Enable Flattened Image Tree support for all Engicam boards.
Cc: Matteo Lisi <matteo.lisi@engicam.com>
Cc: Michael Trimarchi <michael@amarulasolutions.com>
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
Create ubifs.img:
$ mkfs.ubifs -q -r /rootfs -m 4096 -e 253952 -c 7936 -o ubifs.img
Write ubifs.img:
icorem6qdl> nand erase.part rootfs
icorem6qdl> ubi part rootfs
icorem6qdl> ubi create rootfs
icorem6qdl> ext4load mmc 0:2 ${loadaddr} ubifs.img
166592512 bytes read in 8091 ms (19.6 MiB/s)
icorem6qdl> ubi write ${loadaddr} rootfs ${filesize}
166592512 bytes written to volume rootfs
icorem6qdl> ubifsmount ubi0:rootfs
For writing Linux or rootfs on to NAND, the best suitable way
is to use MMC commands since MMC driver by default enabled by
mx6_common.h, hence enabled MMC commands in nand defconfigs.
Boot Linux with uImage instead of zImage, so update
bootz with bootm.
Generated by "tools/moveconfig -s".
This will make config moves easier.
Rename defconfig files for better compatible with
respective board names and dts files.
