Enable Flattened Image Tree support for all Engicam boards.
Cc: Matteo Lisi <matteo.lisi@engicam.com>
Cc: Michael Trimarchi <michael@amarulasolutions.com>
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
Boot Linux with uImage instead of zImage, so update
bootz with bootm.
Generated by "tools/moveconfig -s".
This will make config moves easier.
Add FEC support for Engicam i.CoreM6 RQS modules.
Add I2C support for Engicam i.CoreM6 RQS modules.
icorem6qdl-rqs> i2c bus
Bus 0: i2c@021a0000
Bus 1: i2c@021a4000
Bus 2: i2c@021a8000
icorem6qdl-rqs> i2c dev 0
Setting bus to 0
icorem6qdl-rqs> i2c speed 100000
Setting bus speed to 100000 Hz
icorem6qdl-rqs> i2c probe
Valid chip addresses: 4F
icorem6qdl-rqs> i2c md 4F 0xff
00ff: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
Bus 0: i2c@021a0000 (active 0)
4f: generic_4f, offset len 1, flags 0
Bus 1: i2c@021a4000
Bus 2: i2c@021a8000
Boot from MMC:
U-Boot SPL 2016.11-rc2-g217bd8e-dirty (Nov 08 2016 - 22:56:07)
Trying to boot from MMC1
U-Boot 2016.11-rc2-g217bd8e-dirty (Nov 08 2016 - 22:56:07 +0530)
CPU: Freescale i.MX6DL rev1.3 at 792 MHz
Reset cause: POR
Model: Engicam i.CoreM6 DualLite/Solo RQS Starter Kit
DRAM: 512 MiB
MMC: FSL_SDHC: 0
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: CPU Net Initialization Failed
No ethernet found.
Hit any key to stop autoboot: 0
icorem6qdl-rqs>
