Android does not use usb host function in uboot, and also TCPC function
failure may cause the fastboot does not work, remove all CONFIG_USB_TCPC
configuration items so TCPC is not used in uboot.
Change-Id: I8c54e144517160bd7234a8ae28c6bc83734be538
Signed-off-by: faqiang.zhu <faqiang.zhu@nxp.com>
To align with other iMX8M platforms, use CONFIG_TARGET_IMX8MN_DDR4_EVK for
DDR4 EVK board and will use CONFIG_TARGET_IMX8MN_EVK for LPDDR4 EVK.
Signed-off-by: Ye Li <ye.li@nxp.com>
The u-boot-spl.bin is getting larger and it will break the ddr
firmware which will cause ddr training fail. Disable unnecessary
configs for imx8mn to reduce the spl image size.
Test: boot on imx8mn_evk.
Change-Id: Id105b0adf8669e471752495f78012314efad24c0
Signed-off-by: Ji Luo <ji.luo@nxp.com>
Open configs to enable dual bootloader feature for imx8m
platforms.
Test: A/B slot switch and spl recovery mode test.
Change-Id: I3fe0217c858b4cb1e06bd76f829a4f8977370cde
Duplicate configs to enable dual bootloader for imx8m.
Change-Id: I4e03b73dc42f036e0c8d477ce5d2a6892ac2938c
