path: root/configs/imx6dl_mamoj_defconfig
2019-12-03mtd: rename CONFIG_MTD_DEVICE -> CONFIG_MTDMiquel Raynal
Like in Linux, just use CONFIG_MTD to compile the MTD stack. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
2019-11-07configs: Resync with savedefconfigTom Rini
2019-10-08imx: replace CONFIG_SECURE_BOOT with CONFIG_IMX_HABStefano Babic
CONFIG_SECURE_BOOT is too generic and forbids to use it for cross architecture purposes. If Secure Boot is required for imx, this means to enable and use the HAB processor in the soc. Signed-off-by: Stefano Babic <sbabic@denx.de>
2019-10-08board: imx6dl_mamoj: set the value for CSF sizeStefano Babic
Default value is too high and it covers the worst case. SPL for imx6dl_mamoj becomes too big and cannot fit into the OCRAM, but CSF size can be reduced. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Jagan Teki <jagan@amarulasolutions.com> CC: Breno Lima <breno.lima@nxp.com>
2019-09-23configs: Resync with savedefconfigTom Rini
2019-08-23Convert CONFIG_FSL_USDHC to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_FSL_USDHC Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Add IMX8M, TARGET_S32V234EVB to FSL_USDHC list] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-06-23Convert to use fsl_esdhc_imx for i.MX platformsYangbo Lu
Converted to use fsl_esdhc_imx for i.MX platforms. Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com> Tested-by: Steffen Dirkwinkel <s.dirkwinkel@beckhoff.com> Reviewed-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Martyn Welch <martyn.welch@collabora.com> Acked-by: Jason Liu <Jason.hui.liu@nxp.com>
2019-06-21configs: Resync with savedefconfigTom Rini
2019-05-14net: phy: micrel: Allow KSZ8xxx and KSZ90x1 to be used togetherJames Byrne
Commit d397f7c45b0b ("net: phy: micrel: Separate KSZ9000 drivers from KSZ8000 drivers") separated the KSZ8xxx and KSZ90x1 drivers and warns that you shouldn't select both of them due to a device ID clash between the KSZ9021 and the KS8721, asserting that "it is highly unlikely for a system to contain both a KSZ8000 and a KSZ9000 PHY". Unfortunately boards like the SAMA5D3xEK do contain both types of PHY, but fortunately the Linux Micrel PHY driver provides a solution by using different PHY ID and mask values to distinguish these chips. This commit contains the following changes: - The PHY ID and mask values for the KSZ9021 and the KS8721 now match those used by the Linux driver. - The warnings about not enabling both drivers have been removed. - The description for PHY_MICREL_KSZ8XXX has been corrected (these are 10/100 PHYs, not GbE PHYs). - PHY_MICREL_KSZ9021 and PHY_MICREL_KSZ9031 no longer select PHY_GIGE since this is selected by PHY_MICREL_KSZ90X1. - All of the relevant defconfig files have been updated now that PHY_MICREL_KSZ8XXX does not default to 'Y'. Signed-off-by: James Byrne <james.byrne@origamienergy.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2019-05-04Convert CONFIG_SUPPORT_EMMC_BOOT to KconfigAlex Kiernan
This converts the following to Kconfig: CONFIG_SUPPORT_EMMC_BOOT As requested by Michal Simek <michal.simek@xilinx.com>, these boards have no eMMC so CONFIG_SUPPORT_EMMC_BOOT has not been migrated: xilinx_zynqmp_zc1275_revB xilinx_zynqmp_zc1751_xm018_dc4 xilinx_zynqmp_zc1751_xm019_dc5 xilinx_zynqmp_zcu100_revC xilinx_zynqmp_zcu102_rev1_0 xilinx_zynqmp_zcu102_revA xilinx_zynqmp_zcu102_revB xilinx_zynqmp_zcu104_revA xilinx_zynqmp_zcu104_revC xilinx_zynqmp_zcu106_revA xilinx_zynqmp_zcu111_revA Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Acked-by: Lukasz Majewski <lukma@denx.de> Acked-by: Patrick Delaunay <patrick.delaunay@st.com> Acked-by: Ramon Fried <ramon.fried@gmail.com> Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Tested-by: Sébastien Szymanski <sebastien.szymanski@armadeus.com>
2019-01-19Kconfig: Migrate BOUNCE_BUFFERPhilipp Tomsich
