Rename these options so that CONFIG_IS_ENABLED can be used with them.
Rename this option so that CONFIG_IS_ENABLED can be used with it.
We have a number of platforms that are a combination of a carrier board
and System-on-Module (SoM) that in turn allows for the board to have
different SoCs on it. In some cases, this is handled via board-specific
Kconfig options. In other cases we make use of
CONFIG_SYS_EXTRA_OPTIONS. This latter case however can lead to invalid
configurations as we will not in turn get options that in Kconfig are
selected by or depend on that setting.
To resolve this, make the SoC option a choice in Kconfig and make boards
depend on what they can support. This change opens us up for further
clean-ups in the cases where a single CONFIG_TARGET_xxx can support
different SoCs and today they do not, or do not cleanly do so.
Reported-by: Matt Porter <mporter@konsulko.com>
Cc: Fabio Estevam <festevam@gmail.com>
Cc: "NXP i.MX U-Boot Team" <uboot-imx@nxp.com>
Cc: Soeren Moch <smoch@web.de>
Cc: Markus Niebel <Markus.Niebel@tq-group.com>
Cc: Igor Opaniuk <igor.opaniuk@toradex.com>
Cc: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
Cc: Otavio Salvador <otavio@ossystems.com.br>
Cc: Nikita Kiryanov <nikita@compulab.co.il>
Cc: Andreas Geisreiter <ageisreiter@dh-electronics.de>
Cc: Ludwig Zenz <lzenz@dh-electronics.de>
Cc: Lukasz Majewski <lukma@denx.de>
Cc: Akshay Bhat <akshaybhat@timesys.com>
Cc: Ken Lin <Ken.Lin@advantech.com.tw>
Cc: Ian Ray <ian.ray@ge.com>
Cc: Tim Harvey <tharvey@gateworks.com>
Cc: Jagan Teki <jagan@amarulasolutions.com>
Cc: Raffaele RECALCATI <raffaele.recalcati@bticino.it>
Cc: Simone CIANNI <simone.cianni@bticino.it>
Cc: Adam Ford <aford173@gmail.com>
Cc: Marcin Niestroj <m.niestroj@grinn-global.com>
Cc: "Eric Bénard" <eric@eukrea.com>
Cc: Baruch Siach <baruch@tkos.co.il>
Cc: Jason Liu <jason.hui.liu@nxp.com>
Cc: Ye Li <ye.li@nxp.com>
Cc: Eric Nelson <eric@nelint.com>
Cc: Troy Kisky <troy.kisky@boundarydevices.com>
Cc: Peng Fan <peng.fan@nxp.com>
Cc: Parthiban Nallathambi <parthiban@linumiz.com>
Cc: "Sébastien Szymanski" <sebastien.szymanski@armadeus.com>
Cc: Christian Gmeiner <christian.gmeiner@gmail.com>
Cc: Niel Fourie <lusus@denx.de>
Cc: Martyn Welch <martyn.welch@collabora.com>
Cc: Richard Hu <richard.hu@technexion.com>
Cc: Stefan Roese <sr@denx.de>
Cc: Boris Brezillon <bbrezillon@kernel.org>
Cc: Arkadiusz Karas <arkadiusz.karas@somlabs.com>
Cc: Breno Lima <breno.lima@nxp.com>
Cc: Francesco Montefoschi <francesco.montefoschi@udoo.org>
Cc: Silvio Fricke <open-source@softing.de>
Tested-by: Matt Porter <mporter@konsulko.com> [colibri_imx6]
Reviewed-by: Marcin Niestroj <m.niestroj@grinn-global.com>
At present we use the empty string to indicate that there is no FIT
generator, but this doesn't allow an individual board to undefine it.
Create a separate bool instead.
Update the config of the boards which currently have an empty string.
