We have a number of platforms that are a combination of a carrier board
and System-on-Module (SoM) that in turn allows for the board to have
different SoCs on it. In some cases, this is handled via board-specific
Kconfig options. In other cases we make use of
CONFIG_SYS_EXTRA_OPTIONS. This latter case however can lead to invalid
configurations as we will not in turn get options that in Kconfig are
selected by or depend on that setting.
To resolve this, make the SoC option a choice in Kconfig and make boards
depend on what they can support. This change opens us up for further
clean-ups in the cases where a single CONFIG_TARGET_xxx can support
different SoCs and today they do not, or do not cleanly do so.
Reported-by: Matt Porter <mporter@konsulko.com>
Cc: Fabio Estevam <festevam@gmail.com>
Cc: "NXP i.MX U-Boot Team" <uboot-imx@nxp.com>
Cc: Soeren Moch <smoch@web.de>
Cc: Markus Niebel <Markus.Niebel@tq-group.com>
Cc: Igor Opaniuk <igor.opaniuk@toradex.com>
Cc: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
Cc: Otavio Salvador <otavio@ossystems.com.br>
Cc: Nikita Kiryanov <nikita@compulab.co.il>
Cc: Andreas Geisreiter <ageisreiter@dh-electronics.de>
Cc: Ludwig Zenz <lzenz@dh-electronics.de>
Cc: Lukasz Majewski <lukma@denx.de>
Cc: Akshay Bhat <akshaybhat@timesys.com>
Cc: Ken Lin <Ken.Lin@advantech.com.tw>
Cc: Ian Ray <ian.ray@ge.com>
Cc: Tim Harvey <tharvey@gateworks.com>
Cc: Jagan Teki <jagan@amarulasolutions.com>
Cc: Raffaele RECALCATI <raffaele.recalcati@bticino.it>
Cc: Simone CIANNI <simone.cianni@bticino.it>
Cc: Adam Ford <aford173@gmail.com>
Cc: Marcin Niestroj <m.niestroj@grinn-global.com>
Cc: "Eric Bénard" <eric@eukrea.com>
Cc: Baruch Siach <baruch@tkos.co.il>
Cc: Jason Liu <jason.hui.liu@nxp.com>
Cc: Ye Li <ye.li@nxp.com>
Cc: Eric Nelson <eric@nelint.com>
Cc: Troy Kisky <troy.kisky@boundarydevices.com>
Cc: Peng Fan <peng.fan@nxp.com>
Cc: Parthiban Nallathambi <parthiban@linumiz.com>
Cc: "Sébastien Szymanski" <sebastien.szymanski@armadeus.com>
Cc: Christian Gmeiner <christian.gmeiner@gmail.com>
Cc: Niel Fourie <lusus@denx.de>
Cc: Martyn Welch <martyn.welch@collabora.com>
Cc: Richard Hu <richard.hu@technexion.com>
Cc: Stefan Roese <sr@denx.de>
Cc: Boris Brezillon <bbrezillon@kernel.org>
Cc: Arkadiusz Karas <arkadiusz.karas@somlabs.com>
Cc: Breno Lima <breno.lima@nxp.com>
Cc: Francesco Montefoschi <francesco.montefoschi@udoo.org>
Cc: Silvio Fricke <open-source@softing.de>
Tested-by: Matt Porter <mporter@konsulko.com> [colibri_imx6]
Reviewed-by: Marcin Niestroj <m.niestroj@grinn-global.com>
CONFIG_SYS_MMC_ENV_DEV
CONFIG_SYS_MMC_ENV_PART
Note that with this conversion we now have consistent behavior with
respect to ensuring that we have always selected the correct MMC
device and hardware partition.
CONFIG_ENV_OVERWRITE
[trini: Rerun migration, remove some comments]
CONFIG_CMD_ASKENV
CONFIG_CMD_BMP
CONFIG_CMD_BOOTD
CONFIG_CMD_CACHE
CONFIG_CMD_CRC32
CONFIG_CMD_DHCP
CONFIG_CMD_ENV
CONFIG_CMD_EXPORTENV
CONFIG_CMD_EXT2
CONFIG_CMD_EXT4
CONFIG_CMD_FLASH
CONFIG_CMD_FS_GENERIC
CONFIG_CMD_FUSE
CONFIG_CMD_GPIO
CONFIG_CMD_GPT
CONFIG_CMD_GREPENV
CONFIG_CMD_I2C
CONFIG_CMD_IMLS
CONFIG_CMD_IMPORTENV
CONFIG_CMD_LOADB
CONFIG_CMD_LOADS
CONFIG_CMD_MEMINFO
CONFIG_CMD_MII
CONFIG_CMD_MTDPARTS
CONFIG_CMD_NAND
CONFIG_CMD_NAND_TRIMFFS
CONFIG_CMD_NFS
CONFIG_CMD_PCA953X
CONFIG_CMD_PCA953X_INFO
CONFIG_CMD_PCI
CONFIG_CMD_PING
CONFIG_CMD_READ
CONFIG_CMD_SF
CONFIG_CMD_SPI
CONFIG_CMD_SPL
CONFIG_CMD_SPL_WRITE_SIZE
CONFIG_CMD_TIME
CONFIG_CMD_TRACE
CONFIG_CMD_UBI
CONFIG_CMD_UBIFS
CONFIG_CMD_UNZIP
CONFIG_FS_EXT4
Move below defines which are used by mtest utility to Kconfig.
