CONFIG_BOOTP_BOOTPATH
CONFIG_BOOTP_DNS
CONFIG_BOOTP_GATEWAY
CONFIG_BOOTP_HOSTNAME
CONFIG_BOOTP_PXE
CONFIG_BOOTP_SUBNETMASK
CONFIG_CMDLINE_EDITING
CONFIG_AUTO_COMPLETE
CONFIG_SYS_LONGHELP
CONFIG_SUPPORT_RAW_INITRD
CONFIG_ENV_VARS_UBOOT_CONFIG
[trini: Re-run the migration]
Currently SPL_LOAD_FIT is unable to boot from nand on
i.MX6QDL platform, so enable only for MMC boards.
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
i.MX6 boards still using raw MMC write for SPL and
u-boot-dtb.img along with Falcon mode configurations,
so drop filesystem based write through SPL_EXT_SUPPORT.
On the NIOS2 and Xtensa architectures, we do not have
CONFIG_SYS_TEXT_BASE set. This is a strict migration of the current
values into the defconfig and removing them from the headers.
I did not attempt to add more default values in and for now will leave
that to maintainers.
Enable nand on mmc defconfig, so-that preparing nand
for writing/updating bootimage, Linux becomes easy.
Add new board names for existing board support
imx6q - icore and icore_rqs boards
imx6ul - geam6ul and isiot boards
Add OF_CONTROL support for SPL code.
Fix for finding mmc devices on i.MX6Q icore boards
added in below comment
"icorem6: Fix to find MMC devices"
(sha1: a2b137b38d925df91afef52f5122927de024f81a)
which is reverted in during u-boot-imx merge
" Merge git://git.denx.de/u-boot-imx"
(sha1: 6aee2ab68c362ace5a59f89a63abed82e0bf19e5)
This patch, is recreated to fix merge conflict.
Having this as a 'default y' is rather annoying because it doesn't
actually compile unless other options are defined in the board header:
../cmd/bootm.c: In function 'do_imls_nor':
../cmd/bootm.c:330:7: error: 'CONFIG_SYS_MAX_FLASH_BANKS' undeclared (first use in this function); did you mean 'CONFIG_SYS_MAX_FLASH_SECT'?
i < CONFIG_SYS_MAX_FLASH_BANKS; ++i, ++info) {
Make it 'default n' so people who develop new boards that start from a
blank defconfig have one less compilation failure to debug.
configs/imx6qdl_icore_mmc_defconfig
configs/imx6qdl_icore_rqs_defconfig
Add Falcon mode support in Engicam i.CoreM6 board.
U-Boot proper is using DM_MMC so, enable CONFIG_BLK otherwise
find_mmc_device failed to detect MMC device.
Reviewed-by: Stefano Babic <sbabic@denx.de>
Now that the driver supports it, move these boards over to use driver
model fully for MMC.
CONFIG_ENV_IS_IN_MMC
CONFIG_ENV_IS_IN_NAND
CONFIG_ENV_IS_IN_UBI
CONFIG_ENV_IS_NOWHERE
In fact this already exists for sunxi as a 'choice' config. However not
all the choices are available in Kconfig yet so we cannot use that. It
would lead to more than one option being set.
In addition, one purpose of this series is to allow the environment to be
stored in more than one place. So the existing choice is converted to a
normal config allowing each option to be set independently.
There are not many opportunities for Kconfig updates to reduce the size of
this patch. This was tested with
./tools/moveconfig.py -i CONFIG_ENV_IS_IN_MMC
And then manual updates. This is because for CHAIN_OF_TRUST boards they
can only have ENV_IS_NOWHERE set, so we enforce that via Kconfig logic
now.
Change is consistent with other SOCs and it is in preparation
for adding SOMs. SOC's related files are moved from cpu/ to
mach-imx/<SOC>.
This change is also coherent with the structure in kernel.
