path: root/configs/imx6ul_geam_nand_defconfig
2017-01-02imx6ul: geam6ul: Enable I2C supportJagan Teki
Enable I2C support for Engicam GEAM6UL NAND module. Cc: Stefano Babic <sbabic@denx.de> Cc: Matteo Lisi <matteo.lisi@engicam.com> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2017-01-02defconfigs: imx6: engicam: Enable FITJagan Teki
Enable Flattened Image Tree support for all Engicam boards. Cc: Stefano Babic <sbabic@denx.de> Cc: Matteo Lisi <matteo.lisi@engicam.com> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2017-01-02defconfigs: engicam: Enable UBI commandsJagan Teki
Create ubifs.img: $ mkfs.ubifs -q -r /rootfs -m 4096 -e 253952 -c 7936 -o ubifs.img Write ubifs.img: --------------- icorem6qdl> nand erase.part rootfs icorem6qdl> ubi part rootfs icorem6qdl> ubi create rootfs icorem6qdl> ext4load mmc 0:2 ${loadaddr} ubifs.img 166592512 bytes read in 8091 ms (19.6 MiB/s) icorem6qdl> ubi write ${loadaddr} rootfs ${filesize} 166592512 bytes written to volume rootfs icorem6qdl> ubifsmount ubi0:rootfs Cc: Stefano Babic <sbabic@denx.de> Cc: Matteo Lisi <matteo.lisi@engicam.com> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2017-01-02defconfigs: engicam: Enable MMC commands in nandJagan Teki
For writing Linux or rootfs on to NAND, the best suitable way is to use MMC commands since MMC driver by default enabled by mx6_common.h, hence enabled MMC commands in nand defconfigs. Cc: Stefano Babic <sbabic@denx.de> Cc: Matteo Lisi <matteo.lisi@engicam.com> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2017-01-02imx6: engicam: Use bootm instead of bootzJagan Teki
Boot Linux with uImage instead of zImage, so update bootz with bootm. Cc: Stefano Babic <sbabic@denx.de> Cc: Matteo Lisi <matteo.lisi@engicam.com> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2016-12-16imx6: geam6ul: Add FEC supportJagan Teki
Add FEC support for Engicam GEAM6UL module. Cc: Stefano Babic <sbabic@denx.de> Cc: Matteo Lisi <matteo.lisi@engicam.com> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2016-12-16imx6: geam6ul: Add NAND supportJagan Teki
Add NAND support for Engicam GEAM6UL board. Boot Log: -------- U-Boot SPL 2016.11-g537fa5f (Nov 28 2016 - 11:42:28) Trying to boot from NAND NAND : 256 MiB U-Boot 2016.11-g537fa5f (Nov 28 2016 - 11:20:06 +0100) CPU: Freescale i.MX6UL rev1.1 69 MHz (running at 396 MHz) CPU: Automotive temperature grade (-40C to 125C) at 42C Reset cause: WDOG Model: Engicam GEAM6UL DRAM: 128 MiB NAND: 256 MiB MMC: FSL_SDHC: 0 * Warning - bad CRC, using default environment In: serial Out: serial Err: serial Net: No ethernet found. Hit any key to stop autoboot: 0 Cc: Stefano Babic <sbabic@denx.de> Cc: Matteo Lisi <matteo.lisi@engicam.com> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
