path: root/configs/ids8313_defconfig
2018-02-25bootcount: Migrate CONFIG_SYS_BOOTCOUNT_ADDRTom Rini
Migrate the users of CONFIG_SYS_BOOTCOUNT_ADDR to Kconfig. We can provide a default for BOOTCOUNT_AM33XX as that's a specific part of the RTC in use. We can also provide a default for ARCH_LS1043A and ARCH_LS1021A as they had been previously calculated and their symbols are in Kconfig. In the case of other QE-enabled platforms, they are not so we must update the relevant defconfig files. The previous default only applied in some cases, even on a specific SoC family. Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Alex Kiernan <alex.kiernan@gmail.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-24Convert CONFIG_BOOTCOUNT_I2C to KconfigAlex Kiernan
This converts the following to Kconfig: CONFIG_BOOTCOUNT_I2C Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Lukasz Majewski <lukma@denx.de>
2018-02-15Convert CONFIG_BOOTCOUNT_LIMIT to KconfigLukasz Majewski
This converts the following to Kconfig: CONFIG_BOOTCOUNT_LIMIT Signed-off-by: Lukasz Majewski <lukma@denx.de> Tested-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com> Acked-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
2018-02-13spi: Migrate CONFIG_MPC8XXX_SPI to KconfigTuomas Tynkkynen
2017-05-22Convert CONFIG_CMD_JFFS2 to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_JFFS2 Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_CMD_ENV_FLAGS to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_ENV_FLAGS Signed-off-by: Simon Glass <sjg@chromium.org>
2016-09-26kconfig: introduce kconfig for UBIHeiko Schocher
move the UBI config options into Kconfig. Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Andrew F. Davis <afd@ti.com> Reviewed by: Evgeni Dobrev <evgeni at studio-punkt.com>
2015-06-08autoboot.c: Move config options to KconfigStefan Roese
This patch moves the following config options to Kconfig: CONFIG_AUTOBOOT_KEYED CONFIG_AUTOBOOT_PROMPT CONFIG_AUTOBOOT_DELAY_STR CONFIG_AUTOBOOT_STOP_STR AUTOBOOT_KEYED_CTRLC Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: Drop ip04 and pm9263 configs/ additions, those boards previously set CONFIG_AUTOBOOT_PROMPT but never used it, re-run savedefconfig over all boards that did change. Make digsy_mtc_* string include seconds to match others and not warn. ] Signed-off-by: Tom Rini <trini@konsulko.com> Cc: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-04-18powerpc: ids8313: use "select" instead of default value in defconfigMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-01-29lib/rsa: Modify rsa to use DM driverRuchika Gupta
Modify rsa_verify to use the rsa driver of DM library .The tools will continue to use the same RSA sw library. CONFIG_RSA is now dependent on CONFIG_DM. All configurations which enable FIT based signatures have been modified to enable CONFIG_DM by default. Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com> CC: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2015-01-29configs: Move CONFIG_FIT_SIGNATURE to defconfigRuchika Gupta
For the platforms which use,CONFIG_FIT_SIGNATURE, the required configs are moved to the platform's defconfig file. Selecting CONFIG_FIT_SIGNATURE using defconfig automatically resolves the dependencies for signature verification. The RSA library gets automatically selected and user does not have to define CONFIG_RSA manually. Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com> CC: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