CC: Fabio Estevam <fabio.estevam@nxp.com>
CC: Akshay Bhat <akshaybhat@timesys.com>
CC: Ken Lin <Ken.Lin@advantech.com.tw>
CC: Marek Vasut <marek.vasut@gmail.com>
CC: Heiko Schocher <hs@denx.de>
CC: "Sébastien Szymanski" <sebastien.szymanski@armadeus.com>
CC: Christian Gmeiner <christian.gmeiner@gmail.com>
CC: Stefan Roese <sr@denx.de>
CC: Patrick Bruenn <p.bruenn@beckhoff.com>
CC: Troy Kisky <troy.kisky@boundarydevices.com>
CC: Nikita Kiryanov <nikita@compulab.co.il>
CC: Otavio Salvador <otavio@ossystems.com.br>
CC: "Eric Bénard" <eric@eukrea.com>
CC: Jagan Teki <jagan@amarulasolutions.com>
CC: Ye Li <ye.li@nxp.com>
CC: Peng Fan <peng.fan@nxp.com>
CC: Adrian Alonso <adrian.alonso@nxp.com>
CC: Alison Wang <b18965@freescale.com>
CC: Tim Harvey <tharvey@gateworks.com>
CC: Martin Donnelly <martin.donnelly@ge.com>
CC: Marcin Niestroj <m.niestroj@grinn-global.com>
CC: Lukasz Majewski <lukma@denx.de>
CC: Adam Ford <aford173@gmail.com>
CC: "Albert ARIBAUD (3ADEV)" <albert.aribaud@3adev.fr>
CC: Boris Brezillon <boris.brezillon@free-electrons.com>
CC: Soeren Moch <smoch@web.de>
CC: Richard Hu <richard.hu@technexion.com>
CC: Wig Cheng <wig.cheng@technexion.com>
CC: Vanessa Maegima <vanessa.maegima@nxp.com>
CC: Max Krummenacher <max.krummenacher@toradex.com>
CC: Stefan Agner <stefan.agner@toradex.com>
CC: Markus Niebel <Markus.Niebel@tq-group.com>
CC: Breno Lima <breno.lima@nxp.com>
CC: Francesco Montefoschi <francesco.montefoschi@udoo.org>
CC: Jaehoon Chung <jh80.chung@samsung.com>
CC: Scott Wood <oss@buserror.net>
CC: Joe Hershberger <joe.hershberger@ni.com>
CC: Anatolij Gustschin <agust@denx.de>
CC: Simon Glass <sjg@chromium.org>
CC: "Andrew F. Davis" <afd@ti.com>
CC: "Łukasz Majewski" <l.majewski@samsung.com>
CC: Patrice Chotard <patrice.chotard@st.com>
CC: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
CC: Hans de Goede <hdegoede@redhat.com>
CC: Masahiro Yamada <yamada.masahiro@socionext.com>
CC: Stephen Warren <swarren@nvidia.com>
CC: Andre Przywara <andre.przywara@arm.com>
CC: "Álvaro Fernández Rojas" <noltari@gmail.com>
CC: York Sun <york.sun@nxp.com>
CC: Xiaoliang Yang <xiaoliang.yang@nxp.com>
CC: Chen-Yu Tsai <wens@csie.org>
CC: George McCollister <george.mccollister@gmail.com>
CC: Sven Ebenfeld <sven.ebenfeld@gmail.com>
CC: Filip Brozovic <fbrozovic@gmail.com>
CC: Petr Kulhavy <brain@jikos.cz>
CC: Eric Nelson <eric@nelint.com>
CC: Bai Ping <ping.bai@nxp.com>
CC: Anson Huang <Anson.Huang@nxp.com>
CC: Sanchayan Maity <maitysanchayan@gmail.com>
CC: Lokesh Vutla <lokeshvutla@ti.com>
CC: Patrick Delaunay <patrick.delaunay@st.com>
CC: Gary Bisson <gary.bisson@boundarydevices.com>
CC: Alexander Graf <agraf@suse.de>
CC: u-boot@lists.denx.de
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
Reviewed-by: Christian Gmeiner <christian.gmeiner@gmail.com>
Add support for the debug UART to assist with early debugging.
Enable it for i.CoreM6 as an example.
include/configs/imx6qdl_icore_rqs.h
include/configs/imx6ul_geam.h
include/configs/imx6ul_isiot.h
Currently these (board agnostic) commands cannot be selected using
menuconfig and friends. Fix this the obvious way. As part of this,
don't muddle the meaning of CONFIG_HASH_VERIFY to mean both 'hash -v'
and "we have a hashing command" as this makes the Kconfig logic odd.
