path: root/configs/imx8mm_beacon_defconfig
2020-07-06configs: Resync with savedefconfigTom Rini
2020-06-08imx8mm_beacon: Select the watchdog driverFabio Estevam
Currently watchdog driver is not selected, which causes system to reboot after staying 60s in the U-Boot prompt. Fix this problem by enabling CONFIG_WATCHDOG so that watchdog can be properly serviced. Signed-off-by: Fabio Estevam <festevam@gmail.com> Reviewed-by: Adam Ford <aford173@gmail.com>
2020-05-10imx: Add support for i.MX8MM Beacon EmbeddedWorks devkit.Adam Ford
Beacon EmbeddedWorks, formerly known as Logic PD, is releasing a devkit based on the i.MX8M Mini SoC consisting of baseboard + SOM. It supports eMMC on the SOM, microSD on the baseboard, various GPIO, the PINCTRL, and UART. Signed-off-by: Adam Ford <aford173@gmail.com>
