path: root/configs/imx8qxp_mek_defconfig
2019-05-18CONFIG_SPL_SYS_[DI]CACHE_OFF: addTrevor Woerner
While converting CONFIG_SYS_[DI]CACHE_OFF to Kconfig, there are instances where these configuration items are conditional on SPL. This commit adds SPL variants of these configuration items, uses CONFIG_IS_ENABLED(), and updates the configurations as required. Acked-by: Alexey Brodkin <abrodkin@synopsys.com> Signed-off-by: Trevor Woerner <trevor@toganlabs.com> [trini: Make the default depend on the setting for full U-Boot, update more zynq hardware] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-05-04Convert CONFIG_SUPPORT_EMMC_BOOT to KconfigAlex Kiernan
This converts the following to Kconfig: CONFIG_SUPPORT_EMMC_BOOT As requested by Michal Simek <michal.simek@xilinx.com>, these boards have no eMMC so CONFIG_SUPPORT_EMMC_BOOT has not been migrated: xilinx_zynqmp_zc1275_revB xilinx_zynqmp_zc1751_xm018_dc4 xilinx_zynqmp_zc1751_xm019_dc5 xilinx_zynqmp_zcu100_revC xilinx_zynqmp_zcu102_rev1_0 xilinx_zynqmp_zcu102_revA xilinx_zynqmp_zcu102_revB xilinx_zynqmp_zcu104_revA xilinx_zynqmp_zcu104_revC xilinx_zynqmp_zcu106_revA xilinx_zynqmp_zcu111_revA Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Acked-by: Lukasz Majewski <lukma@denx.de> Acked-by: Patrick Delaunay <patrick.delaunay@st.com> Acked-by: Ramon Fried <ramon.fried@gmail.com> Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Tested-by: Sébastien Szymanski <sebastien.szymanski@armadeus.com>
2019-05-01Merge tag 'u-boot-imx-20190426' of git://git.denx.de/u-boot-imxTom Rini
Porting to DM and i.MX8 ------------------------ - warp7 to DM - kp_imx53 to DM - Warnings in DT - MX8QM support - colibri-imx6ull to DM - imx7d-pico to DM - ocotp for MX8
2019-04-25imx8qxp: mek: enable dm-spl for pmPeng Fan
with u-boot,dm-spl added for imx8qx-pm node, and SPL_SIMPLE_BUS enabled, the bind and probe code in board file could be removed. Also we need to enlarge SYS_MALLOC_F_LEN to avoid calloc fail. Signed-off-by: Peng Fan <peng.fan@nxp.com>
2019-04-25imx8: mek: move HUSH_PARSER to defconfigPeng Fan
Move HUSH_PARSER to defconfig, otherwise meet " => run netboot Booting from net ... Unknown command 'if' - try 'help' Unknown command 'then' - try 'help' Unknown command 'else' - try 'help' Unknown command 'fi' - try 'help' Unknown command '0x80280000' - try 'help' Unknown command 'if' - try 'help' Unknown command 'then' - try 'help' Unknown command 'then' - try 'help' Unknown command 'else' - try 'help' Unknown command 'fi' - try 'help' Unknown command 'else' - try 'help' Unknown command 'fi' - try 'help' " Signed-off-by: Peng Fan <peng.fan@nxp.com>
2019-04-25imx8qxp: mek: Enable CMD_FUSEPeng Fan
Enable CMD_FUSE for i.MX8QXP MEK Signed-off-by: Peng Fan <peng.fan@nxp.com>
2019-02-07configs: Resync with savedefconfigTom Rini
2019-01-28imx8qxp: mek: default enable SPLPeng Fan
Enable SPL for i.MX8QXP MEK, and currently use SPL FIT. The SPL enable SPL_DM to use MMC/PINCTRL/POWER DOMAIN/CLK. Note: SPL FIT could not support secure boot chain, because i.MX8/8X only support i.MX container format. This container format has not been upstreamed, so we use FIT for now. When SPL container supported, we could switch to that. Signed-off-by: Peng Fan <peng.fan@nxp.com>
2018-11-14Revert "imx8qxp_mek: Disable CONFIG_DISPLAY_CPUINFO"Bin Meng
This reverts commit c5bbfaf05dc8592b479a44df6abaadbab54fec2b. Disabling CONFIG_DISPLAY_CPUINFO was a temporary solution to get the v2018.11 release out. Now the merge window opens, revert it. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-11-13configs: Resync with savedefconfigTom Rini
2018-11-07imx8qxp_mek: Disable CONFIG_DISPLAY_CPUINFOBin Meng
Due to revert of commit c0434407b595, this board does not build any more. Disable CONFIG_DISPLAY_CPUINFO for v2018.11 release. This commit should be reverted after v2018.11 release. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-10-22imx: imx8qxp_mek: update to build image in U-BootPeng Fan
Update README Add imximage.cfg Update defconfig to include imximage.cfg Signed-off-by: Peng Fan <peng.fan@nxp.com>
2018-10-22imx: add i.MX8QXP MEK board supportPeng Fan
Add i.MX8QXP MEK board support Enabled pinctrl/clk/power-domain/mmc/i2c/fec driver. Added README file. Signed-off-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Anatolij Gustschin <agust@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com>
