This partially reverts changes by commit 2cc393f32fd9
("video: make BPP and ANSI configs optional") since it
caused issues with other boards (missing LCD console
output on pinebook, x86 platform or sandbox). Enable
all disabled options again and opt out of not supported
color depth in board defconfigs.
Reported-by: Vagrant Cascadian <vagrant@debian.org>
Rename CONFIG_SPL_DMA_SUPPORT to CONFIG_SPL_DMA. This allows to use
macros such as CONFIG_IS_ENABLED() that allow conditional compilation of
code for SPL and U-Boot.
Signed-off-by: Vignesh Raghavendra <vigneshr@ti.com>
Many boards do not use all selected framebuffer depth
configurations, for such boards there is some unused
code in video and console uclass routines. Make depth
specific code optional to avoid dead code and slightly
reduce binary size. Also make ANSI code optional for
the same reason. When i.e. using only VIDEO_BPP16 the
code size shrinks (below values when using gcc-7.3.0):
$ ./tools/buildman/buildman -b video-wip -sS wandboard
01: Merge git://git.denx.de/u-boot-sh
02: video: add guards around 16bpp/32bbp code
03: video: make BPP and ANSI configs optional
arm: (for 1/1 boards) all -776.0 bss -8.0 text -768.0
Tested-by: Eugen Hristev <eugen.hristev@microchip.com>
Tested-by: Patrice Chotard <patrice.chotard@st.com>
Tested-by: Steffen Dirkwinkel <s.dirkwinkel@beckhoff.com>
Both symbols must be enabled when there is a raw NAND driver
selected. Also enable them when CONFIG_CMD_NAND is selected to avoid
breaking things when we'll further rework the MTD dependency
description.
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
[trini: Rebase and migrate a few more boards here]
Add more clarity by changing the Kconfig entry name.
[trini: Re-run migration, update a few more cases]
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
Define "splashimage" variable in the default environment
and enable BMP code. Also configure white on black for
video console.
CONFIG_FSL_USDHC
[trini: Add IMX8M, TARGET_S32V234EVB to FSL_USDHC list]
The name CONFIG_LEGACY_IMAGE_FORMAT reads slightly better along with
allowing us to avoid a rather nasty Kbuild/Kconfig issue down the line
with CONFIG_IS_ENABLED(IMAGE_FORMAT_LEGACY). In a few places outside of
cmd/ switch to using CONFIG_IS_ENABLED() to test what is set.
Converted to use fsl_esdhc_imx for i.MX platforms.
Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com>
Reviewed-by: Peng Fan <peng.fan@nxp.com>
Reviewed-by: Lukasz Majewski <lukma@denx.de>
Reviewed-by: Martyn Welch <martyn.welch@collabora.com>
Acked-by: Jason Liu <Jason.hui.liu@nxp.com>
Moved CONFIG_SPL_TEXT_BASE to common/spl/Kconfig and migrate existing
values.
Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
[trini: Re-run migration]
Enable DM_VIDEO in defconfigs.
SPL on Engicam i.Core M6 boards enabled DM, so it would require some
malloc() pool before relocation in order to load U-Boot proper properly.
So, enable SPL malloc() pool of 0x2000 size similarly like what we have
used for icore mmc defconfigs.
Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
Tested-by: Shyam Saini <shyam.saini@amarulasolutions.com>
Signed-off-by: Michael Trimarchi <michael@amarulasolutions.com>
Reviewed-by: Fabio Estevam <festevam@gmail.com>
The bounce buffer is used by a few drivers (most of the MMC drivers)
to overcome limitations in their respective DMA implementation.
This moves the configuration to Kconfig and makes it user-selectable
(even though it will be a required feature to make those drivers
work): the expected usage is for drivers depending on this to 'select'
it unconditionally from their respective Kconfig (see follow-up
patches).
This commit includes a full migration using moveconfig.py to ensure
that each commit compiles. To ensure bisectability we update
dependencies of various drivers to now select BOUNCE_BUFFER when needed.
[trini: Squash all patches to ensure bisectability]
Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Reviewed-by: Otavio Salvador <otavio@ossystems.com.br> [dw_mmc portion]
Reviewed-by: Fabio Estevam <festevam@gmail.com> [mxsmmc portion]
Reviewed-by: Simon Glass <sjg@chromium.org> [tegra portion]
Now that CMD_UBI does not select CMD_MTDPARTS we need to make platforms
that had been enabling it turn it on by hand. This exposed that we had
not yet migrated CMD_MTDPARTS fully, so do so now.
Fixes: 86dfa556d927 ("cmd: ubi: Remove useless call to mtdparts_init()")
CONFIG_MII
CONFIG_DRIVER_TI_EMAC
Acked-by: Jagan Teki <jagan@amarulasolutions.com>
We have the following cases:
- CONFIG_NR_DRAM_BANKS was defined, migrate normally
- CONFIG_NR_DRAM_BANKS_MAX was defined and then used for
CONFIG_NR_DRAM_BANKS after a check, just migrate it over now.
- CONFIG_NR_DRAM_BANKS was very oddly defined on p2771-0000-* (to 1024 +
2), set this to 8.
This converts IMAGE_FORMAT_LEGACY to Kconfig
Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
Migrate the CONFIG_FSL_ESDHC option to Kconfig.
Signed-off-by: Mario Six <mario.six@gdsys.cc>
Currently SPL_LOAD_FIT is unable to boot from nand on
i.MX6QDL platform, so enable only for MMC boards.
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
SPL FIT is able to pick the suitable fdt file for u-boot,
so add that function through board_fit_config_name_match.
Cc: Matteo Lisi <matteo.lisi@engicam.com>
Cc: Michael Trimarchi <michael@amarulasolutions.com>
Set fdt_file env variable during board_late_init
CONFIG_CMD_BMODE
[trini: Make this default y and depend on mx5/6/7]
Enable Flattened Image Tree support for all Engicam boards.
Create ubifs.img:
$ mkfs.ubifs -q -r /rootfs -m 4096 -e 253952 -c 7936 -o ubifs.img
Write ubifs.img:
icorem6qdl> nand erase.part rootfs
icorem6qdl> ubi part rootfs
icorem6qdl> ubi create rootfs
icorem6qdl> ext4load mmc 0:2 ${loadaddr} ubifs.img
166592512 bytes read in 8091 ms (19.6 MiB/s)
icorem6qdl> ubi write ${loadaddr} rootfs ${filesize}
166592512 bytes written to volume rootfs
icorem6qdl> ubifsmount ubi0:rootfs
For writing Linux or rootfs on to NAND, the best suitable way
is to use MMC commands since MMC driver by default enabled by
mx6_common.h, hence enabled MMC commands in nand defconfigs.
Boot Linux with uImage instead of zImage, so update
bootz with bootm.
Generated by "tools/moveconfig -s".
This will make config moves easier.
Rename defconfig files for better compatible with
respective board names and dts files.
