As the M4 use different DDR memory size in normal android/car2 and car
image, use different defconfig for car2 to decrease DDR memory
reservation. So memory reserved for each M4 core is 8MB in car2 and
normal android image. it's 32MB for car image.
Change-Id: Idf608f539cd614a154c78e3a1af28eff1da5c1f2
Signed-off-by: Zhang Bo <bo.zhang@nxp.com>
Enable the SPL SDP driver and USB driver in MEK board codes and defconfigs.
Because the USB driver needs larger malloc pool, increase the malloc size
and disable simple malloc
Signed-off-by: Ye Li <ye.li@nxp.com>
This reverts commit af92ba299b2b87cde02bbd4f534f1a30b45552cd.
Disable the CONFIG_DM_DEVICE_REMOVE will cause device_remove function
do nothing. But it is needed by some drivers like usb, mmc, sf. When
running "usb start" then "usb stop", it does not stop the usb, and cause
problem to next "usb start".
Enable the mtest command and add relevant configurations for tested memory
range.
(cherry picked from commit 4bfe6f1e7527921d9f02dbd37eea8924dd6d3336)
Add fastboot relevant configurations and update mfgtool environments
to support uuu.
Set SMC fuse mechanism as default for QX/QM configs to enable
writing to fuses by default.
Signed-off-by: Teo Hall <teo.hall@nxp.com>
In u-boot 2018, all DM devices will be removed before jumping to kernel.
It executes after the board_quiesce_devices where we turn off the power
domain of the devices used in u-boot. Thus, this cause crash when removing
DM devies.
This patch disables the CONFIG_DM_DEVICE_REMOVE, since it is useless for imx8
and is not compatibled with current power domain implemenation.
Acked-by: Peng Fan <peng.fan@nxp.com>
The u-boot does not support to use two different gadget drivers at same time.
So for all iMX8QM/QXP MEK and ARM2 defconfigs, enable the CDNS3 usb gadget
to support device mode on typec port and disable CI UDC driver for OTG port.
Reviewed-by: Peng Fan <peng.fan@nxp.com>
(cherry picked from commit 29625003b8d8f96f25d8a9f530db5c95f5ce2a8a)
Added default environment for hdp loading.
Added hdp loading as default for iMX8QM ARM2 and MEK boards.
Signed-off-by: Oliver Brown <oliver.brown@nxp.com>
(cherry picked from commit 432e5b4347841095c3b5a8a0d106f35deadd006e)
There is eMMC5.0 chip on imx8qm ARM2 and MEK boards, enable the HS400
support and SD3.0 SDR104 support.
Add board level codes and configs for i.MX8QM MEK board.
- Enabled DM driver:
FEC, LPUART, LPI2C, GPIO, SD/MMC, FSPI, pinctrl, USB host(EHCI/XHCI)
Power-domain, SC thermal
- Enabled Non-DM driver:
SATA, PCIE, fuse, iomux, video(IMXDPUV1), USB device(CI-UDC)
- Disabled driver:
mailbox
- Board defconfigs:
imx8qm_mek_defconfig
imx8qm_mek_fspi_defconfig
