path: root/configs/imx8qm_mek_defconfig
2019-05-18CONFIG_SPL_SYS_[DI]CACHE_OFF: addTrevor Woerner
While converting CONFIG_SYS_[DI]CACHE_OFF to Kconfig, there are instances where these configuration items are conditional on SPL. This commit adds SPL variants of these configuration items, uses CONFIG_IS_ENABLED(), and updates the configurations as required. Acked-by: Alexey Brodkin <abrodkin@synopsys.com> Signed-off-by: Trevor Woerner <trevor@toganlabs.com> [trini: Make the default depend on the setting for full U-Boot, update more zynq hardware] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-04-25imx: support i.MX8QM MEK boardPeng Fan
Add i.MX8QM MEK board support. Included a basic dts, enabled SPL FIT Boot log as below: U-Boot SPL 2019.01-rc1-00029-gf002213219 (Dec 24 2018 - 10:28:30 +0800) Normal Boot Trying to boot from MMC2_2 U-Boot 2019.01-rc1-00029-gf002213219 (Dec 24 2018 - 10:28:30 +0800) CPU: NXP i.MX8QM RevB A53 at 142933 MHz Model: Freescale i.MX8QM MEK Board: iMX8QM MEK Build: SCFW 9330215b Boot: SD1 DRAM: 6 GiB MMC: FSL_SDHC: 0, FSL_SDHC: 1 Loading Environment from MMC... *** Warning - bad CRC, using default environment In: serial@5a060000 Out: serial@5a060000 Err: serial@5a060000 Net: Error: ethernet@5b040000 address not set. eth-1: ethernet@5b040000 Hit any key to stop autoboot: 0 Signed-off-by: Peng Fan <peng.fan@nxp.com>
