CONFIG_SYS_BOOTM_LEN
As part of this, rework error handling in boot/bootm.c so that we pass
the buffer size to handle_decomp_error as CONFIG_SYS_BOOTM_LEN will not
be available to host tools but we do know the size that we passed to
malloc().
Cc: Soeren Moch <smoch@web.de>
CONFIG_SYS_SPL_MALLOC_SIZE
CONFIG_SYS_SPL_MALLOC_START
We introduce a default value here as well, and CONFIG_SYS_SPL_MALLOC to
control if we have a malloc pool or not.
CONFIG_SPL_BSS_START_ADDR
CONFIG_SPL_STACK
CONFIG_SPL_BSS_MAX_SIZE
CONFIG_SPL_MAX_FOOTPRINT
Note that the da850evm platforms were violating the "only use one" rule
here, and so now hard-code their BSS limit.
CONFIG_SPL_PAD_TO
CONFIG_SPL_MAX_SIZE
CONFIG_TPL_PAD_TO
CONFIG_TPL_MAX_SIZE
Note that we need to make TPL_MAX_SIZE be hex, and so move and convert the
existing places.
CONFIG_SYS_CBSIZE
CONFIG_SYS_PBSIZE
CONFIG_SYS_MAXARGS
Enable CONFIG_DM_SERIAL. uart2 and its pinmux was already
marked with u-boot,dm-spl.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
Reviewed-by: Fabio Estevam <festevam@denx.de>
There is no reason for disabling I-cache and D-cache
in SPL.
Remove the unneeded CONFIG_SPL_SYS_ICACHE_OFF and
CONFIG_SPL_SYS_DCACHE_OFF options.
Signed-off-by: Fabio Estevam <festevam@denx.de>
Resync all defconfig files using moveconfig.py
CONFIG_ETHPRIME
This is also done by adding a gating Kconfig option, CONFIG_USE_ETHPRIME
similar to other options that are not always set and control environment
variables.
As the CI test for stopping platforms from being merged that were
defining symbols that had Kconfig entries, a small number of symbols
needed to be migrated again. Do so, and catch two cases the README
should also have been updated but was not.
Add initial support for Advantech RSB-3720 board.
The initial support includes:
- MMC
- eMMC
- I2C
- FEC
- Serial console
Signed-off-by: Darren Huang <darren.huang@advantech.com.tw>
Signed-off-by: Kevin12.Chen <Kevin12.Chen@advantech.com.tw>
Signed-off-by: Phill.Liu <Phill.Liu@advantech.com.tw>
Signed-off-by: Tim Liang <tim.liang@advantech.com.tw>
Signed-off-by: wei.zeng <wei.zeng@advantech.com.cn>
Signed-off-by: Ying-Chun Liu (PaulLiu) <paul.liu@linaro.org>
Cc: uboot-imx <uboot-imx@nxp.com>
Cc: Peng Fan (OSS) <peng.fan@oss.nxp.com>
