path: root/configs/iNet_3W_defconfig
2016-05-25sunxi: Enable a bunch of commands by default on sunxiHans de Goede
Recently a set of CONFIG_CMD_FOO defines was moved from being defined in config_distro_defaults to Kconfig, and added to all sunxi defconfigs to compensate. Instead of explictly selecting these in all sunxi defconfigs, simply always select these for sunxi boards. This makes the defconfigs simpler and ensures a consistent set of available commands across all sunxi boards. Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-04-12sunxi: Enable CMD_GPIO on all sunxi boardsHans de Goede
We have CONFIG_CMD_GPIO=y in almost all sunxi boards, but after its Kconfig conversion it has ended up missing on some recently added boards. Simply select it for ARCH_SUNXI, so that we get it on all sunxi boards for both a consistent user experience and simpler defconfig files. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2016-03-23sunxi: Select CONFIG_OF_BOARD_SETUP from arch/arm/KconfigHans de Goede
Always select OF_BOARD_SETUP on sunxi, rather then having it in almost all our defconfigs. This also fixes it missing from some recently added defconfigs. This commit also modifies our ft_board_setup() to not cause warnings when CONFIG_VIDEO_DT_SIMPLEFB is not set, since we will now always build it. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-12-10sunxi: select SYS_NS16550 from KconfigHans de Goede
Select SYS_NS16550 from Kconfig instead of setting it in all our defconfig files. Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-10-20sunxi: Kconfig-ify CONFIG_AXP152_POWER and _AXP209_POWERHans de Goede
Kconfig-ify CONFIG_AXP152_POWER and _AXP209_POWER settings, removing them from CONFIG_SYS_EXTRA_OPTIONS. Note that sun5i boards can have either an AXP209 or an AXP152 pmic, the Kconfig default is AXP209, boards with an AXP152 must explicitly select this. Likewise boards without a pmic must explicitly select SUNXI_NO_PMIC in their defconfig. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-08-21Tidy up some defconfig filesSimon Glass
Several files are out of order. This means that when the moveconfig tool moves CONFIG options to Kconfig it generates a large diff. To avoid this, reorder the files first. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-08-05sunxi: usb: USB_MUSB_SUNXI move to musb-new KconfigPaul Kocialkowski
Now that the musb-new driver has a Kconfig, we can move Kconfig options to enable controllers to it, so that it's easier in e.g. menuconfig. In addition, this allows declaring support for USB_MUSB_HOST/GADGET in defconfigs instead of the USB_MUSB_SUNXI controller, that will get selected automatically when needed. Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
2015-04-15sunxi: iNet 3W supportPaul Kocialkowski
The iNet 3W is an A10 tablet with 1GiB RAM and a 1024x768 screen. Also see: http://linux-sunxi.org/INet_3W Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