CONFIG_ENV_OVERWRITE
[trini: Rerun migration, remove some comments]
CONFIG_CMD_ASKENV
CONFIG_CMD_BMP
CONFIG_CMD_BOOTD
CONFIG_CMD_CACHE
CONFIG_CMD_CRC32
CONFIG_CMD_DHCP
CONFIG_CMD_ENV
CONFIG_CMD_EXPORTENV
CONFIG_CMD_EXT2
CONFIG_CMD_EXT4
CONFIG_CMD_FLASH
CONFIG_CMD_FS_GENERIC
CONFIG_CMD_FUSE
CONFIG_CMD_GPIO
CONFIG_CMD_GPT
CONFIG_CMD_GREPENV
CONFIG_CMD_I2C
CONFIG_CMD_IMLS
CONFIG_CMD_IMPORTENV
CONFIG_CMD_LOADB
CONFIG_CMD_LOADS
CONFIG_CMD_MEMINFO
CONFIG_CMD_MII
CONFIG_CMD_MTDPARTS
CONFIG_CMD_NAND
CONFIG_CMD_NAND_TRIMFFS
CONFIG_CMD_NFS
CONFIG_CMD_PCA953X
CONFIG_CMD_PCA953X_INFO
CONFIG_CMD_PCI
CONFIG_CMD_PING
CONFIG_CMD_READ
CONFIG_CMD_SF
CONFIG_CMD_SPI
CONFIG_CMD_SPL
CONFIG_CMD_SPL_WRITE_SIZE
CONFIG_CMD_TIME
CONFIG_CMD_TRACE
CONFIG_CMD_UBI
CONFIG_CMD_UBIFS
CONFIG_CMD_UNZIP
CONFIG_FS_EXT4
Move below defines which are used by mtest utility to Kconfig.
CONFIG_SYS_MEMTEST_START
CONFIG_SYS_MEMTEST_END
Signed-off-by: Ashok Reddy Soma <ashok.reddy.soma@xilinx.com>
[trini: Fix kmcoge5ne board, re-run migration as well]
Like in Linux, just use CONFIG_MTD to compile the MTD stack.
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
CONFIG_FSL_USDHC
[trini: Add IMX8M, TARGET_S32V234EVB to FSL_USDHC list]
The name CONFIG_LEGACY_IMAGE_FORMAT reads slightly better along with
allowing us to avoid a rather nasty Kbuild/Kconfig issue down the line
with CONFIG_IS_ENABLED(IMAGE_FORMAT_LEGACY). In a few places outside of
cmd/ switch to using CONFIG_IS_ENABLED() to test what is set.
Converted to use fsl_esdhc_imx for i.MX platforms.
Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com>
Tested-by: Steffen Dirkwinkel <s.dirkwinkel@beckhoff.com>
Reviewed-by: Peng Fan <peng.fan@nxp.com>
Reviewed-by: Lukasz Majewski <lukma@denx.de>
Reviewed-by: Martyn Welch <martyn.welch@collabora.com>
Acked-by: Jason Liu <Jason.hui.liu@nxp.com>
Commit d397f7c45b0b ("net: phy: micrel: Separate KSZ9000 drivers from
KSZ8000 drivers") separated the KSZ8xxx and KSZ90x1 drivers and warns
that you shouldn't select both of them due to a device ID clash between
the KSZ9021 and the KS8721, asserting that "it is highly unlikely for a
system to contain both a KSZ8000 and a KSZ9000 PHY". Unfortunately
boards like the SAMA5D3xEK do contain both types of PHY, but fortunately
the Linux Micrel PHY driver provides a solution by using different PHY
ID and mask values to distinguish these chips.
This commit contains the following changes:
- The PHY ID and mask values for the KSZ9021 and the KS8721 now match
those used by the Linux driver.
- The warnings about not enabling both drivers have been removed.
- The description for PHY_MICREL_KSZ8XXX has been corrected (these are
10/100 PHYs, not GbE PHYs).
- PHY_MICREL_KSZ9021 and PHY_MICREL_KSZ9031 no longer select PHY_GIGE
since this is selected by PHY_MICREL_KSZ90X1.
- All of the relevant defconfig files have been updated now that
PHY_MICREL_KSZ8XXX does not default to 'Y'.
Signed-off-by: James Byrne <james.byrne@origamienergy.com>
Moved CONFIG_SPL_TEXT_BASE to common/spl/Kconfig and migrate existing
values.
Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
[trini: Re-run migration]
The bounce buffer is used by a few drivers (most of the MMC drivers)
to overcome limitations in their respective DMA implementation.
This moves the configuration to Kconfig and makes it user-selectable
(even though it will be a required feature to make those drivers
work): the expected usage is for drivers depending on this to 'select'
it unconditionally from their respective Kconfig (see follow-up
patches).
This commit includes a full migration using moveconfig.py to ensure
that each commit compiles. To ensure bisectability we update
dependencies of various drivers to now select BOUNCE_BUFFER when needed.
[trini: Squash all patches to ensure bisectability]
Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Reviewed-by: Otavio Salvador <otavio@ossystems.com.br> [dw_mmc portion]
Reviewed-by: Fabio Estevam <festevam@gmail.com> [mxsmmc portion]
Reviewed-by: Simon Glass <sjg@chromium.org> [tegra portion]
CONFIG_MII
CONFIG_DRIVER_TI_EMAC
Acked-by: Jagan Teki <jagan@amarulasolutions.com>
We have the following cases:
- CONFIG_NR_DRAM_BANKS was defined, migrate normally
- CONFIG_NR_DRAM_BANKS_MAX was defined and then used for
CONFIG_NR_DRAM_BANKS after a check, just migrate it over now.
- CONFIG_NR_DRAM_BANKS was very oddly defined on p2771-0000-* (to 1024 +
2), set this to 8.
This converts IMAGE_FORMAT_LEGACY to Kconfig
Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
Migrate the CONFIG_FSL_ESDHC option to Kconfig.
Signed-off-by: Mario Six <mario.six@gdsys.cc>
CONFIG_BOOTP_BOOTPATH
CONFIG_BOOTP_DNS
CONFIG_BOOTP_GATEWAY
CONFIG_BOOTP_HOSTNAME
CONFIG_BOOTP_PXE
CONFIG_BOOTP_SUBNETMASK
CONFIG_CMDLINE_EDITING
CONFIG_AUTO_COMPLETE
CONFIG_SYS_LONGHELP
CONFIG_SUPPORT_RAW_INITRD
CONFIG_ENV_VARS_UBOOT_CONFIG
[trini: Re-run the migration]
Currently SPL_LOAD_FIT is unable to boot from nand on
i.MX6QDL platform, so enable only for MMC boards.
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
i.MX6 boards still using raw MMC write for SPL and
u-boot-dtb.img along with Falcon mode configurations,
so drop filesystem based write through SPL_EXT_SUPPORT.
On the NIOS2 and Xtensa architectures, we do not have
CONFIG_SYS_TEXT_BASE set. This is a strict migration of the current
values into the defconfig and removing them from the headers.
I did not attempt to add more default values in and for now will leave
that to maintainers.
Add new board names for existing board support
imx6q - icore and icore_rqs boards
imx6ul - geam6ul and isiot boards
Add OF_CONTROL support for SPL code.
Fix for finding mmc devices on i.MX6Q icore boards
added in below comment
"icorem6: Fix to find MMC devices"
(sha1: a2b137b38d925df91afef52f5122927de024f81a)
which is reverted in during u-boot-imx merge
" Merge git://git.denx.de/u-boot-imx"
(sha1: 6aee2ab68c362ace5a59f89a63abed82e0bf19e5)
This patch, is recreated to fix merge conflict.
Having this as a 'default y' is rather annoying because it doesn't
actually compile unless other options are defined in the board header:
../cmd/bootm.c: In function 'do_imls_nor':
../cmd/bootm.c:330:7: error: 'CONFIG_SYS_MAX_FLASH_BANKS' undeclared (first use in this function); did you mean 'CONFIG_SYS_MAX_FLASH_SECT'?
i < CONFIG_SYS_MAX_FLASH_BANKS; ++i, ++info) {
Make it 'default n' so people who develop new boards that start from a
blank defconfig have one less compilation failure to debug.
Now that the driver supports it, move these boards over to use driver
model fully for MMC.