The bounce buffer is used by a few drivers (most of the MMC drivers) to overcome limitations in their respective DMA implementation. This moves the configuration to Kconfig and makes it user-selectable (even though it will be a required feature to make those drivers work): the expected usage is for drivers depending on this to 'select' it unconditionally from their respective Kconfig (see follow-up patches). This commit includes a full migration using moveconfig.py to ensure that each commit compiles. To ensure bisectability we update dependencies of various drivers to now select BOUNCE_BUFFER when needed. [trini: Squash all patches to ensure bisectability] Signed-off-by: Tom Rini <trini@konsulko.com> Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Otavio Salvador <otavio@ossystems.com.br> [dw_mmc portion] Reviewed-by: Fabio Estevam <festevam@gmail.com> [mxsmmc portion] Reviewed-by: Simon Glass <sjg@chromium.org> [tegra portion]
2018-05-30fastboot: Move fastboot to drivers/fastbootAlex Kiernan
Separate CMD_FASTBOOT from FASTBOOT and move code and configuration to drivers/fastboot. Switch dependencies on FASTBOOT to USB_FUNCTION_FASTBOOT as anyone who wants FASTBOOT before this series wants USB_FUNCTION_FASTBOOT. Split USB_FUNCTION_FASTBOOT from FASTBOOT so they retain their existing behaviour. Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-05-18configs: imx6dl-mamoj: Enable HABJagan Teki
Enable Secure boot(HAB) for BTicino Mamoj board. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2018-05-18configs: imx6dl-mamoj: Add Falcon mode supportJagan Teki
Add Falcon mode support to boot Linux directly after SPL. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2018-05-18configs: imx6dl-mamoj: Add DFU supportJagan Teki
Add DFU support for BTicino Mamoj board and update the same steps in README. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Signed-off-by: Simone CIANNI <simone.cianni@bticino.it> Signed-off-by: Raffaele RECALCATI <raffaele.recalcati@bticino.it>
2018-05-18configs: imx6dl_mamoj: Enable fastboot and umsJagan Teki
Enable fastboot and ums for host to interact eMMC on Mamoj board. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Signed-off-by: Simone CIANNI <simone.cianni@bticino.it> Signed-off-by: Raffaele RECALCATI <raffaele.recalcati@bticino.it>
2018-05-18i.MX6DL: mamoj: Add PFUZE100 supportJagan Teki
MX6DL Mamoj boards has Freescale PFUZE100 PMIC, add support for it through DM_PMIC dt definition. pmic log: Reviewed-by: Stefano Babic <sbabic@denx.de> ======== => pmic list | Name | Parent name | Parent uclass @ seq | pfuze100@08 | i2c@021f8000 | i2c @ 3 => pmic dev pfuze100@08 dev: 0 @ pfuze100@08 => pmic dump Dump pmic: pfuze100@08 registers 0x00: 10 00 00 21 00 01 3f 01 00 7f 00 00 00 00 00 81 0x10: 00 00 3f 00 00 00 00 00 00 00 00 10 00 00 00 00 0x20: 2b 2b 2b 08 c4 00 00 00 00 00 00 00 00 00 2b 2b 0x30: 2b 08 c4 00 00 72 72 72 08 d4 00 00 2c 2c 2c 08 0x40: e4 00 00 2c 2c 2c 08 e4 00 00 6f 6f 6f 08 f4 00 0x50: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x60: 00 00 00 00 00 00 48 00 00 00 10 06 1e 1e 17 10 0x70: 1a 1f 00 00 00 00 00 00 00 00 00 00 00 00 00 Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Signed-off-by: Simone CIANNI <simone.cianni@bticino.it> Signed-off-by: Raffaele RECALCATI <raffaele.recalcati@bticino.it>
2018-05-18i.MX6DL: mamoj: Add I2C supportJagan Teki
i.MX6DL Mamoj has i2c3 and i2c4 buses, add support through DM_I2C with dt definition. i2c log: Reviewed-by: Stefano Babic <sbabic@denx.de> ======= => i2c bus Bus 2: i2c@021a8000 Bus 3: i2c@021f8000 => i2c dev 2 Setting bus to 2 => i2c speed 400000 Setting bus speed to 400000 Hz => i2c probe Valid chip addresses: 20 51 53 => i2c md 53 0xff 00ff: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................ => i2c md 51 0xff 00ff: a8 08 40 50 09 43 46 52 42 18 80 8e ae a9 d0 53 ..@P.CFRB......S => i2c dev 3 Setting bus to 3 => i2c speed 100000 Setting bus speed to 100000 Hz => i2c probe Valid chip addresses: 08 40 48 4B => i2c md 08 0xff 00ff: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Signed-off-by: Simone CIANNI <simone.cianni@bticino.it> Signed-off-by: Raffaele RECALCATI <raffaele.recalcati@bticino.it>
2018-05-18i.MX6: board: Add BTicino i.MX6DL Mamoj initial supportJagan Teki
Add initial support for i.MX6DL BTicino Mamoj board. Mamoh board added: - SPL - SPL_DM - SPL_OF_CONTROL - DM for U-Boot proper - OF_CONTROL for U-Boot proper - eMMC - FEC - Boot from eMMC - Boot from USB SDP Signed-off-by: Simone CIANNI <simone.cianni@bticino.it> Signed-off-by: Raffaele RECALCATI <raffaele.recalcati@bticino.it> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
