path: root/configs/imgtec_xilfpga_defconfig
2016-09-21mips: Add MIPSfpga platform supportZubair Lutfullah Kakakhel
MIPSfpga is an FPGA based dev platform. In a nutshell, its a microAptiv cpu core with lots of Xilinx IP blocks The FPGA dev board used is the Nexys4DDR board by Digilent. For more information, check the Readme file in board/imgtec/xilfpga Signed-off-by: Zubair Lutfullah Kakakhel <Zubair.Kakakhel@imgtec.com> Reviewed-by: Paul Burton <paul.burton@imgtec.com> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
