path: root/configs/imx6qsabreautoandroid_defconfig
2018-12-20MA-13785 remove the fastboot command of ucmd and acmdfaqiang.zhu
To avoid end user executing uboot command through fastboot, the fastboot command of "ucmd" and "acmd" in the uboot to be flashed into non-volatile storage device is removed in this partch. Change-Id: I999b8688a53c2201d02979be68266afc110dfb15 Signed-off-by: faqiang.zhu <faqiang.zhu@nxp.com>
2018-06-13MLK-18591-7 android: Add mx6/7 reference board support to enable android ↵Ye Li
fastboot Add board level support for android fastboot feature. Each board has a android specified header file for defining android related configuraitons. And add build targets for their android uboot images building. Signed-off-by: Ye Li <ye.li@nxp.com>