Signed-off-by: Daniel Thompson <daniel.thompson@linaro.org>
[trini: Re-apply, add imply for a few cases, run moveconfig.py, also
migrate CRC32_VERIFY]
- CONFIG_PHYLIB
- CONFIG_PHY_SMSC
- CONFIG_PHY_MICREL
- CONFIG_PHY_MICREL_KSZ9021
SPL FIT is able to pick the suitable fdt file for u-boot,
so add that function through board_fit_config_name_match.
Cc: Matteo Lisi <matteo.lisi@engicam.com>
Cc: Michael Trimarchi <michael@amarulasolutions.com>
Rename defconfig files for better compatible with
respective board names and dts files.
Add I2C support for Engicam i.CoreM6 qdl board.
icorem6qdl> i2c bus
Bus 0: i2c@021a0000
Bus 1: i2c@021a4000
Bus 2: i2c@021a8000
icorem6qdl> i2c dev 2
Setting bus to 2
icorem6qdl> i2c speed 100000
Setting bus speed to 100000 Hz
icorem6qdl> i2c probe
Valid chip addresses: 2C
icorem6qdl> i2c md 2C 0xff
00ff: 00 00 00 00 0f f0 01 64 ff ff 00 00 00 00 00 00 .......d........
Acked-by: Heiko Schocher <hs@denx.de>
Add IPUv3 framebuffer support for Engicam i.CoreM6 qdl board.
Use CONFIG_DM_ETH and remove board_eth_init code
from board files.
Cc: Peng Fan <peng.fan@nxp.com>
Add DM_GPIO, DM_MMC support for u-boot and disable for SPL.
Cc: Fabio Estevam <fabio.estevam@nxp.com>
Enable imx6 pinctrl driver support for i.CoreM6.
i.CoreM6 DualLite/Solo modules are system on module solutions
manufactured by Engicam with following characteristics:
CPU NXP i.MX6 DL, 800MHz
RAM 1GB, 32, 64 bit, DDR3-800/1066
NAND SLC,512MB
Power supply Single 5V
MAX LCD RES FULLHD
and more info at
http://www.engicam.com/en/products/embedded/som/sodimm/i-core-m6s-dl-d-q
Add enet support for engicam icorem6 qdl starter kit.
- Add pinmux settings
- Add board_eth_init
TFTP log:
Net: FEC [PRIME]
Hit any key to stop autoboot: 0
icorem6qdl> tftpboot {fdt_addr} imx6dl-icore.dtb
Using FEC device
TFTP from server 192.168.2.96; our IP address is 192.168.2.75
Filename 'imx6dl-icore.dtb'.
Load address: 0x0
Loading: ######
1.3 MiB/s
done
Bytes transferred = 28976 (7130 hex)
CACHE: Misaligned operation at range [00000000, 00007130]
icorem6qdl>
Boot Log for i.CoreM6 DualLite/Solo Starter Kit:
U-Boot SPL 2016.09-rc2-30739-gd1fa290 (Sep 17 2016 - 00:37:46)
Trying to boot from MMC1
U-Boot 2016.09-rc2-30739-gd1fa290 (Sep 17 2016 - 00:37:46 +0530)
CPU: Freescale i.MX6SOLO rev1.3 at 792MHz
CPU: Industrial temperature grade (-40C to 105C) at 31C
Reset cause: POR
DRAM: 256 MiB
MMC: FSL_SDHC: 0
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: CPU Net Initialization Failed
No ethernet found.
switch to partitions #0, OK
mmc0 is current device
reading boot.scr
** Unable to read file boot.scr **
reading zImage
6741808 bytes read in 341 ms (18.9 MiB/s)
Booting from mmc ...
reading imx6dl-icore.dtb
30600 bytes read in 19 ms (1.5 MiB/s)
Booting using the fdt blob at 0x18000000
Using Device Tree in place at 18000000, end 1800a787
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
Boot Log for i.CoreM6 Quad/Dual Starter Kit:
CPU: Freescale i.MX6Q rev1.2 at 792MHz
CPU: Industrial temperature grade (-40C to 105C) at 28C
Reset cause: POR
DRAM: 512 MiB
MMC: FSL_SDHC: 0
In: serial
Out: serial
Err: serial
No ethernet found.
icorem6qdl>
Acked-by: Peng Fan <peng.fan@nxp.com>
