path: root/configs/imx8mq_ddr3l_arm2_defconfig
2018-09-10MLK-19524: configs: add fastboot support for nand u-bootHan Xu
add fastboot support for nand u-boot. 1. Add fastboot related configs 2. enlarge the SPL size for i.MX8MQ DDR4 NAND config 3. include the imx_env for boot command settings Signed-off-by: Han Xu <han.xu@nxp.com>
2018-08-28MLK-18901-2 imx8mq: Enable mtest command for ARM2 and EVK boardsYe Li
Enable the mtest command and add relevant configurations for tested memory range to all ARM2 boards and EVK board. Signed-off-by: Ye Li <ye.li@nxp.com> (cherry picked from commit bb3dfa130dd0af57dfe7a41869f6ecd843e6c558)
2018-04-27MLK-17109-4 imx8mq_arm2: Add i.MX8MQ DDR3L and DDR4 ARM2 boards supportYe Li
Add board codes, configurations, DTS and DDR initialization codes for the DDR3L and DDR4 ARM2 boards. Supported modules - DDR3L ARM2: Two RANK DDR3L, QSPI B, eMMC/SD, RMII ENET, UART. - DDR4 ARM2: Two RANK DDR4, SD, NAND, RGMII ENET, UART. NAND read/write/erase is ok in u-boot, NAND SPL boot will be tested later when tool is ready. Signed-off-by: Ye Li <ye.li@nxp.com> Acked-by: Peng Fan <peng.fan@nxp.com>
