path: root/configs/imx6ul_isiot_nand_defconfig
2017-11-27i.MX6: engicam: Add imx6q/imx6ul boards for existing boardsJagan Teki
Add new board names for existing board support imx6q - icore and icore_rqs boards imx6ul - geam6ul and isiot boards Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2017-10-30imx: Fix regression with CONFIG_DM_MMC=yFabio Estevam
When CONFIG_DM_MMC=y, CONFIG_BLK should be selected, otherwise the SD/eMMC card cannot be used. Also, select CONFIG_DM_USB=y when CONFIG_USB=y to avoid build failure. Tested on mx6slevk, mx7dsabresd and mx6ullevk. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com> Tested-by: Adam Ford <aford173@gmail.com> Tested-by: Sébastien Szymanski <sebastien.szymanski@armadeus.com> Tested-by: Jagan Teki <jagan@openedev.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-08-17dm: imx: Move i.MX devices to use CONFIG_DM_MMC_OPSSimon Glass
Now that the driver supports it, move these boards over to use driver model fully for MMC. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-12Convert CONFIG_NAND to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_NAND Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Sync up a few more, add imply's] Signed-off-by: Tom Rini <trini@konsulko.com>
Change is consistent with other SOCs and it is in preparation for adding SOMs. SOC's related files are moved from cpu/ to mach-imx/<SOC>. This change is also coherent with the structure in kernel. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Fabio Estevam <fabio.estevam@nxp.com> CC: Akshay Bhat <akshaybhat@timesys.com> CC: Ken Lin <Ken.Lin@advantech.com.tw> CC: Marek Vasut <marek.vasut@gmail.com> CC: Heiko Schocher <hs@denx.de> CC: "Sébastien Szymanski" <sebastien.szymanski@armadeus.com> CC: Christian Gmeiner <christian.gmeiner@gmail.com> CC: Stefan Roese <sr@denx.de> CC: Patrick Bruenn <p.bruenn@beckhoff.com> CC: Troy Kisky <troy.kisky@boundarydevices.com> CC: Nikita Kiryanov <nikita@compulab.co.il> CC: Otavio Salvador <otavio@ossystems.com.br> CC: "Eric Bénard" <eric@eukrea.com> CC: Jagan Teki <jagan@amarulasolutions.com> CC: Ye Li <ye.li@nxp.com> CC: Peng Fan <peng.fan@nxp.com> CC: Adrian Alonso <adrian.alonso@nxp.com> CC: Alison Wang <b18965@freescale.com> CC: Tim Harvey <tharvey@gateworks.com> CC: Martin Donnelly <martin.donnelly@ge.com> CC: Marcin Niestroj <m.niestroj@grinn-global.com> CC: Lukasz Majewski <lukma@denx.de> CC: Adam Ford <aford173@gmail.com> CC: "Albert ARIBAUD (3ADEV)" <albert.aribaud@3adev.fr> CC: Boris Brezillon <boris.brezillon@free-electrons.com> CC: Soeren Moch <smoch@web.de> CC: Richard Hu <richard.hu@technexion.com> CC: Wig Cheng <wig.cheng@technexion.com> CC: Vanessa Maegima <vanessa.maegima@nxp.com> CC: Max Krummenacher <max.krummenacher@toradex.com> CC: Stefan Agner <stefan.agner@toradex.com> CC: Markus Niebel <Markus.Niebel@tq-group.com> CC: Breno Lima <breno.lima@nxp.com> CC: Francesco Montefoschi <francesco.montefoschi@udoo.org> CC: Jaehoon Chung <jh80.chung@samsung.com> CC: Scott Wood <oss@buserror.net> CC: Joe Hershberger <joe.hershberger@ni.com> CC: Anatolij Gustschin <agust@denx.de> CC: Simon Glass <sjg@chromium.org> CC: "Andrew F. Davis" <afd@ti.com> CC: "Łukasz Majewski" <l.majewski@samsung.com> CC: Patrice Chotard <patrice.chotard@st.com> CC: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> CC: Hans de Goede <hdegoede@redhat.com> CC: Masahiro Yamada <yamada.masahiro@socionext.com> CC: Stephen Warren <swarren@nvidia.com> CC: Andre Przywara <andre.przywara@arm.com> CC: "Álvaro Fernández Rojas" <noltari@gmail.com> CC: York Sun <york.sun@nxp.com> CC: Xiaoliang Yang <xiaoliang.yang@nxp.com> CC: Chen-Yu Tsai <wens@csie.org> CC: George McCollister <george.mccollister@gmail.com> CC: Sven Ebenfeld <sven.ebenfeld@gmail.com> CC: Filip Brozovic <fbrozovic@gmail.com> CC: Petr Kulhavy <brain@jikos.cz> CC: Eric Nelson <eric@nelint.com> CC: Bai Ping <ping.bai@nxp.com> CC: Anson Huang <Anson.Huang@nxp.com> CC: Sanchayan Maity <maitysanchayan@gmail.com> CC: Lokesh Vutla <lokeshvutla@ti.com> CC: Patrick Delaunay <patrick.delaunay@st.com> CC: Gary Bisson <gary.bisson@boundarydevices.com> CC: Alexander Graf <agraf@suse.de> CC: u-boot@lists.denx.de Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Christian Gmeiner <christian.gmeiner@gmail.com>
2017-07-10configs: Resync defconfigsTom Rini
2017-06-27Merge git://www.denx.de/git/u-boot-imxTom Rini
Signed-off-by: Tom Rini <trini@konsulko.com> Conflicts: include/configs/imx6qdl_icore_rqs.h include/configs/imx6ul_geam.h include/configs/imx6ul_isiot.h
2017-05-31Kconfig: Finish migration of hashing commandsDaniel Thompson
Currently these (board agnostic) commands cannot be selected using menuconfig and friends. Fix this the obvious way. As part of this, don't muddle the meaning of CONFIG_HASH_VERIFY to mean both 'hash -v' and "we have a hashing command" as this makes the Kconfig logic odd. Signed-off-by: Daniel Thompson <daniel.thompson@linaro.org> [trini: Re-apply, add imply for a few cases, run moveconfig.py, also migrate CRC32_VERIFY] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-31engicam: Move PHY configs to defconfigJagan Teki
- CONFIG_PHYLIB - CONFIG_PHY_SMSC - CONFIG_PHY_MICREL - CONFIG_PHY_MICREL_KSZ9021 Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2017-05-18engicam: Set fdt_file env during run-timeJagan Teki
Set fdt_file env variable during board_late_init Cc: Stefano Babic <sbabic@denx.de> Cc: Matteo Lisi <matteo.lisi@engicam.com> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2017-04-30Convert CONFIG_CMD_BMODE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_BMODE Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Make this default y and depend on mx5/6/7] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-03-26configs: imx6: Select missing BOARD_LATE_INITJagan Teki
Select missing BOARD_LATE_INIT from configs/ to respective targets on arch area for Engicam imx6 boards. Cc: Tom Rini <trini@konsulko.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2017-03-17i.MX6UL: isiot: Add modeboot env via board_late_initJagan Teki
Add runtime, modeboot env which is setting mmcboot, or nandboot based on the bootdevice so-that conditional macros b/w MMC and NAND for CONFIG_BOOTCOMMAND should be avoided in config files. Cc: Matteo Lisi <matteo.lisi@engicam.com> Cc: Michael Trimarchi <michael@amarulasolutions.com> Reviewed by: Stefano Babic <sbabic@denx.de> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2017-03-17imx6ul: isiotmx6ul: Enable I2C supportJagan Teki
Enable I2C support for Engicam Is.IoT NAND module. Cc: Stefano Babic <sbabic@denx.de> Cc: Matteo Lisi <matteo.lisi@engicam.com> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2017-03-17imx6: isiotmx6ul: Add nandboot env supportJagan Teki
Add config options for booting Linux from NAND in UBI format. Cc: Stefano Babic <sbabic@denx.de> Cc: Matteo Lisi <matteo.lisi@engicam.com> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2017-03-17imx6: isiotmx6ul: Add NAND supportJagan Teki
Add NAND support for Engicam Is.IoT MX6UL board. Cc: Stefano Babic <sbabic@denx.de> Cc: Matteo Lisi <matteo.lisi@engicam.com> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