CONFIG_SYS_MEMTEST_START
CONFIG_SYS_MEMTEST_END
Signed-off-by: Ashok Reddy Soma <ashok.reddy.soma@xilinx.com>
[trini: Fix kmcoge5ne board, re-run migration as well]
Like in Linux, just use CONFIG_MTD to compile the MTD stack.
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
CONFIG_SECURE_BOOT is too generic and forbids to use it for cross
architecture purposes. If Secure Boot is required for imx, this means to
enable and use the HAB processor in the soc.
Default value is too high and it covers the worst case. SPL for
imx6dl_mamoj becomes too big and cannot fit into the OCRAM, but CSF size
can be reduced.
CC: Jagan Teki <jagan@amarulasolutions.com>
CC: Breno Lima <breno.lima@nxp.com>
CONFIG_FSL_USDHC
[trini: Add IMX8M, TARGET_S32V234EVB to FSL_USDHC list]
Converted to use fsl_esdhc_imx for i.MX platforms.
Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com>
Tested-by: Steffen Dirkwinkel <s.dirkwinkel@beckhoff.com>
Reviewed-by: Peng Fan <peng.fan@nxp.com>
Reviewed-by: Lukasz Majewski <lukma@denx.de>
Reviewed-by: Martyn Welch <martyn.welch@collabora.com>
Acked-by: Jason Liu <Jason.hui.liu@nxp.com>
Commit d397f7c45b0b ("net: phy: micrel: Separate KSZ9000 drivers from
KSZ8000 drivers") separated the KSZ8xxx and KSZ90x1 drivers and warns
that you shouldn't select both of them due to a device ID clash between
the KSZ9021 and the KS8721, asserting that "it is highly unlikely for a
system to contain both a KSZ8000 and a KSZ9000 PHY". Unfortunately
boards like the SAMA5D3xEK do contain both types of PHY, but fortunately
the Linux Micrel PHY driver provides a solution by using different PHY
ID and mask values to distinguish these chips.
This commit contains the following changes:
- The PHY ID and mask values for the KSZ9021 and the KS8721 now match
those used by the Linux driver.
- The warnings about not enabling both drivers have been removed.
- The description for PHY_MICREL_KSZ8XXX has been corrected (these are
10/100 PHYs, not GbE PHYs).
- PHY_MICREL_KSZ9021 and PHY_MICREL_KSZ9031 no longer select PHY_GIGE
since this is selected by PHY_MICREL_KSZ90X1.
- All of the relevant defconfig files have been updated now that
PHY_MICREL_KSZ8XXX does not default to 'Y'.
Signed-off-by: James Byrne <james.byrne@origamienergy.com>
CONFIG_SUPPORT_EMMC_BOOT
As requested by Michal Simek <michal.simek@xilinx.com>, these boards
have no eMMC so CONFIG_SUPPORT_EMMC_BOOT has not been migrated:
xilinx_zynqmp_zc1275_revB
xilinx_zynqmp_zc1751_xm018_dc4
xilinx_zynqmp_zc1751_xm019_dc5
xilinx_zynqmp_zcu100_revC
xilinx_zynqmp_zcu102_rev1_0
xilinx_zynqmp_zcu102_revA
xilinx_zynqmp_zcu102_revB
xilinx_zynqmp_zcu104_revA
xilinx_zynqmp_zcu104_revC
xilinx_zynqmp_zcu106_revA
xilinx_zynqmp_zcu111_revA
Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
Acked-by: Lukasz Majewski <lukma@denx.de>
Acked-by: Patrick Delaunay <patrick.delaunay@st.com>
Acked-by: Ramon Fried <ramon.fried@gmail.com>
Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
Tested-by: Sébastien Szymanski <sebastien.szymanski@armadeus.com>
Moved CONFIG_SPL_TEXT_BASE to common/spl/Kconfig and migrate existing
values.
Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
[trini: Re-run migration]
The bounce buffer is used by a few drivers (most of the MMC drivers)
to overcome limitations in their respective DMA implementation.
This moves the configuration to Kconfig and makes it user-selectable
(even though it will be a required feature to make those drivers
work): the expected usage is for drivers depending on this to 'select'
it unconditionally from their respective Kconfig (see follow-up
patches).
This commit includes a full migration using moveconfig.py to ensure
that each commit compiles. To ensure bisectability we update
dependencies of various drivers to now select BOUNCE_BUFFER when needed.
[trini: Squash all patches to ensure bisectability]
Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Reviewed-by: Otavio Salvador <otavio@ossystems.com.br> [dw_mmc portion]
Reviewed-by: Fabio Estevam <festevam@gmail.com> [mxsmmc portion]
Reviewed-by: Simon Glass <sjg@chromium.org> [tegra portion]
CONFIG_MII
CONFIG_DRIVER_TI_EMAC
Acked-by: Jagan Teki <jagan@amarulasolutions.com>
We have the following cases:
- CONFIG_NR_DRAM_BANKS was defined, migrate normally
- CONFIG_NR_DRAM_BANKS_MAX was defined and then used for
CONFIG_NR_DRAM_BANKS after a check, just migrate it over now.
- CONFIG_NR_DRAM_BANKS was very oddly defined on p2771-0000-* (to 1024 +
2), set this to 8.
Separate CMD_FASTBOOT from FASTBOOT and move code and configuration to
drivers/fastboot.
Switch dependencies on FASTBOOT to USB_FUNCTION_FASTBOOT as anyone who wants
FASTBOOT before this series wants USB_FUNCTION_FASTBOOT. Split
USB_FUNCTION_FASTBOOT from FASTBOOT so they retain their existing
behaviour.
Enable Secure boot(HAB) for BTicino Mamoj board.
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
Add Falcon mode support to boot Linux directly after SPL.
Add DFU support for BTicino Mamoj board and update
the same steps in README.
Signed-off-by: Simone CIANNI <simone.cianni@bticino.it>
Signed-off-by: Raffaele RECALCATI <raffaele.recalcati@bticino.it>
Enable fastboot and ums for host to interact eMMC on
Mamoj board.
MX6DL Mamoj boards has Freescale PFUZE100 PMIC, add support
for it through DM_PMIC dt definition.
pmic log:
Reviewed-by: Stefano Babic <sbabic@denx.de>
=> pmic list
| Name | Parent name | Parent uclass @ seq
| pfuze100@08 | i2c@021f8000 | i2c @ 3
=> pmic dev pfuze100@08
dev: 0 @ pfuze100@08
=> pmic dump
Dump pmic: pfuze100@08 registers
0x00: 10 00 00 21 00 01 3f 01 00 7f 00 00 00 00 00 81
0x10: 00 00 3f 00 00 00 00 00 00 00 00 10 00 00 00 00
0x20: 2b 2b 2b 08 c4 00 00 00 00 00 00 00 00 00 2b 2b
0x30: 2b 08 c4 00 00 72 72 72 08 d4 00 00 2c 2c 2c 08
0x40: e4 00 00 2c 2c 2c 08 e4 00 00 6f 6f 6f 08 f4 00
0x50: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x60: 00 00 00 00 00 00 48 00 00 00 10 06 1e 1e 17 10
0x70: 1a 1f 00 00 00 00 00 00 00 00 00 00 00 00 00
i.MX6DL Mamoj has i2c3 and i2c4 buses, add support
through DM_I2C with dt definition.
i2c log:
=> i2c bus
Bus 2: i2c@021a8000
Bus 3: i2c@021f8000
=> i2c dev 2
Setting bus to 2
=> i2c speed 400000
Setting bus speed to 400000 Hz
=> i2c probe
Valid chip addresses: 20 51 53
=> i2c md 53 0xff
00ff: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
=> i2c md 51 0xff
00ff: a8 08 40 50 09 43 46 52 42 18 80 8e ae a9 d0 53 ..@P.CFRB......S
=> i2c dev 3
Setting bus to 3
=> i2c speed 100000
Setting bus speed to 100000 Hz
=> i2c probe
Valid chip addresses: 08 40 48 4B
=> i2c md 08 0xff
00ff: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
Add initial support for i.MX6DL BTicino Mamoj board.
Mamoh board added:
- SPL
- SPL_DM
- SPL_OF_CONTROL
- DM for U-Boot proper
- OF_CONTROL for U-Boot proper
- eMMC
- FEC
- Boot from eMMC
- Boot from USB SDP
