_SIZE_LIMIT are defined as hex (SPL_SIZE_LIMIT was
converted in b51882d0 ("spl: Convert CONFIG_SPL_SIZE_LIMIT to hex"), but
there are still places that reference integer values. Change those to hex
as well. Also, update the Makefile to check for 0x0 instead of 0.
This also fixes the following build error when CONFIG_SPL_SIZE_LIMIT
is set by menuconfig to 0x0:
spl/u-boot-spl.bin exceeds file size limit:
limit: 0 bytes
actual: 0x80f0 bytes
excess: 0x80f0 bytes
Signed-off-by: Ovidiu Panait <ovidiu.panait@windriver.com>
Reviewed-by: Lukasz Majewski <lukma@denx.de>
